Question about Rinnai Heating & Cooling
Power supply required for Rannai gas heater RC-217E
Cant light my heater rannai reh 18 p
I would suspect the gas valve is defective.
Dec 08, 2016 | Heating & Cooling
What kind of propane regulator do I need for my RL 94 rannai?
That is a water heater or boiler? You need to contact a gas service contractor. It would be dangerous to do it any other way as the gas pressure needs setting.
May 03, 2016 | Grilling
I have a 1997 prowler can't get hot water heater to light
Insects commonly get into the gas supply line just behind the lighting orifice. Try blowing out the line with compressed air. This sometimes requires disassembly of the supply line. This is assuming you have tryed the proper lighting method that the MFG instructions list on the gas device you are lighting. Also check to see if you have a electrical powered gas valve. And if you do make sure that it has power going to the valve allowing it to open when it's calling for gas.
Jan 21, 2015 | Water Water Heaters
I have a Rannai 2001 heater which was working well, it is getting power as you can see and hear the igniter trying to light the pilot light which is no coming on. so it is not lighting the heater as there...
Make sure you have not run out of gas first if you are on LPG bottles. Sounds silly but it happens alot.
If the gas is ok they you are likely looking at a problem which would need to be looked at by a decent service technican. Try the Rinnai NZ website, I'm sure they have a helpline and might have a list of service agents. Otherwise ask at any local plumbing or heating shop. Sorry can't help much more.
Aug 16, 2010 | Heating & Cooling
Can a Rannai RCE329A vent free wall unit be vented?
Sorry, no. The UL rating of this unit specifies "Unvented Installation Only".
Jan 18, 2010 | Rinnai Vent Free Gas Heater/
Rannai 2520
This is a water heater not a heater, sorry. Remove the ignition probe just below a small window and adjusst the gap after polishing the probes. Make sure all wires are connected good. Test fire unit.
Dec 19, 2009 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Replacing Old York TS to HoneyWell RTH230B
rh is hot for heating rc is hot for cooling looks to me like ya need a heat pump stat some thing to control the reversing valve.Tom
Jun 18, 2009 | Honeywell Electronic Programmable...
Is there alot of problems with bosch aquastar 2400
Bosch has had problems with these heaters for sure. They are the best known thing out there in the market.They are mostly responsible for the bad rap being given to all tankless heaters, but a big part of the problem is installation. They are being sold to homeowners at box stores as DIY kits. These are not units to be homeowner installed, venting and fuel requirements are different from regular heaters and they will not function correctly if improperly installed. I have installed several of the Rannai units over the past few years without any issue whatsoever.
Mar 10, 2009 | Bosch AquaStar Indoor Natural Gas Tankless...
Rinnai Tankless Water Heater
Question, is there any other equipment that uses propane? You indicate that the problem started after a delivery of propane after running out. If so, I suspect a blockage in either the gas train or the rinnai itself. If tou have the temperature control that regulates the water temperature, you can recall error codes to pinpoint the issue. They are optional equipment so if you can wire one in or ask your propane gas supplier if their service department has one, it will aide in the diagnosis.
Nov 22, 2007 | Heating & Cooling
Rannai function lock
Have you tryed unlocking it by holding down on the lock button for 5-6 seconds?
Oct 11, 2007 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Heating & Cooling Logo
24 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
