Digidoor 1 rail jams - Office Equipment & Supplies
My digidoor 1000n motor recently did not close all the way leaving a gap of about 60 mm and yesterday the gap seemed a bit bigger more like 100 mm how do i set it to close fully
on the rail there should be 2 cylindrical black magnetic read switches with white wires connected to them.
Those are the open and close distance units
sometimes they come loose and move with the vibration of the motor when opening the door
Nov 30, 2016 | Cars & Trucks
Who do I contact for Digidoor repairs and maintenance in the Lydenburg area?
only link for digidoors repair
one company
use "contact us " their web page
to get the nearest authorized repairer of didgi doors to the lydenburg region
DigiDoor Garage Door Motors Installations Repairs of DigiDoor 1000N...
Oct 14, 2016 | Building Materials
Can i fit 12v battery backup for digidoor 11 to open when there is loadshedding. My digidoor2 had the extra consoke for remote receiver
Nope, Digidoor II has no battery backup. You need to invest in a UPS or replace the motor.
Digidoor one, Digidoor III and the Digidoor IQ all have build in battery backup.
Jun 13, 2015 | Computers & Internet
Where can I get a digidoor 1 garage door motor ?
I found a site that you may check out go google -type in
they claim to be the home of digidoors. they have an e-mail , and a telephone no. 0114749060
even if they are not close to you maybe you can purchase on line and have it sent to you.
Feb 17, 2015 | Cars & Trucks
I bought a receiver to pair a Centurion D5 motor with thE Digidoor motor.How do i install the Receiver on a Digidoor motor?
Hi there Vusi.
You should have a manual open and close switch on the wall for your Digidoor. You need to find the two wires which control the open and close functions on the Digidoor Trace these back to the Digidoor motor connect these to the Comm and NO terminals. You also need to supply 12V power to the receiver This needs to be connected to the Possitive and Negative terminals on the receiver. These connections originate in the Digidoor motor housing and can be connected right there. Some Digidoor motors have connection terminals for additional remote receivers in the housing. Remember that the minimum connections needed are Positive, Common(Sometimes the common is also the negative supply so you can bridge the common and negative terminals on the receiver) and NO. Then pair the remote with the receiver as per the instructions in the receiver box. If you still cannot come right post pics of the PC boards of your receiver and Digidoor motor and I will identify the connections for you
Jan 05, 2015 | Televison & Video
Hi, My Digidoor II opener only moves the door 20mm at a time and stops. The same happens using the remote or the wall mounted pushbutton. How do I fix this?
I had the same problem easy to fix!
It's the rocker rail (small plastic thing that ajusts the power and direction) that is damaged. Buy the part for R36-00 from any Digidoor agent 011 3978448.
Remove the motor from the installation rail and open the blue motor cover. You will see the rocker rail is attached to the blue cover, one of them will be broken. Replace both of them (up and down)!
Jan 06, 2011 | Computers & Internet
I bought a second hand Digidoor 1 with garage door. The door opens and closes perfectly when the digidoor is off. When I power up the digidoor the motor will not open the garage door when the door is...
You are receiving interference from the digi door. You will have to return this unit and go with a different one on a different frequency. Chamberlain makes a clicker that would work well with that unit. Thanks BB
Sep 21, 2010 | liftmaster Chamberlain Garage Door Opener...
Fault Code 08.001.44 Paper Jam
That is a failure in the maintenance kit tray area.
1. The Cap/Wipe/Purge belts have loosened up or are out our alignment. - Adjust the Cap/Wipe/Purge belts and follow the procedures outlined in the Service Quick Reference Guide for adjusting these belts and proper alignment. 2. Ink contamination or spilled wax is keeping the Cap/Wipe/Purge from properly moving. - Clean up spilled ink from the drum maintenance rails guides, sensors, and pulley belts. 3. The Drum Maintenance rail guides are out of position. - Remove and reseat if necessary. These rails may have suffered fatigue and may show signs of cracking or breaking. If this is the case it is a recommendation to replace the Drum Maintenance rail guides
The maintenance drawer itself may have the end tabs worn down from lifting up and down.
Mar 27, 2008 | Xerox Phaser 8200 Laser Printer
