Question about Kitchen Ranges
Hi I need to know how to adjust gas oven termustat
2 Suggested Answers
Maytag317
  • 1136 Answers
SOURCE: how do i adjust oven pilot light on vulcan range
hi, there is an orfice for the oven located on the gas valve. If you are using LP gas, the orfice should be turn down all the way (counter clockwise). If you are using natural gas, the orfice should be turned out about 2-1/2 turns. Was this oven set up to be used with one gas and noe is being used with another? If so, you will need to do more then adjust orfices. Please let me know if I can assist you further.
Thaks
Vic
Posted on May 13, 2009
Hello, I would like to know why my LWW5331SOO gas oven is not igniting.
If you live in Pasadena, CA and need oven repair service Max Global Appliance Repair is ready to help you. Just call us at (626) 460-0903 or find useful info on our website Oven repair Pasadena CA Bosch Samsung LG Electronics
Sep 02, 2017 | Kitchen Ranges
Adjustment for timer tone - Frigidaire Gas Range
Hi RDWSR, this is AP. Thank you for your post.
Regrettably, you are not able to adjust the timer tone on your Frigidaire wall oven.
Mar 06, 2014 | Frigidaire FGB24S5A Gas Single Oven
Oven is not holding correct temp
Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details.
Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat.
When you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, and then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.
Let us know if you want something else please accept the solution.
Jan 02, 2011 | Maytag MGS5770 Gas Kitchen Range
Hi: I just installed Frigidaire gas range and have a couple questions. 1. 2 surface burners each have flame too high on only half the burner. it shoots up pretty high. How can I adjust this? 2....
Hi. There is an adjustment screw on each burner. Just make tiny adjustments until you are happy with it. Regarding the gas hiss, yes that is normal.
3 thumbs up please. Thanks, Joe
Oct 15, 2010 | Kitchen Ranges
Oven Flame
Hi still under warrenty get who sold this to you to come back and fix it
Feb 21, 2010 | Kenmore 71312 / 71319 Gas Range
Converting to lP and can't get oven to adjust properly
A very common occurrence surprisingly...to me anyway.
Have you changed the orifice in the oven when the conversion was done, both on the bake and broil burner supply tube ?
Need to start there even if it seems obvious, I see it a lot.
let me know,
Good luck,
macmarkus :)
Nov 08, 2009 | Maytag MGS5770 Gas Kitchen Range
Ge propane kitchen range changed to natural gas.can't get the ove
Hi, Did you flip the cap on top of the regulator? As far as adjusting the bake/broil orfices, all you will nee to do is turn them 2 full turns counter clockwise. Start the oven and watch the flame. It should have blue tips as much as possible.
You might have to raise or lower the orfice adjustment as needed.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jul 15, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Flame to high
Hi, To lower the size of the flame, turn the orfice on top of the gas valve in the oven. You will need a 1/2" wrench and need to turn the orfice clockwise to lower the flame.
please let me know if this helps or if I can assist you further.
Vic
Jul 04, 2009 | Kitchen Ranges
Yellow flame after an Lp conversion
I remember having a stove with an adjustable orifice in the oven. It looked like a double nut arrangement. If that is what you find, tightening them to each other shrinks the size. Should turn fairly easy, do not force. You may also find a pilot adjustment behind the oven control knob. Hope this helps.
May 19, 2009 | KitchenAid KGST307 Gas Kitchen Range
How do i adjust oven pilot light on vulcan range
Thaks
Vic
May 13, 2009 | Kitchen Ranges
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
