It stops before rinsing and the rinsing light and spin cycle lights start blinking. what is needing replacing?
SOURCE: the water wont drain or spin wf210 hotpoint
Hi I think your problem is that the filter is blocked, filter is located between drum and pump at the rear, clean that out and that should solve the problem.
Posted on Mar 28, 2009
SOURCE: Fisher & Paykel GW712 washing machine continuously
Out of balance switch could be faulty/ coroded.
have a gw 709 and it had the same problem, out of balance switch had jammed on
Posted on Apr 15, 2009
SOURCE: re Baumatic BK6EL, the washer stops at the
Hi Same problem but easy to fix.
Remove back cover of machine. Look to the lower end of the bowl and you will notice a stainless steel wire with hook attached. If this is hanging loose that will be your problem. Reattach the hook to the grey coloured lever , it has a hole drilled through it at the extremity. The wire pulls on this lever to disengage the drum brake during the spin cycle.
Posted on Mar 02, 2010
  • 3 Answers
SOURCE: kenmore he2 front loader washer won't do rinse spin cycle
if yours is the same, the drain is hidden behind the lower access panel on the front (how convenient, huh?). I don't understand why they didn't just make a recess hole for it. I've just left one screw loose in the center and it kinda "compression" fits. We clean this out regularly, as my wife and family don't check pockets well. :)
Posted on Apr 02, 2010
SOURCE: moffat washer light blinking and
I have the exact same problem on my clothes, washer. Lights blinking, then it stops at the end of the rinse cycle. What the ****. Moffat blows
Posted on Feb 13, 2011
Haier HLP21n blinking light error code.. Rinse and Spin lights blink...what does it mean?
This washer is a sanyo on the inside. When panasonic bought out sanyo and all its daughter brands, they started making parts not available for repairs. The service manual is here--->
This is also known as a sears proflex among other names.... haier-hlp21n-blinking-light-error-code-eqln1e0r5dvuapuxoxy4lmrd-1-0.jpg
Dec 09, 2014 | Haier HLP21N Washer
Spin light keeps blinking and I am unable to start wash cycle
we also need more information to try to pintpoint the problem
Jun 18, 2014 |
Why does my washer stop in cycle
Raise and lower your lid six times to reset timers.
Sep 30, 2017 | Speed Queen CTSA0AWN Front Load Washer
My whirpool locked light keeps flashing and wont wash
The light is flashing due to the door lock error. The door lock is activated as the machine experienced an error or was stopped in middle of a cycle. Or the door was being pulled while the machine was running a cycle. Try unplugging your washer and restart the washer to check if you are still getting the same blinking light. If error is still not resolved then start the rinse/spin cycle & stop the cycle, now press and hold the cancel button for 5-10 seconds. However, if you are still not able to get the door open then you'll need to open the door manually by disassembling the washer.
Hope this helps... Please post back for any further assistance.
Apr 18, 2011 | Washing Machines
Moffat washer light blinking and stops at either full load or stops at rinse cycle
Dec 20, 2010 | Washing Machines
Wsher stops in the rinse cycle wiht a n F4 message
f2 error means long drain or no drain
check the drain pump
replace drain pump if nessesary
Mar 17, 2009 | Kenmore Washing Machines
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Washing machine stops mid cylcle
try pushing the door closed again, i have a problem with my machine that when i put a load on it starts then stops the light starts flashing then i firmly push the door (at the handle side) and it starts to work again, it might help!
May 10, 2007 | Whirlpool AWM6120 Front Load Washer
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
