Question about Vacuums
What is the formula to figure how much water is in a ractangular fish tank
    Top Expert:
  • Vacuums Master
  • 50,566 Answers
The volume formula is what is used to determine the amount of water in a tank
that is length X width X height (depth) that determines the cubic capacity or the tank
now 1 cubicft = 7.48 gallons
so as an example-- a fish tank 3ft X2 ft X 2ft = 12 cubic ft =12 X 7.48 = 89.76 gallons
Posted on Dec 15, 2016
  • Geoff White
    Geoff White Dec 15, 2016
    In some countries 1 cu ft contains 6.23 gallons
  • Bill Boyd Dec 15, 2016
    what ever--- the formula to calculate the volume is still the same
    some countries have not yet moved to the metric system where there is no problem allowed as it is just the one measure of liters or 1/10 part of liters
How do you put the soultion in and how do you use it
Here is link to the users manual:
http://www.bissell.com/assets/0/132/134/228/14489708-7c37-4678-a90a-79e6825ef104.pdf
but real quick, heres the essentials:
Fill the SmartMix/formula tank
Lift the formula tank up and out of the machine base.
Fill the formula tank
by first unscrewing the cap
and insert. Always use genuine BISSELL formulas
to maximize cleaning and for the safety of your
machine. Fill formula up to the line and replace the
cap and insert. Place formula tank into the slot in the
back of the machine for a snug fit.
2b.
If using the BISSELL 3X Concentrated Fiber Cleansing
Formula: Add 3 capfuls of 3X Concentrated Fiber
Cleansing formula to the formula tank, and then fill
with warm water to the line.
Note: If bottle leaks, check for proper positioning
of red gromment and straw insert.
Good luck and thanks for using FIXYA
Please rate us if you are happy :)
Apr 06, 2011 | Bissell 1697-7 Powersteamer Pro Deluxe...
FHow much solution goes in first?
The tank is labeled. Take the clean/solution tank off the vacuum by lifting it straight up. Unscrew the black cap on the bottom of the tank and remove the bottle insert. Add 8 oz of the Little Green formula (this gets you up to the Formula fill line). Then add hot water to the water fill line. Replace the bottle insert and tighten the black cap. Then replace the clean/solution tank by lining the indentations up with the vertical guides on the left side of the unit and sliding it straight down. Please note that the bottles of the formula come in 32 oz or 64 oz bottles. So you can expect one of the smaller bottles to last 4 fill cycles.
I hope this helps.
Oct 07, 2010 | Bissell THE BISSELL LITTLE GREEN MACHINE...
I have a Bissell Proheat 2x cleaner which has worked perfectly on every occasion. Today I filled the machine as usual with water and formula and switched on, the motor ran, the lights were on and the...
Please check the following with liquid in both tanks.
- Check to see if the machine will spray through the hose with the setting on tools. If it does, the pump is fine. Continue troubleshooting.
- Check for debris on spray tips. Clean them with a soft brush (on old tooth brush works well). The spray tips may be lifted out for easier access.
- Ensure the tank lid is properly attached to the bottom of the tank. To attach this properly, remove the Water Tank from the machine. Hook the front window onto the lip of the bottom container and then allow the window with lid to cover the complete tank. Secure the latch on the back of the bottom tank to the back of the tank lid. THE TANK LID CANNOT BE ATTACHED PROPERLY IF THE BOTTOM TANK IS ALREADY INSTALLED IN THE MACHINE.
- Check the bottom of the Water Tank and the Formula Tank to make sure each has a red auto-load gasket attached. Make sure the Water Tank and the Formula Tank are seated properly. Depress the x on this gasket to ensure this depresses and release back out. Liquid from the tank should dispense.
- Remove the handle completely and re-attach. Once the handle is re-attached, re-attempt to spray.
If the machine continues to not spray, check the following:
REMOVE THE COLLECTION TANK:
• Make sure the unit is set to water rinse
• Remove the smart mix bottle and fill it with water only
• Place the smart mix bottle into the collection tank reservoir
• Run the unit and try to spray. If the machine sprays, you will be able to see the water level decreasing in the smart mix bottle and you will need to replace the bottom tank. It is possibly warped.
If these suggestions do not resolve the issue contact BISSELL Consumer Services.
1-800-237-7691
Mon-Fri: 8am to 10pm ET
Sat: 9am to 8pm ET
Sep 27, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
We cannot get the water and soap to dispense in out Bissell steamcleaner
Check to ensure there is liquid in the water tank and the formula bottle.
Note: This machine will spray with liquid in the Water tank only if the machine is set to the Water Rinse setting. On any other setting, you need to have liquid in the formula tank as well.
If no: add liquid to the Water tank and the Formula tank.
If yes: check each of the following....
-If everything is seated and attached properly, prime the machine by turning off the power, waiting one minute, and then turning the power back on and depressing the trigger on the handle.
- If priming the unit fails to fix the problem, remove the handle completely and re-attach. Once the handle is re-attached, re-attempt to spray.
Aug 13, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Pressing the handle to release cleaning solution does nothing. The cleaning solution does not come out. Carpet is dry.
If your machine continues to not spray, please take your machine to a local BISSELL Authorized Service Center for inspection and repair. BISSELL provides you with a one year warranty for any defective or malfunctioning part.
To locate your nearest BISSELL Authorized Service Center, go to www.bissell.com. Click on the Customer Support tab near the top of the homepage and enter your zip code in the Service Center locator box to perform your search.
You can also locate a Service Center by phone, 24 hours a day, by calling 1-800-237-7691 and choosing option #1.
Aug 03, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
My bissell steam cleaner will not spray any water
Jun 15, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
I have the Bissell heat pro 2x 8920 and the water doesn't come out. The soap just mixes with water tank and the carpet stays dry
Jun 14, 2010 | Bissell 8920 ProHeat 2XTM Upright Vacuum
Hi! I am borrowing this cleaner from a friend,
No, it just might need a new pump belt. When the belt is worn it won't dispense water or solution. Here is the belt you need:
Bissell 1699 Belt
Jan 07, 2010 | Bissell 1699 ProHeat Clear View Upright...
I have misplaced the directions for the Bissell powersteamer powerbrush. I need the directions for filling the u tank etc.
Release the handle and lay the machine handle
back to access the Tank.
2. Remove the Tank from the base of the machine by
lifting the Tank carry Handle.
3. Carry like a bucket to the sink. Rotate the Handle
forward to unlatch the lid. Lift off and set the lid aside.
4. Fill up the Bladder with clean hot tap water.
*Do not boil or microwave water as it can
destroy the Bladder.
5.
Replace the top of the Tank by matching the lid
and tank edges. Handle must be in the forward
position in order to replace lid. Rotate the handle
to the carrying position to latch the lid.
Note: Remember to secure the lid and test to
make sure it is secure before picking up the Tank.
6.
Place tank into machine base, seating firmly in place.
Rotate tank handle back into latched position. Bring
machine handle back into upright position.
1.
Lift the formula Tank up and out of the machine base.
2. To fill the Formula Tank, first unscrew the Cap
and Insert. Always use genuine BISSELL formulas
Cap and Insert. Place Formula Tank back into the
base of machine, making sure it is seated securely.
of red gromment and straw.
Apr 29, 2008 | Bissell 1699 ProHeat Clear View Upright...
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
