Question about Yamaha Boating
Y dose my 28 yamaha smother when i put the top cover back on
Atv big bear 350 won't idle after cleaning
sounds like your mixture was leaned out because ur filter was cloged up ...making it run rich so was adjusted by screwing air screw out, now uv cleaned it, adjust it to make mixture richer by screwing back in until runs smotherly
Sep 08, 2013 | K and N Yamaha Big Bear Yfm350fw Air...
P 1004 would that make the transmission shift hard
No but it dose help your engine run smother change ur short runner valve
Aug 02, 2013 | 2008 Dodge Charger
Yamaha xt200 1983 service manual
Hi, John the vast majority of service, parts, and owners manuals on the internet are "FREE" to download and all service manuals contain wiring diagrams in the back pages. The rest usually charge a modest fee around $10 and there is a handful of obscure, rare, obsolete, and very old models that are no longer or never were available, for these rare occasions I shall look on eBay and find the cheapest one available. Most of the manuals will cover your exact make, model, and year otherwise one will be provided that comes as close as possible to your bike and will have most of the same info that an exact manual would have. To download your manual please click on the blue links below. Good luck and have a wonderful day http://www.ebay.ca/itm/1982-1983-Yamaha-XT200-Repair-Manual-Clymer-M417-Service-Shop-Garage-/161125516498?hash=item2583d444d2:g:ltAAAOxyaRZR4KcW&vxp=mtr $28
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-xt-owners-manuals
Yamaha XT200
https://en.wikipedia.org/wiki/Yamaha_XT200
Apr 21, 2011 | Yamaha XT 125 X Motorcycles
2001 Yamaha XJ 900 S Diversion how to adjust rear shock
Hi, Nodsieboy for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $ you can download another one. For more information about your issue and valuable "Free" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Yamaha Diversion 900 Owner Manual Rear Shock Absorber Adjustment
HD How to Adjust rear spring preload on Yamaha FZ6R and test ride
Yamaha 95 XJ900S Service Manual
Yamaha diversion 900 XJ900S Owner Manual
Oct 08, 2010 | Yamaha XJ 900 S Diversion Motorcycles
My Polaris 380 just stop moving the pump was run and had good pressure turn one wheel they all turn freely also tail dose not move
Check several things if these pool cleaners stop moving. Check the filter screen in the in-line filter and clean, if necessary. Clean the skimmer basket, pump basket, and pool filter. Check all of the hoses,
connections, and swivels for leaks that could cause loss of water pressure. Make sure that your wheel RPM is between 28 and 32. Adjust your thrust if necessary to get RPM to that level.
Aug 03, 2010 | Polaris 380 In Ground Pool Cleaner
Where do you insert the ink cartridges on lexmark x4650
These are the instructions for X2500 Printer
1.Press the "Power" button to turn on your Lexmark X2500 3-in-1 printer.
2.Open the top portion of the printer to reveal the ink cartridges.
3.Lift the gray plastic cover on the left. Remove the empty black #28 ink cartridge. Next, lift the purple plastic cover on the right and remove the empty color #29 ink cartridge.
4.Remove the new black #28 ink refill cartridge from its packaging. Tear the protective strip of paper from the cartridge's sensor. Now, remove the new color #29 ink refill cartridge from its packaging and tear the protective strip of paper from the cartridge's sensor.
5.Turn the cartridges so that you can read the label. This is the way the cartridges should face when being put into the printer.
6.Slide the black #28 cartridge into the slot on the left side and push it down. Slide the color #29 cartridge into the slot on the right side and push down.
7.Push the gray plastic cover down over the #28 cartridge until it clicks closed. Push the purple plastic cover down over the #29 cartridge until it clicks closed.
8.Close the top portion of the printer. Your new ink cartridges are installed, and your printer is ready to use.
Oct 25, 2009 | Lexmark X2500 All-In-One Printer
New top end but no compression or very little
Sounds like you have the crank to cam timing incorrect.  Also you may have the valves set too tight.  Dose it pop and sputter?
Mar 22, 2009 | 2005 Yamaha WR 250 F
Onkyo TX-28 Reciever memory function not working
Replace super capacitor in the front board (C712) with part # 598-EDLF473A5R5C .47F 5.5V form Mouser Electronics. I did. It worked.
Aug 13, 2008 | Denon DRA-395 Receiver
Boating Logo
75 people viewed this question
Top Yamaha Boating Experts
Phil Walker
Phil Walker
Colin Stickland
Colin Stickland
Mike
Are you a Yamaha Boating Expert? Answer questions, earn points and help others
