Question about Rinnai Heating & Cooling
POWER SUPPLY REQUIRED FOR RANNAI HEATER - Rinnai Heating & Cooling
Cant light my heater rannai reh 18 p
I would suspect the gas valve is defective.
Dec 08, 2016 | Heating & Cooling
What kind of propane regulator do I need for my RL 94 rannai?
That is a water heater or boiler? You need to contact a gas service contractor. It would be dangerous to do it any other way as the gas pressure needs setting.
May 03, 2016 | Grilling
My rannai propane heater makes a whistling sound.
Check the fan. Unplug the unit and remove the panel that houses the fan unit. Electrical cleaner can be sprayed onto the connection points of the nicad heater elements as well as the fan motor. It may be that one of the heating coils has a bad connection. Take apart and reassemble heating elements and connection points.
Jan 17, 2015 | Heating & Cooling
Would high winds and rain cause pilot light on a rannai tankless water heater to go out?
Yes.
High winds can cause reversal of air flow down vent pipe causing pilot flame to blow out.
If situation happens frequently, then special roof cap has to be added.
Have plumber check natural draft up vent pipe.
Other things can cause same problem, for example if vent fan is located in same room as water heater, or house is tightly insulated, and vent fan is ON, then it will draw air down the water heater vent and blow out pilot.
http://waterheatertimer.org/pdf/Bosch_Checking_the_draft.pdf
Oct 29, 2012 | Water Heaters
I have a Rannai 2001 heater which was working well, it is getting power as you can see and hear the igniter trying to light the pilot light which is no coming on. so it is not lighting the heater as there...
Make sure you have not run out of gas first if you are on LPG bottles. Sounds silly but it happens alot.
If the gas is ok they you are likely looking at a problem which would need to be looked at by a decent service technican. Try the Rinnai NZ website, I'm sure they have a helpline and might have a list of service agents. Otherwise ask at any local plumbing or heating shop. Sorry can't help much more.
Aug 16, 2010 | Heating & Cooling
No hot water from bosch tankless heater
  1. If the display is blank, verify power to electrical outlet. (120VAC/60Hz properly grounded circuit required). Verify that the heater on/off switch is in the on (I) position.
  2. Verify the fuses in the control unit are good.To access fuses, the control unit must be removed. See BULLETIN TWH-G2-24 Two spare fuses are located inside lower access panel of control unit.
  3. Make sure cold water inlet connection is plumbed to the right side of heater when facing unit.
  4. A minimum of 0.8 gallons per minute (GPM) (3 l/m) is required to activate the heater. A quart container should fill in 20 seconds or less to activate heater.
  5. Clean inlet filter screen per chapter 5.2. of the installation manual.
  6. Inspect the water path for obstructions. Make sure all showerheads, faucet aerators and whole house filters are clear of debris.
  7. The heater activates when the water flow through the unit is at or above the required minimum of 0.8 GPM (3 l/m). A crossover creates back pressure on the water flowing through the heater. Therefore, a higher flow rate than normal is needed to force the heater to activate. To check for a plumbing crossover, shut off the cold water supply feed to the water heater. Then open all of the hot water taps served by the heater. Wait 10 minutes and check for water flow at taps. There should be no water flowing. Any continuous flow of water indicates a crossover is present and must be corrected. Consult a professional plumber for help in correcting a crossover. Failing single lever faucets and mixing valves are common causes of plumbing crossovers.
  8. With the ON/OFF switch turned to OFF (O) position and the power supply cord unplugged, remove theunit's front cover (See Page 5. Fig 3 of installation manual). Check wire connections between the water valve, control unit and electrode set. See chapter 9.2 of installation manual for location of these parts.
Feb 14, 2010 | Bosch & Tankless LP Hot Water Heater
Can a Rannai RCE329A vent free wall unit be vented?
Sorry, no. The UL rating of this unit specifies "Unvented Installation Only".
Jan 18, 2010 | Rinnai Vent Free Gas Heater/
Rannai 2520
This is a water heater not a heater, sorry. Remove the ignition probe just below a small window and adjusst the gap after polishing the probes. Make sure all wires are connected good. Test fire unit.
Dec 19, 2009 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Blow off periodically releases small amt of water.
This may be the case. If you have a check valve installed on the heater to prevent the hot water from backing up into the inlet or cold water side this may happen. A hot water expansion tank at the heater or water hammer devices near the fixture itself should cure the problem.
One question, how high is you water pressure?
Dec 01, 2008 | Rinnai Webstone The isolator EXP tankless...
Rannai function lock
Have you tryed unlocking it by holding down on the lock button for 5-6 seconds?
Oct 11, 2007 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Heating & Cooling Logo
26 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
