Question about Hampton Bay 24750 Huntington III Ceiling Fan
Wall switch and remote quit working for fan and light
The Huntingdon fan and light worked for two years just fine. Now everything has quit working. The wall switch does not work and neither does the remote, even though I replaced the batteries (the control shows to be working on its screen, but it doesn't do anything to the fan/light). Any suggestions? This fan/light combo came with a remote--it isn't something we added to it. Is there a fuse or something IN the fan that needs to be replaced? The breaker in the breaker box hasn't been tripped either--we've already checked it.
    Problem Solver:
  • 15 Answers
Simple things to check - sometimes the vibration from the fan will cause the wires to come loose. Drop the fan and make sure both wire nuts are secure - take the opportunity to check and make sure you have voltage (using a voltmeter or a 110v test light) at the junction box. Do you have lights on the fan? Do they come on? If you have power to the fan, something is amiss inside the fan such as a faulty speed switch or connection.
Posted on Jul 20, 2009
Can't turn off fan when light is on
Not sure, but if its a new installation, I would say that the wiring has been done incorrectly. Ceiling fans with lights should be able to work independently. both on / off or 1 on, the other off.
Feb 22, 2014 | Televison & Video
Just installed a heller ceiling fan with remote, it works fine from the remote but the light nolonger works from the light switch
All the switch on the wall does is turn the power on/off. You have to do everything from the remote with the wall switch on.
Dec 27, 2013 | Hampton Bay 24002 Ceiling Fan
Ceiling fan light delay
How do you change the speeds? Pull chain ,dual control on wall or remote.
Sep 15, 2013 | Hampton Bay Dryers
Neither remote or wall switches will operate Hampton Bay 52
Check your wall switch you either lost your neautral or have a bad connection on your switch. Solution check white wires that are twisted tougher in wire nut and check the black wires on switch to make sure one of them don't pull out . Over time the black wires pushed in back of switch can work loose .
Jan 24, 2012 | Hampton Bay 52 In. Ant. Brass Redington...
Monte Carlo ceiling fan and light not working
Even a brief power outage can cause amnesia in the receiver. You can try disconnecting power at the source and spending a few minutes removing the battery from the wall-mounted remote and pressing all buttons to eliminate the 'stuck button' problem. Reinstall the remote battery and reconnect main power to the unit. Test operation.
Lastly, there always is the possibility that some gremlin changed your original control setup.
Jun 23, 2017 | Dryers
I don't know what model my fan is, but it's only 3 years old and suddenly two days ago the light and fan quit working. We replaced the light switch on the wall-nothing. Took apart whatwe could of the fan...
That may be, because you were using the Remote Control to operate it, but then turned off the wall switch instead of turning it off using the Remote Control.
Turn the wall switch back On and try to get the Remote Control to take back over the operation. If that solves your problem, in the future you will know to turn off the fan and lights with the remote, before turning off the wall switch.
Hope this helps solve your problem. My wife had to learn the same way with ours.
Feb 04, 2011 | Hampton Bay Heating & Cooling
Fan with remote won't work with wall switch. I
I just recently purchased a hunter ceiling fan w/light and remote. Had it installed and wall switch would not work, only remote. I contacted Hunter company directly about this problem and I was told that they redesigned their fans with remotes so that only the remote works for turning off power to fan. The person who made that made that BRILLIANT change should be fired. So to those of you who own a newer hunter an product with a remote ne your wall switch will not work tat s te reason why.
Jul 14, 2009 | Hunter Ceiling Fan Light Remote Control
Ceiling fan and lights with remote control
I got a new reciver installed in ceiling fixture,works fine:Boytin
Mar 15, 2008 | Hunter 52" Ceiling Fan With Light And...
Remote control ceiling fan
Possibly a bad circuit board in the ceiling fans remote function. I would suspect that the circuit board has a thermal issue where once warm it works fine. The most common fault that I have seen is a bad solder connection on the board. Pull the board from the fan and check all solder connections for cracks or dull solder. If you see any of these then reflow the solder connections. If this does not work you probably will need to order a new board from the manu.
Jan 26, 2008 | Dryers
Quit
if you get in touch with hunter they will send you a replacement reciever for you unit if its not discontinued
Jan 21, 2008 | Oasis Hunter 54' Ceiling Fan
Hampton Bay 24750 Huntington III Ceiling Fan Logo
338 people viewed this question
Top Hampton Bay Dryers Experts
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
