Vacuums Logo
A
Anonymous Posted on Dec 15, 2016
My hoover 5050ed wont turn on at all? Can you please help? Is there a trip switch or something!
My hoover dual pro carpet clean was running i lefdt it running for about 3 min while i was moving something it died and now it wont turn on
Does the vacuum cleaner smell 'burnt'? Vacuum cleaners require servicing from time to time (disassembly, inside casings blown out with compressed air, filters either cleaned or replaced - even more so with bagless vacs like the Dyson). As this is a washer there are extra complications like shafts and bearings rusting and seals wearing out to the point where they freeze up, which will trip thermal protection relays etc to stop it from doing catastrophic damage. You might be able to disassemble the vac, clean it up, give the bearings and shafts a liberal spray with something like WD40, reassemble it and hope for the best*. If you aren't game enough then I'd advise you to take it into a shop unless it's under warranty which means you're covered for repairs/replacement.
*This is mains powered device and there are safety risks involved.
My Hoover Duros (blue color, S3000 something model with the power brush) worked fine for 3 years, than it died. The other day I couldn't turn it on... What can it be? A fuse? Where's is the fist in...
manual > http://hoover.com/file/682/
To reset the breaker:
(1) Push the ON/OFF switch
http://hoover.com/file/682/completely
down. You will feel some
resistance when the switch moves
downward. The switch will also move
slightly upward on its own.
(2) Wait one minute.
(3) Repeat step 1.
(4) Turn the cleaner ON and continue
cleaning.
If the brushes continue to stall and
the breaker trips again, clean the
brushes to remove debris. (Figs. 4-1
through 4-4)
To reset the breaker:(1) Push the ON/OFF switch
completely
down. You will feel someresistance when the switch movesdownward. The switch will also moveslightly upward on its own.(2) Wait one minute.(3) Repeat step 1.(4) Turn the cleaner ON and continuecleaning.If the brushes continue to stall andthe breaker trips again, clean thebrushes to remove debris. (Figs. 4-1through 4-4)
Jul 28, 2013 • Vacuums
Wont turn on
this link is for the manual go to page 12 for troublshooting it could be seversl thing that are quite easy to check,
Hoover spirit 900 canister wont turn on?
see this causes and fix it. God bless you
If the vacuum cleaner motor does not run the motor itself might be burned out. Check the power switch first to be sure the motor can get power. Then, be sure the motor shaft can turn freely, that nothing is obstructing it. If the motor can turn freely and is getting power but still won't run it will need to be replaced
If the vacuum cleaner motor doesn't run the on - off switch might be turned off or defective. Test the switch with an Ohm meter or continuity checker.
I was vacuuming and it just turned off. I found a clog from something it picked up. I removed it, but it won't start. Is there some time of fuse that tripped?
Hi, there is probably a reset button on the machine that kicks out when it overheats. Check that first.Please lt me know, Chris
1helpful
Telios 2000
This is normally caused by restricted airflow, causing the heat sensor switch to trip. Please make sure the hose and bag are not clogged, verifying you have good suction and airflow to the hose end when you initially turn it on. The heat sensor switch is intended to shut off the motor if sufficient cooling air is not present.
My Sebo hoover trips the house mains sockets every time I switch it on, yet doesn't trip the kitchen mains. Have replaced filters/bag to reduce load but still no good. What should I be investigating in the...
It sounds like your vacuum is fine if it works when plugged in the kitchen outlet. It is tripping the breaker switch in the other room because the circuit is overloaded (too many things plugged in this circuit). Try unplugging some things in that room and try your vacuum again.
If it only trips when using one particular outlet, then the outlet should be replaced. I would recommend having an electrician check your wiring out.
Hope this helps
2helpful
2answers
Agitator brushes wont turn even after cleaning
the brushes will not turn even wen the switch is turned on
Spin brushes wont spin and the switch wont turn machine off. I have to unplug it.
for the spin brushes it is most likely the motor is fried if you smell something burning it could be jammed or the wires have be shaken off the motor terminals. for it not turning off you need a new switch.
2answers
Henry Hoover throwing trip switch in house
Sounds more likely to be the switch than the motor, especially if it is the model with the top switch rather than the side "rocker" switch. If you are in the UK, speak to the technical people at www.a1cleaningsupplies.co.uk they can post a replacement. Otherwise outside or even within the UK you can contact the manufacturers technical people. Website is www.numatic.com
Top Hoover Vacuums Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
