Thermostat clicking sound - Heating & Cooling
    Guru:
  • 587 Answers
That's relays inside the thermostat switching, it's normal.
Posted on Dec 17, 2016
I have a new trane system - thermostat makes an annoying clicking sound every 10-15 minutes -
Sorry to say, that annoying clicking sound is the thermostat calling for cooling/heat. Whenever the temperature is reached it will "click" off and then "click" back on when needed. Some thermostats are quieter, but all digital thermostats will have that sound. Sorry again and I hope this answers your question!
Sep 01, 2010 | Heating & Cooling
My AC unit is 3 years old. its set at 72 but wont go below 78 degrees. im in Las Vegas...Help
Set System Switch to Cool and lower setpoint below room temperature.
Verify thermostat and system wires are securely attached.
Diagonistic: Set System Switch to Cool and lower the setpoint below the room temperature. Within a few seconds the thermostat should make a soft click sound. This sound usually indicates the thermostat is operating properly. If the thermostat does not click, try the reset operation ( . If the thermostat does not click after being reset contact your heating and cooling service person or place of purchase for a replacement. If the thermostat clicks, contact the AC manufacturer or a service person to verify the cooling system is operating correctly.
Or call the techline 18002842925.
Jul 18, 2010 | White Rodgers White-Rodgers 1F85RF-275...
Its not cooling down even though I can hear the motor running
Jul 17, 2010 | White Rodgers White-Rodgers 1F85RF-275...
We have the white and rodgers thermostat model 1F81-261. The problem is that the ac unit will not work. We have reset and changed the batteries and set the point 4 degrees less than the actual room...
Diagonistic: Set System Switch to Cool and lower the setpoint below the room temperature. Within a few seconds the thermostat should make a soft click sound. This sound usually indicates the thermostat is operating properly. If the thermostat does not click, try the reset operation ( . If the thermostat does not click after being reset contact your heating and cooling service person or place of purchase for a replacement. If the thermostat clicks, contact the furnace manufacturer or a service person to verify the heating system is operating correctly.
Reset the thermostat by pressing , UP,DOWN and TIME at the same time.
Jun 28, 2010 | White Rodgers White-Rodgers 1F85RF-275...
Its saying MO in the upper left hand corner and AC won't turn on
Diagnostic: Set SYSTEM Switch to COOL and lower the setpoint below room temperature. Within a few seconds the thermostat should make a soft click sound. This sound usually indicates the thermostat is operating properly. Ifthe thermostat does not click, try the reset operation .If the thermostat does not click after being reset contact your heating and cooling service person or place of purchase for a replacement. If the thermostat clicks,contact the AC manufacturer or a HVAC service
person to verify the cooling is operating correct.
MO stand for MONDAY.
Jun 06, 2010 | White Rodgers White-Rodgers 1F85RF-275...
Auxiliary light was lite on my white-rodgers 1f82-51 thermostate and i have no heat?
follow this guide:
Diagnostic: Set SYSTEM Switch to HEAT and raise
the setpoint above room temperature. Within a few
click, try the reset operation. If the thermostat does not click after being reset contact your heating and cooling service person or place of purchase for a replacement. If the thermostat clicks, contact the furnace manufacturer or a service person to verify the heating is operating correctly.
Mar 01, 2010 | White Rodgers White-Rodgers 1F85RF-275...
Thermostat is making a clicking sound, eveything on display is lit up.
If the thermostat has a display and making a clicking sound, that sounds like the thermostat is working.
If your thermostat has batteries, then its most likely your batteries that are keeping the display lit.
You can try removing and replacing the batteries first. Also, check all your breakers. If these two steps fail and the system is not functioning, then you have a problem somewhere.
Jan 17, 2010 | Heating & Cooling
Heat will not come on.
No heat troubleshooting
Diagnostic: Set SYSTEM Switch to HEAT and raise the setpoint above room temperature. Within a few seconds the thermostat should make a soft click sound. This sound usually indicates the thermostat is operating properly. If the thermostat does not click, try the reset operation listed above. If the thermostat does not click after being reset contact your heating and cooling service person or place of purchase for a replacement. If the thermostat clicks, contact the furnace manufacturer or a HVAC service
If you need further support call the techline 18002842925.
Nov 16, 2009 | Honeywell Electronic Programmable...
How would I fix this CLICKING sound?
You have a bad fan relay. You need to get it changed. Is this fan board. If so the intire board has to be changed. Safe side get a service tech to check it out ask for free estimate up front. Russ
Jul 21, 2009 | Heating & Cooling
Doesn't cool
Check your thermostat setting. the clicking sound is probably the compressor un-loading.
If you set the thermostat higher, the compressor will not turn off too soon.
May 08, 2009 | Refrigerators
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
