Question about HP OFFICEJET PRO 6830 E-ALL-IN-ONE PRINTER
Officejet Pro 6830 0xc19a0040 error print head
Techvisitor
  • 63 Answers
SOURCE: The following printhead(s) has a problem Black/Yellow[K/Y].
Simple solution is:
Replace the Black and Yellow Print Catridges. The print heads are mounted to the bottom of the catridges and these, depending on whther they're from HP or not. can have a hard time conducting electricity properly, and in turn.. spitting ink out properly.
Also happens often with aftermarket Catridges because HP puts chips on the catridge. be sure to put an HP catridge. Sometimes you get what you pay for :)
Posted on Oct 31, 2008
Amardeep46
  • 129 Answers
SOURCE: "Door Open" error message
check all the doors of the printer. If they are not closed, The printer will continue to throw this error.
Posted on Feb 28, 2009
nalin_elliot
  • 224 Answers
SOURCE: HP officejet Pro 7580 problems with streaking
Clean the electrical contacts on the printhead and inside the product The ink nozzles on the printheads might clog if they are exposed to air for more than a few minutes or if the product is not used for long periods of time. Follow these steps to clean the electrical contacts on the printheads. CAUTION: Follow these steps carefully to avoid damaging the sensitive electrical components.
  1. Make sure that the product is turned on.
  2. Open the top cover of the product.
  3. Press and hold the OK button for five seconds. The carriage moves to the left side of the product and stops. Release the OK button.
  4. Wait until the carriage is idle and silent.
  5. Unplug the product power cord from the electrical outlet.
    NOTE: Do not turn the product off by pressing the Power button (c01346625.gif ). This causes the carriage to move out of reach.
  6. Lift the printhead latch. Figure 1: Lift the printhead latch c01448109.gif
  7. Lift the handle on the printhead that the error message indicates is missing or damaged, and then pull the printhead out of its slot. Figure 2: Lift the handle and remove the printhead c01448110.gif
  8. Use a dry, soft, lint-free cloth to remove any ink from the electrical contacts on the printhead.
    1. Wipe the electrical contacts with the swab until no ink residue remains, and then wipe the electrical contacts with a fresh cloth to dry them and remove lint.
    2. After the electrical contacts on the printhead are clean and dry, place the printhead on a sheet of paper or a paper towel. Make sure that the ink nozzles face up and do not touch the paper.
    3. Use a fresh, dry, soft, lint-free cloth to clean the electrical contacts inside the product. Figure 4: Clean the electrical contacts inside the product c01448112.gif
    4. Allow at least five minutes for the contacts to dry. Check the contacts for lint or debris, and then dry or clean the contacts again if needed.
    5. Plug the product power cord into the electrical outlet.
    6. Press the Power button (c01346625.gif ) to turn on the product. 'Printhead missing or damaged, replace the printhead' displays on the control panel.
    7. Insert the printhead into its color-coded slot. Press down firmly on the printhead to make sure the electrical contacts touch.
    8. Pull the printhead latch all the way forward, and then press down firmly to engage the latch.
      NOTE: You might have to press firmly to engage the latch. If the error message indicates that both printheads are missing or damaged, repeat the steps in this procedure to clean the other printhead.
    9. Close the top cover of the product. The product restarts and then prints an alignment page.
    10. Click on setup on the printer select tools and select clean printhead.
    11. inside the printer clean the metal carriage rod,rollers and that is it (clean with moist cotton swab)
Posted on Jun 23, 2009
  • 54 Answers
SOURCE: print head on Officejet Pro L7590
Press Setup on the control panel.
Press the right arrow button until Tools displays, and then press OK .
Press 2 to begin the cleaning process.
Posted on Nov 21, 2009
SOURCE: Officejet Pro L7650 black/yellow print head problem
There isn't a good fix for this problem. You can try the following;
1. Plug Unit Directly into wall, not thru a powerstrip.
2. Reset the Printer, Unplug Power Supply, Wait 30 Secs. Re-connect. Turn Power Back On.
3. Open Case, Wait for Printheads to move to right. Take Out Offending Printhead. Clean Gold Contacts / Soak Print Nozzles in 1/8" Water, if dried out. shake printhead to loosen stuck nozzles (watch out for flying ink!!). DO NOT PUT PRINTHEAD BACK IN YET!! Close Cover. Wait for printer to say "XXX Printhead is missing" Re-Open Cover, Wait till printheads move to right, Re-Insert Printhead, Close Cover. Reset if Necessary.
4. BTW None of this worked for me. I'm gonna see if anyone I know has one of these printers and swap out parts to see if it is indeed the printhead(s).
5. According to other posts, HP Service will tell you to try all of the above, then when it doesn't work, they tell you your printer is defective. Someone else mentioned a bad firmware problem. If you're out of warranty, your screwed. Another HP Horror Story! Oh My! California wants to elect their old CEO. lol.
Posted on Apr 13, 2010
Hp officejet pro 8500a shows cleaning print head/alining print head
that might be your printing settings and laptop file formate
Mar 17, 2016 | HP Office Equipment & Supplies
My HP officejet pro L7580 has stopped printing black. The cartridge has been replaced ( HP original) . Other colours are fine. Printheads are fine. Error message on display: Alignment failed - Refer to...
On this HP the print head is not part of the cartridge. How do you know the print head is fine? Did you just try to do a test page without an alignment?
I know that HP (they suck) will not help you because you are past warranty - Google your question since I am sure that you are not the only person to have experienced this issue.
I think you have a bad print head.
Sep 18, 2017 | HP Officejet Pro L7580 All-In-One InkJet...
How do I remove old printheads
Hi the below website explains how to fix print head errors and how to remove/replace the print heads in HP Officejet Pro L7680 All-In-One Printer
http://tinyurl.com/raj12345
Best Of Luck.......
Dec 09, 2010 | HP Officejet Pro L7680 All-In-One Printer
Head error after replkad
Remove the print heads and very gently clean the area on the printer and print head where the electrical contacts are. Do this with a Q-tip lightly moistened with distilled water. Be sure all surfaces are clean and dry before reinstalling the print head. If that doesn't work then your replacement print head is bad and you should return it to where you bought it or contact HP.
Jun 09, 2010 | HP Officejet Pro K5400 All-In-One InkJet...
HP Officejet pro l7580 magenta won't print, new HP cartridge 8/11
You will have to reset the printer.If you want any further support, a technician from techbuddies can help you for free.For this log on to www.techbuddies.org
Jun 18, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
L7380 is givinf errors on printthaed
This particular printer has separate ink heads and cartridges.
Call HP and complain about it not lasting the specified amount of prints and they might get it to you free.
Is this less than a year old?
Jun 17, 2009 | HP Officejet Pro L7380 Laser Printer
HP OfficeJet Pro l7500 won't print. Printer queue shows 5 jobs with error on first 2. I tried twice after rebooting the computer.How to print , or how to download proper driver? SB
Officejet Pro L7500 is giving me error message that it can see the black and yellow print head I have replaced it and it is still giving me the same error.
Is there a way to clean it with out having to have it taken in to be repaired?
Jun 10, 2009 | HP Office Equipment & Supplies
Print Head Problems
Try cleaning the print hade sensor useing alcohol.it is by the home position whera the print hade is installed.
Apr 30, 2008 | HP Officejet Pro L7680 All-In-One Printer
HP OFFICEJET PRO 6830 E-ALL-IN-ONE PRINTER Logo
264 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
