Question about NEC Lands Phones
I have nec sl1000 how to changing default extension after reset it
HOW TO RESET
What do you want to reset? make it clear to provide solution.
Jul 01, 2014 | NEC PABX SL1000
Nec sl1000 call barring
How bar extensions from dialling out
Feb 27, 2014 | NEC PABX SL1000
How to Change Display Name
There is no option for it on your extension because your "class of service" is not set for it. Probably the only extension set for name change is 301 if the default configuration was not changed.
Mar 25, 2017 | NEC DSX 22 Corded Phone
Systeem 4/24 sl000
I think its always busy because it has a fault on that handset or its cradle. Swap the 2 over, and see if the problem moves to the new location, if it does the handset or cradle is faulty.
Dec 20, 2013 | NEC SL1100 1100061 Digital 12 Btn Black...
HOW COULD I RESET THE NEC SL100 PBX SYSTEM?
Download manual from: https://www.manualslib.com/manual/832824/Nec-Sl1000.html?page=531
System Reset on Page No. 2-509 of the manual:
Dial 1 + press HOLD (Press Hold key only to cancel)
Jul 04, 2013 | NEC PABX SL1000
Factory reset sl1000
Feb 16, 2013 | NEC PABX SL1000
How to assign trunk lines on NEC SL1000 Keyphone System?
Try posting here:
http://www.tek-tips.com/threadminder.cfm?pid=937&page=1
Dec 07, 2012 | NEC PABX SL1000
Lands Phones Logo
44 people viewed this question
Top NEC Lands Phones Experts
Brian LaDuca
george  peters
george peters
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
