What is the purpose of levels on this website??
What will I get after reaching level 2 or level 3??
  • 1,926 Answers
Nothing except the recognition. I do this just to amuse myself so it isn't relevant to me, but the levels and awards and Earls and Dukes etc are meant to encourage people to provide solutions I guess.
Posted on Dec 15, 2016
  • Webaloons
    Webaloons Dec 15, 2016
    Don't they give you any kind of authority when you become an expert??
  • Geoff White
    Geoff White Dec 15, 2016
    None that I've noticed. Maybe I missed it LOL. I just post something when I know something.
What are the benefits of using rain water harvesting?
There are many benefits of rainwater harvesting, and some of them are listed below:
1. The rainwater can be used for irrigation.
2.Reduces water bills.
3. After filtering can be used for drinking.
4. Increases ground water level.
5. Easy maintenance.
There are lot more advantages for which you can refer Regenwassertonne.
Mar 17, 2017 | The Kitchen Appliances - Others
What is the significance of steam pressure reducing valve?
It's a safety item, designed to stop this pressure reaching any dangerous level. High pressure steam can be very dangerous when let loose, as much as a blowtorch, so you only want enough to give you a good latte, no more.
Jul 13, 2016 | Coffee Makers & Espresso Machines
I have been playing jellysplash via facebook for ages but today when i reached level 120 on my computer, it will not sync on kindle or phone, Help
I had a similar problem on Facebook with a game. You might try a different account and basically start over. Good luck.
good luck.
Jun 18, 2014 | Facebook Computers & Internet
Just purchased a Danby dehumidifier (model # DDR6O11R). I was wondering when the dehumidifier reaches the programmed level of humidity (example: 40%). Is the unit suppose to shut off completely? I believe...
Depending on which mode you have the unit set on, will determine if it shots OFF entirely or the fan continues to run. In the Constant or Continual mode, the compressor will turn OFF, once the humidity extraction level has been reached. But, the fan will continue to operate, in an effort to keep the air circulating, so that if the humidity level rises, the compressor will turn ON and start extracting again.
In Timed Mode (usually 2 hour or 4 hour) , when the compressor turns OFF the fan does too.
Hope this helped you. Please let me know. Thanks.
Jun 06, 2011 | Danby Dehumidifier
I want to change transmition fluid on ford festiva 1991 (manual transmition). I found the drain bolt , but my problem is what fluid I should put in, how much and I can't find a opening for fluid to...
Transmission Fluid Fill
  1. Remove the Speedometer Cable Sleeve (17B301) and Speedometer Gear (17271). Refer to the procedure in this section.
  1. Fill the transaxle with Motorcraft MERCON® Multi-Purpose ATF XT-2-QDX. Refer to Transmission Fluid Capacity for specifications.
  1. Check the transmission fluid level. Refer to the procedure in this section.
May 25, 2011 | 1991 Ford Festiva
While on rinse cycle. the machine make a loud of noise, the whole machine shake alot. i replace all the 3 spring, and one spring on the back. and notice there is 2 pin that drop. so i re scure the pin. but...
I had the same problem. It was a combination of unbalanced loads and the machine was not level. I used a torpedo level I bought at Lowes to check the level of the machine. First, standing in front of the machine, put the level on the front edge of the machine top. Measure left to right and using a wrench adjust the screw feet on the bottom front of the machine until you reach level. Then standing in front of the machine, grab the two back corners of the machine console body (do not use the control panel for this as you will break it loose from the body). pulling up and forward, rotate the machine so that the back feet are lifted off the floor, while the front feet are still making contact with the floor. This allows the back feet to automatically level the machine. Using the level check from front to back on the left and right top of the machine body to ensure level is reached. Repeat the entire process until you reach an acceptable level condition on the washer. Note: All level measurements must be made on a flat surface of the machine.
Jan 19, 2011 | Whirlpool Washing Machines
If i lay a pipe 6 inches below the surface of the sea and let it fill up with sea water i lay it out under the sea at a 2 degree angle until it come out of the sea (due to curve of earth) will the sea...
I would say no. The water in the pipe that is above sea level will drop back in the pipe until it reaches sea level. Provided neither end of the pipe whether above or below the sea is blocked the level in the pipe will always find natural sea level so it wont be higher or lower than sea level. So in answer to your question No it wont pour out.
Nov 08, 2010 | Scuba Diving & Snorkeling
A well has 15 steps inside.the water level is at ninth steps.
It is a trick question sort of. The frog reaches water on the 6th jump before it has to jump back 2 steps for that turn.
May 15, 2010 | Answer Carbon Expert BMX Handlebar
The instructions for the Bop it was thrown away with the Xmas wrapping paper Can I get instructions on line how to continue to play after reaching 100?
just go on bop it hasbro just type in bop it instructions and hasbro bop it should show up then click demo and then unlock it then go on exper level and look at the tpo and it says it
Jan 02, 2010 | Toys
How do I enter cheat codes for call of duty worl at war on playstation 3
Text excerpt found at: http://cheats.ign.com/ob2/068/902/902587.html Cheat: Cheat List Cheats are unlocked not by inserting passwords, but by acquiring the thirty Intel Pieces strewn throughout the game.
The more of them you collect, the more cheats you can access. On the left are the number of Intel Pieces collected, and on the right are the cheats that are unlocked, with an explanation of what each does.
  • 2 - "CoD Noir" Play the game in black and white.
  • 4 - "Photo-Negative" Game colors become inverted.
  • 6 - "Super Contrast" Game's contrast increases.
  • 8 - "Ragtime Warfare" The game feels like an old silent movie.
  • 10 - "Cluster Bombs" One frag grenade thrown equals five in explosion.
  • 15 - "A Bad Year" Enemies explode into tires when shot.
  • 20 - "Slow-Mo Ability" Game plays at 40% normal speed.
  • 30 - "Infinite Ammo" Just what it says.
Unlockable: Arcade Mode To unlock Arcade Mode, beat the game once through on any difficulty level. Arcade Mode itself is split into two options - Full Challenge or Level Challenge - that add extra replayability to the game.
Unlockable: Prestige Mode To unlock Prestige Mode, which is a multiplayer-only mode, you must reach experience level fifty-five. Instead of capping out at level fifty-five, which is the highest level, Prestige Mode allows you to start again from level one. This can be done a total of ten times, giving you ten different icons in in-game lobbies to show your extreme achievement.
Unlockable: New Mission To play an all-new mission, which is an extra mission after the main quest is completed, beat the game and view the ending credits thereafter. After they've run their course, you will then be given the opportunity to play one last single player mission before all is said and done.
Unlockable: Golden Weapons To unlock the following "Golden" weapons, fulfill the requirement listed.
  • AK-47 - Complete all Assault Rifle challenges
  • Desert Eagle - Attain Level 55
  • Dragonuv - Complete all Sniper Rifle challenges
  • M1014 - Complete all Shotgun challenges
  • M60 - Complete all LMG challenges
  • Mini-Uzi - Complete all SMG challenges
Unlockable: Multiplayer Weapons To unlock the following weapons in multiplayer mode, reach the numbered rank listed.
  • Assault Rifle (G3) - Rank 25
  • Assault Rifle (G36C) - Rank 37
  • Assault Rifle (M14) - Rank 46
  • Assault Rifle (M4) - Rank 10
  • Assault Rifle (MP44) - Rank 52
  • LMG (M60E4) - Rank 19
  • Pistol (Desert Eagle) - Rank 43
  • Pistol (Golden Desert Eagle) - Rank 55
  • Pistol (M1911) - Rank 16
  • Shotgun (M1014) - Rank 31
  • SMG (AK-74U) - Rank 28
  • SMG (Mini Uzi) - Rank 13
  • SMG (P90) - Rank 40
  • Sniper Rifle (Barret) - Rank 49
  • Sniper Rifle (Dragunov) - Rank 22
  • Sniper Rifle (M40) - Rank 04
  • Sniper Rifle (R700) - Rank 34
Hint: Intel Pieces Below is the level distribution list for Intel Pieces, which are enemy laptops full of information strewn throughout the game. There are thirty of them total. The left column is the level in question, while the right column is how many Intel Pieces can be found on that level. Levels with no Intel Pieces are excluded completely.
  • Level 2 - 2
  • Level 4 - 2
  • Level 5 - 3
  • Level 6 - 2
  • Level 7 - 2
  • Level 9 - 3
  • Level 10 - 2
  • Level 12 - 2
  • Level 13 - 3
  • Level 14 - 2
  • Level 16 - 2
  • Level 17 - 1
  • Level 18 - 2
  • Level 19 - 2
If the information was helpful to you, please give me a rating.
Thanks.
OpenSource13
Apr 18, 2009 | Sony PlayStation® 3 (60 GB) Console
Washing Machines Logo
Top Washing Machines Experts
