How to clear please wait in dialta di2510 - Office Equipment & Supplies
Dialta di2510 not initializing
Unplug it from the wall, wait a while and plug it back in. If still not booting, Probably needs to have the firmware reloaded,or all the dimms (memory chips) need to be reseated, or the main board has failed. If you are not a tech, probably should call one.
Sep 02, 2014 | Konica Minolta Dialta Di2010 2510 Toner 2...
How to install Minolta dialta Di2510
Go to Konica Minolta Web site can use only windows 95 best is XP. If there is Windows 7 Go for it. This a legacy Minolta machine
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Aug 24, 2014 | Konica Minolta di-2510 AFR-19 AFR19 ADF...
You must download the drivers from Konica's support website at the following link: http://kmbs.konicaminolta.us/wps/portal/web/home/home/businesssolutions
At the top of the page click on downloads
A new window will pop up for product self help support.
Type your model number Di2510 into the quick search box on the left side of the page and a link will appear to the drivers and documentation for your model.
Aug 24, 2014 | Konica Minolta Office Equipment & Supplies
Di2510 toner bottle is not rotating
must have the block that turns the botle toner it works well
remove the toner click on f8 and watch the block rotates or not
Jun 01, 2014 | Konica Minolta DiALTA Di183F Copier
Di2510 hard drive
Rear of the machine remove the back cover
Nov 06, 2012 | Minolta DiALTA DI2510F All-In-One Laser...
Hello, I am having problems with a Di2510 machine. When it is turned on I get the 'Please Wait' screen, and then nothing? It just stays frozen on that message
sir, Have you had the developer and drum replaced or does the screen say Replace PC Drum? There are certain house chores the copier does before "Ready to Copy" it is waiting for them to get done equals "Please Wait". One big item is making sure the developer and toner are properly mixed inside the image unit underneath the drum. Might want to have the developer replaced and drum/cleaning blade normally done all together, then run the F8 procedure and make sure the counters where cleared Did you recently replace the drum and the developer if so did you clear the counters for the drum and developer. IF not then the copier thinks the new drum and new developer are old. Copier works on the counters that how it know it got a new drum and developer. Get new develop and new drum and have it installed correctly, Counters are clear before the unit is yanked out of the machine, then you remove the image unit/drum unit replace the developer/drum and cleaning blade. (DO NOT USE AVACUUM CLEANER WHEN REPLACING THE DEVELOPER static electricity can destroy the sensor located below the developer unit. Then reinstall and RUN F8. Make sure the fax line and Ethernet cable is removed can't print anything until the F8 is run. Or you start over with new developer and new drum
Aug 11, 2011 | Minolta Di2510 All-In-One Laser Printer
PLEASE HELP ME WITH CODE 0910
C0910 service code means that your tray 2 is not lifting the paper properly. Most often this is caused by the tray being loaded improperly. So to try and fix this I would open tray 2 and check the loading of the paper and correct if necessary. Reset the code by turning off then on the main power from the back left side of the machine. Leave tray 2 open until the copier warms up and says ready. Then close tray 2 and wait to see if the code comes back. If it does then you have a motor lift problem or the sensor that detects the lift is bad. You can always leave tray 2 open and inch or 2 so that you can still use the copier as this will keep the code from coming on.
Good Luck and Thank You for using Fixya.
Sep 13, 2010 | Minolta DiALTA DI2510F All-In-One Laser...
How do you print double sided on a Minolta DI2510 on vista
In print properties select left binding and double side. DOES YOUR COPIER HAVE A DUPLEXER??????
Jun 29, 2010 | Minolta DiALTA DI2510F All-In-One Laser...
Minolta dialta di181 c1300 error
C1301 errors after setting up the Di181.
Solution:
Replace PWB-A, part number 1177-0106-03 for C1301.
Jul 30, 2008 | Minolta DiALTA Di181 Printer
ERROR CODE
thanks for posting the solution. it may help other users
Robert
Nov 28, 2007 | Minolta DiALTA DI2510F All-In-One Laser...
k24674
jasbo
jasbo
