Question about LG Washing Machines
My LG direct drive dish washer. There is a flashing asterisk by the Power button and will not begin the cycle.
    Sergeant:
  • LG Expert
  • 448 Answers
Food plugged up pump poss. broken glass in pump
Posted on Dec 22, 2016
  • 101 Answers
SOURCE: LG Intello washer won't initiate
check the door switch, the machine doesn't see the door closed that is why it wouldn't go into the wash cycle.
Posted on Apr 21, 2008
  • 10865 Answers
SOURCE: My Bosch washer will not
Hi. I can help you. THe problem may be in the door switch itself.
Door switch The door switch is important because, if it's defective, the dishwasher won't work at all. To reach it, you need to remove the control panel cover, or sometimes the interior liner of the door. If it's defective, you need to completely replace it.
Wiring Often the main wiring connection from the house, at the dishwasher, burns and breaks the connection. If that's the problem, the wires must be repaired/replaced as necessary. If that's not the problem, check the wiring to the door switch, the wiring between the door and the lower part of the dishwasher, and the wiring to the timer. Repair any broken, burned, brittle, or defective wiring, using the proper appliance-grade wire and connectors.
Timer or selector switch Although it's uncommon, the timer or the selector switch may be defective. If so, you need to replace the defective part, because neither of these can be repaired.
Posted on Aug 28, 2009
57 varieties
  • 1653 Answers
SOURCE: Ariston A1436 The machine begins to fill then empties and fails
Make sure that the top of the waste water pipe is at the correct height for the machine, typically around 30-34 inches from the floor (see your installation instructions). If it is any lower then it will start a siphoning action as soon as the water reaches the same level in the machine and never actually fill up and hence the cycle will not start. If the machine detects that insufficient water has entered the machine within a given time, typically 8 minutes, then if flags an error to the on board controller. If the error persists after the waste pipe height is corrected then check out the pressure switch for correct operation as if this is not triggered then the cycle will also not start or will halt almost immediately.
Posted on Oct 25, 2009
richroth
  • 9472 Answers
SOURCE: pushed start button to begin
If the door fails to lock after six (6) attempts "Fdl" will display. The "Fdl" error code indicates the door failed to lock or the control does not detect the door being locked. The likely failure is the door lock mechanism. There is always a chance there could be a loose wire connection between the door lock mechanism and the Central Control Unit (CCU) causing the error too.
Posted on Apr 25, 2011
SOURCE: Start button blinks; won't empty; won't leave wash cycle
turn your dailer to spin cycle
Posted on May 21, 2012
My lg washer when pushing power on , cl starts flashing on the clock. Washer will not start.
this usually means that the child lock is activated. it is usually deactivated by pressing two buttons together, this should be mentioned in your instruction manual.
Oct 07, 2016 | LG Washing Machines
What is the button combination to put the LG washer in test mode?
i believe it is the power button along with the two center buttons on the right.
Mar 30, 2015 | LG WM2701HV Front Load Ultra Capacity...
I have a ADP5000MT, when I start a cycle it begins but after 5 mins switches to the bottom option - the =30''V symbol button and keeps flashing .. I cant find my manual
CODES: The Express program light Keeps flashing quickly
MEANINGS: Longer inlet time
Possible Cause: Faucets is not opened, or water intake is restricted, or water pressure is to low.
Jan 16, 2013 | Whirlpool Dishwashers
I have recently changed my dishwasher over from a direct hot water pipe into the dish washer, to a cold water pipe but the temperature lights keep flashing and then the cycle, which has barely begun,...
A dishwasher requires a hot water line to operate properly. The dishwasher is indicating the water is too cold to even begin a cycle.
Charlie
Jan 09, 2011 | Dishwashers
Need remote code for LG 32lcd350 TV for dish 3.0 remote
Hi there my name is Kimberly Escobar with DISH Network Customer Support. I understand you need the codes to program a DISH Network remote model 3.0 to an LG T.V. Some of the codes we have are 678, 506, 520,123, 000, 512, and 213. To integrate the code into the remote you would need to press and hold the clear T.V button at the top until all the other top buttons light up in red, then once you see them light up you would need to enter one of your codes followed by the pound key (#) for example if you choose code 678 it would be 678#. After you press pound the T.V button will flash in red 3 times after that try the remote and make sure it functions with your T.V. I hope this is helpful to you. You can also view this link http://www.dishnetwork.com/SupportSection/power-scan-instructions which contains information on how to program your remote to your T.V using a different procedure. If you have any additional questions or concerns please feel free to contact us directly at 1800-333-DISH thank you.
Sep 05, 2010 | DISH Network IR Remote Control
Screen flashing "LE" and will not finish spin cycle?
You MUST use "HE" (High Efficiency-Low Suds) type detergent--but to use the correct amount.
Nearly all brands of "HE" detergent have incorrect instructions.
The correct amount is as follows:
HE: (2) Tablespoons Per Washload
HE 2X (double concentrated) : (1) Tablespoon
HE 3X (triple concentrated): (1) Teaspoon
This reduces/prevents:
1) Musty Odor
2) "LE" Error/Interrupted Cycle
3) L-O-N-G Cycle Times (longer than time displayed)
4) Insufficient Cleaning Results
5) Small Water Leaks from the air vent behind the washer or at the
front door gasket
6) Damaged Hall Effect Sensor (on 2007 or older LG washers)
7) Reduced Spin Speeds (laundry not spin-dried effectively)
Most consumers were doing what is *normally* the right thing to do, which is to follow directions on the detergent label. In this rare case--those directions should be entirely disregarded.
Additionally--in many LG washers--the liquid dispenser cup (blue cup) has a "MAX" line on the white siphon cap.
This was a very big *faux pas* on LGs part--this "MAX" line has NOTHING to do with measuring detergent and should never be used as a guide for determining correct detergent amount.
The "MAX" line indicates how much liquid must be in the blue dispenser cup before it DISPENSES from the bottom of the cup.
This is a very,very frustrating mistake that gives owners much grief.
After three months of incorrect type of detergent or incorrect amount of the correct detergent used--musty odor begins to occur.
After more than two years--a significant amount of soap scum/curd has accumulated in the washer. Odor-causing bacteria flourishes on this build-up.
It is imperative to remove this slimy residue. Tide sells a product called "TIDE WASHING MACHINE CLEANER" which is very effective.
Once a tub has become heavily contaminated--normal methods of performing a TUB CLEAN cycle won't "cut it".
Add the entire packet of "TIDE WASHING MACHINE CLEANER" directly into the tub (no laundry) and close the door.
Press and hold: SPIN SPEED & SOIL LEVEL buttons--then press POWER button.
Wait for door to lock.
Press the START button (6) times--this will fill the tub with hot water to the maximum setting when it stops filling.
Press the START button two more times--this will enable the tub to tumble.
After 3 hours--turn "off" the washer.
Turn the washer back "on".
Select the shortest wash cycle (usually "quick wash") and press "START". This will rinse out the tub.
This method of "TUB CLEAN" is *not* from a service manual but has been the best method for cleaning out LG washers more than a year into incorrect detergent useage.
After this--use the correct amount of "HE" detergent & perform a "TUB CLEAN" cycle every (4) months using the *tub clean* option on the control panel.
Most digital-controlled front load washers have a software feature that consumers are unaware of.
If excess suds is detected by the MAIN BOARD (which monitors motor electrical load during rinse & final spin) the "suds kill mode" will be enabled.
This causes the washer DISPLAY CLOCK to stall.
The washer makes an attempt to reduce/remove suds--usually a futile attempt--and ends the cycle much longer than was originally shown on the DISPLAY.
May 24, 2010 | LG WM-2277HW Front Load Washer
Lg wm3677hw the le error code, how do I repair
Some of my notes:
When you press the "SPIN SPEED" button and "SOIL LEVEL" button the water level frequency should be above 246. If it be below that number find the small tube going to the control and blow it out. Get rid of the sediment in the air bell and reconnect tightly. Pump out water and retry.
Hall sensor failure:
When too much of the low-sudsing HE detergent is used in the LG washers (and especially non-HE type detergent)...
The motor & main board will detect suds when the tub begins to spin.
As strange as this sounds--suds causes drag/resistance.
The older hall sensors overheated--the main board would shut-down the washer & flash an error message of "LE".
If the Hall Sensor was not damaged--then the customer would be able to unplug the washer for about 2-3 minutes and plug in the washer again--the washer would be able to be re-started (reboot of the computer).
Eventually--this results in an "LE" error that won't re-set and the Hall Sensor needs to be replaced. The tell-tale symptom of this (aside from a "stuck" LE error) is that when the customer pushes the START button--the tub *wiggles* momentarily before flashing LE again.
On a few occasions--the washer WILL start but the motor GROWLS loudly.
It's very important not only to use "HE" (High Efficiency-Low Suds) type detergent--but to use the correct amount.
Nearly all brands of "HE" detergent have incorrect dosage instructions.
1) Musty Odor
front door gasket
This method of "TUB CLEAN" is *not* from a service manual but has been the best method for cleaning out LG washers more than a year into incorrect detergent usage.
LG washer repair manual
Apr 05, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Lights flashing at end of cycle, dishes not clean
I switched it off at the wall and left it for a minute and set the dial to Stop and then set it again from the beginning and so far it has been fine. Thanks, DCD
Oct 02, 2009 | Miele Dishwashers
Noise
lets begin
1.-Unplug washer or disconnect power.
2.-Check drive motor.
3.-Check drive belt.
4.-Check wire harness connections.
5.-Plug in washer or reconnect power.
6.-Check the MCU by looking for operations of the drive motor
in both directions.
was this helpful?
May 09, 2009 | Kenmore HE2 Plus Front Load Washer
Whirlpool dish washer du931scgb1
This is the symptom of defected timer motor is need to replaced..
Hope this may help;
Regards,
VOTIT
Aug 01, 2008 | Dishwashers
Washing Machines Logo
35 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
