Question about Coffee Makers & Espresso Machines
Cva 3660 f73
Capsule stuck in down position capsule plate stuck
5 Suggested Answers
  • 70 Answers
SOURCE: CAN I RESET THE CAPSULE COUNT ON MY MIELE CVA 2660
No, Not without replacing electronic. You can only reset descale counter in service mode. All other counters are not resettable.
Posted on Apr 01, 2010
  • 10865 Answers
SOURCE: The part where you put the capsule in on my
Hi Rachel. Chances are that you need a new capsule. Go to this site to get what you need http://www.espressocartridges.com/index.php?main_page=index&cPath=5
J.
Posted on Sep 04, 2010
  • 6 Answers
SOURCE: the capsule lock system does not make holes in the capsule
-the short term solution-
1. take your affected capsule. set it on its un-punctured/un-perforated bottom (the thin foil surface) on a flat surface. the three puncture holes should be facing upward on the top of the capsule. by the way, if you shake the capsule you should hear the grounds sound dry as if the capsule was new.
2. find a thin small rubber band. size-wise, ideally, the rubber band will fit loosely around your thumb; with a very small gap between the rubber and your thumb.
3. put the rubber band around the collar of the capsule. the band should be put over the top of the capsule and pushed down until it stops flush against the flange (rim). if the band is correctly placed, the band will be just 1mm flat inside the rolled bare aluminum edge (rim).
4. insert the capsule in your citiz machine as usual. optional: you can orient one of the puncture holes at 12 o'clock position (top dead center) during the insertion process. this time, it will work. you will find the capsule will eject cleanly with the rubber band intact.
5. save the rubber band.
-which machines does this apply to?-
this is a common problem with nespresso machines introduced after 2010, specifically the citiz. i have not seen this problem on the pixie, yet. i would expect this issue on the lattissima plus.
i am assuming that the machine is otherwise functioning properly: meaning that the machine does not have an issue with the water pump, excessive scaling deposits restricting water flow, or some other major mechanical part.
-why is this happening?-
look at the capsule, the post-2010 machines bite new slightly rectangular indentations on the capsule around the top edge of the wall. this is new. nepresso changed the insertion mechanism in response to competitors bringing non-nespresso branded capsules to market: Douwe Egberts/Sara Lee "L'or expressO", Caffe Vergnana "ESPRESSO", etc.
this new insertion mechanism was supposed to thwart knockoff capsules, instead it is unintentionally thwarting your "real" nespresso capsule. the injector needles are not piercing correctly all the way. the injectors poorly lodge: deep enough to make puncture holes but not deep enough to allow water to flow freely into the espresso grounds compartment.
two things can happen:
1. the pressure release valve, inside the brewing chamber which prevents an explosion occurring if the coffee exhaust path becomes blocked, is activated and hot water overflows into your used capsule basket.
2. the hot water flows outside and around the capsule and into your cup as clear hot water.
-what do i do long term?-
contact nepresso. get your machine repaired or replaced. this is a factory manufacturing defect that has nothing to do with you, wear, use, or hard water. refuse to pay the $125 repair fee. demand that they fix the machine free of charge. they will send you a loaner in a plastic shipping crate to use while your is being fixed. you should not have to suffer without espresso or waste legitimately purchased capsules just because nespresso is in a legal fight capsule copycats. this is not your fault.
Posted on Dec 26, 2011
SOURCE: can not remove capsule and lever stuck
I had a similar problem, and it was down to high pressure remaining in the machine preventing the lever from releasing. You can test this by pressing the capsule in the machine (which will be much more solid than normal).
To fix, all you need to do is make a hole in the stuck capsule. I did this by drilling a small hole in the side of the capsule.
That releases the pressure (and a little spurt of coffee!), and the lever will release.
Posted on Apr 21, 2012
DeLonghi Nespresso U not puncturing capsule
Not a fan of nespresso, a lot of cheap plastic. I am guessing the pivot for the capsule puncture arm has worn out allowing some play in it, which is keeping it from closing all the way just a guess, but it is an issue I have fixed before.
May 02, 2013 | DeLonghi Coffee Makers & Espresso Machines
Can not remove capsule and lever stuck
Mar 10, 2012 | Krups Dolce Gusto KP 2100 Espresso Machine
Nespresso capsules falling through
IS THE PISTON MOVING /ARE YOU PRESSING THE CAPSULE TO MUCH DOWN WORDS ?
Mar 09, 2012 | Nespresso Citizmilk D120
When i put in the nespresso cup in the Citiz and close it nothing happens. Ussually it should make holes in the cup so the coffee can come out. But there are no holes when i open it again. So i can not...
Jun 08, 2011 | Krups Coffee Makers & Espresso Machines
My Nespresso Magimix Citiz does not pierce the capsules every time. I use only Nespresso capsules. I have tried to pass them through a second or third time when this happens but I have thrown too many...
Mar 02, 2011 | Nespresso C100/T-US-AERO Espresso Machine
My Citiz is not puncturing the front (waffled) section of the capsule and is not brewing.
Feb 21, 2011 | Nespresso Citiz C110
With our nespresso machine, when you place the capsule inside & press the button the water runs through the inside of the machine where the plexiglass basket for the empty capsules are
Feb 04, 2011 | Nespresso Citizmilk D120
CAN I RESET THE CAPSULE COUNT ON MY MIELE CVA 2660 COFFEE SYSTEM.IT IS SHOWING 3798 -CAN I GET IT RESET TO ZERO ?
Mar 22, 2010 | Miele CVA2660 Stainless Steel Coffee Maker
Fault f72
this is usually due to the hinged part of the capsule plate failing to return to the normal resting position after ejecting the first capsule. You can resolve this problem by occasionally pulling the capsule plate out of the unit and running it through the dishwasher. You can also scrub it with a toothbrush under hot soapy water. Coffee stains build up on the mechanism preventing the plate from dropping to the rested position. The second capsule hits this and jams rather than riding the ramp into the puncture plate.
Feb 21, 2010 | Miele CVA2650 Stainless Steel Espresso...
The capsule lock system does not make holes in the capsule
Oct 09, 2009 | Nespresso Le Cube
Coffee Makers & Espresso Machines Logo
26 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
