Question about Miele Coffee Makers & Espresso Machines
Miele cva3660 capsule plate replacement,where to purchase at reasonable cost
Miele H 4080 Microwave mica diffuser plate
http://www.amazon.com/Amico-Microwave-Repairing-Plates-Sheets/dp/B00880DAB0
Oct 19, 2013 | Miele M613GSS 800 Watts Convection /...
What is a miele cva 2650 descaling funnel
The descaling funnel is a small, dull red insert that replaces the capsule holder and is used during the descaling cycle. I purchased a used CVA2650 that came without the funnel. I called Miele concierge service for help. They stock the descaling funnel and sell it for $15.95. In my case, they simply mailed one at no charge without me even asking. Great customer service!
May 10, 2012 | Miele CVA2650 Stainless Steel Espresso...
My Nespresso Magimix Citiz does not pierce the capsules every time. I use only Nespresso capsules. I have tried to pass them through a second or third time when this happens but I have thrown too many...
-the short term solution-
1. take your affected capsule. set it on its un-punctured/un-perforated bottom (the thin foil surface) on a flat surface. the three puncture holes should be facing upward on the top of the capsule. by the way, if you shake the capsule you should hear the grounds sound dry as if the capsule was new.
2. find a thin small rubber band. size-wise, ideally, the rubber band will fit loosely around your thumb; with a very small gap between the rubber and your thumb.
3. put the rubber band around the collar of the capsule. the band should be put over the top of the capsule and pushed down until it stops flush against the flange (rim). if the band is correctly placed, the band will be just 1mm flat inside the rolled bare aluminum edge (rim).
4. insert the capsule in your citiz machine as usual. optional: you can orient one of the puncture holes at 12 o'clock position (top dead center) during the insertion process. this time, it will work. you will find the capsule will eject cleanly with the rubber band intact.
5. save the rubber band.
-which machines does this apply to?-
this is a common problem with nespresso machines introduced after 2010, specifically the citiz. i have not seen this problem on the pixie, yet. i would expect this issue on the lattissima plus.
i am assuming that the machine is otherwise functioning properly: meaning that the machine does not have an issue with the water pump, excessive scaling deposits restricting water flow, or some other major mechanical part.
-why is this happening?-
look at the capsule, the post-2010 machines bite new slightly rectangular indentations on the capsule around the top edge of the wall. this is new. nepresso changed the insertion mechanism in response to competitors bringing non-nespresso branded capsules to market: Douwe Egberts/Sara Lee "L'or expressO", Caffe Vergnana "ESPRESSO", etc.
this new insertion mechanism was supposed to thwart knockoff capsules, instead it is unintentionally thwarting your "real" nespresso capsule. the injector needles are not piercing correctly all the way. the injectors poorly lodge: deep enough to make puncture holes but not deep enough to allow water to flow freely into the espresso grounds compartment.
two things can happen:
1. the pressure release valve, inside the brewing chamber which prevents an explosion occurring if the coffee exhaust path becomes blocked, is activated and hot water overflows into your used capsule basket.
2. the hot water flows outside and around the capsule and into your cup as clear hot water.
-what do i do long term?-
contact nepresso. get your machine repaired or replaced. this is a factory manufacturing defect that has nothing to do with you, wear, use, or hard water. refuse to pay the $125 repair fee. demand that they fix the machine free of charge. they will send you a loaner in a plastic shipping crate to use while your is being fixed. you should not have to suffer without espresso or waste legitimately purchased capsules just because nespresso is in a legal fight capsule copycats. this is not your fault.
Mar 02, 2011 | Nespresso C100/T-US-AERO Espresso Machine
After 4 years they found out that they have to change tha plate at the back and the compressor.Is it right so soon to have such a problem and the cost is 550EURO.SHALL I FIXED IT OR BUY ANOTHER ONE BUT NO...
Miele should be one of the best but better replace the unit. Once they get worked on it might break down again in the near future. Save yourself the headache
Sep 30, 2017 | Liebherr European Right Hinge Fully...
CAN I RESET THE CAPSULE COUNT ON MY MIELE CVA 2660 COFFEE SYSTEM.IT IS SHOWING 3798 -CAN I GET IT RESET TO ZERO ?
No, Not without replacing electronic. You can only reset descale counter in service mode. All other counters are not resettable.
Mar 22, 2010 | Miele CVA2660 Stainless Steel Coffee Maker
Capsules jammed fault 72
I pulled out the pod carousel, and reached by finger over the capsule tray hole. In there was a stuck pod. Once I go that out, I power cycled the machine and all was well.
Mar 03, 2010 | Miele CVA2650 Stainless Steel Espresso...
Fault f72
this is usually due to the hinged part of the capsule plate failing to return to the normal resting position after ejecting the first capsule. You can resolve this problem by occasionally pulling the capsule plate out of the unit and running it through the dishwasher. You can also scrub it with a toothbrush under hot soapy water. Coffee stains build up on the mechanism preventing the plate from dropping to the rested position. The second capsule hits this and jams rather than riding the ramp into the puncture plate.
Feb 21, 2010 | Miele CVA2650 Stainless Steel Espresso...
My machine has died and is showing with error code F 73. I can't find a reference to this error code anywhere. Any idea what this means?
I have had this too...
Try this:
turn off the power (inside opening front) & remove the carousel & runners then the waste container & then the capsule plate.
clean area inside where capsule plate comes from & reassemble everything, that usually clears the problem -if it is only happening once in a while.
Dec 28, 2009 | Miele CVA2660 Stainless Steel Coffee Maker
Coffee Makers & Espresso Machines Logo
35 people viewed this question
Top Miele Coffee Makers & Espresso Machines Experts
just-ice
Michael Galve
Michael Galve
Colin Stickland
Colin Stickland
Are you a Miele Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
