Question about Rinnai Heating & Cooling
Rinnai electric gas heater RC-217E imput power
My 606a rinnai heater flashes 12
According to the Rinnai manual which is here:
https://www.rinnai.us/documentation/downloads/RC-606-48x05(00)_owners_manual_RCE-606TRAII_vent_free.pdf
It looks like that is a "flame failure". They suggest ventilating the room and turning the heater off and on again, I think this might mean the heater was eating all of the oxygen in your room.
Maybe cracking a window a small bit?
Dec 02, 2016 | Rinnai Heating & Cooling
How do I operate Rinnai heater model RC-337AC-BL
I would go to www.rinnai.us and ask them for an english manual.
Jan 05, 2015 | Rinnai Heating & Cooling
I need user manual for Rinnai Fan Heater 2000 RC - 219AC
How to operate Rinnai RC-219AC Fan Heater 2000
Jan 08, 2014 | Rinnai Heating & Cooling
RINNAI R94LS CONVERT TO NATURAL FROM PROPANE
The electric water heaters have replaced the traditional of water heating. The advanced features and the latest technologies of water heater have made it so easy for everyone. Find the best electric water heater on the market today. Read electric water heater reviews and comments from experts. Almost each product is manually reviewed and tested.
Electric Water Heater List Reviews waterheaterlist com
Jan 28, 2013 | Rinnai R94LSi Tankless Water Heater...
Electical connection for ru98e
Rinnai RU98e is gas water heater with .4 gallon per minute activation.
This tankless gas water heater plugs into ordinary 120Volt 60 Hz outlet and consumes 63 watts when running.
For electric tankless:
Copy following links for illustrated walk-thru and wire-breaker size calculation for electric:
http://waterheatertimer.org/How-to-wire-Tankless-electric-water-heater.html
Oct 31, 2012 | Rinnai Water Heaters
I have a Convector 417 RC-417-80 that starts fine but after about 5 minutes stops working. Any ideas?
Steve, there are a several of basic things that can cause this problem.
1. Air filter is clogged. Turn electrical part of unit OFF, Remove and Clean Filter, if necessary.
2. Air intake obstruction. Look for air intake obstruction around the front of the heater.
3. If your unit is a flue-less heater, Oxygen Depletion Sensor (ODS) may be partially clogged with
dust, link or pet air. Clean Pilot Assembly using canned compressed air with a straw nozzle (like
you clean your computer with).
4. Gas pressure fluctuation to the heater. This will require a service call from an authorized Rinnai
Service Technician,
Hope this helped you to troubleshoot and solve the problem.
Jul 11, 2011 | Rinnai Heating & Cooling
Turned off heater last night. Tonight turned on and no light, nothing. what's wrong and how do I fix.
Have you checked the outlet plug for power? If there is power at the plug I would look at the fuse on the Main Circuit Board. Have you had any other electrical problems around the house? If you are not up to speed on electricity you should go no further than the fuse. Call a Rinnai service person.
Tom
Oct 21, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Two Rinnai's in series, large house, using circulater with electric pump connected to 2 gallon electric water heater. Problem is the Rinnai's seem to be firing almost constantly, apparently due to some...
Your circulator provides the draw necessary to fire the heater. You are defeating the purpose of this kind of heater by circulating the water. Add a second heater to fix this engineering fault.
Jan 05, 2010 | Rinnai Digital Remote Water Heater Control...
Heating & Cooling Logo
42 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
