Question about Upstar Televison & Video
Upstar monitor factory support - Upstar Televison & Video
P250WT upstar used as monitor. Lost volume output. How to reset ?
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts
Nov 01, 2016 | Upstar Televison & Video
P240wt upstar tv HDMI inputs not working with AMD HD 6450 Graphics
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Sep 13, 2016 | Upstar Televison & Video
Need upstar TV Codes
I found that common LG codes (056) mostly work with UpStar (that uses LG panels, and generic electronics modules).
Watch out for stripped or missing hardware, including on table stand pod and VESA brackets, with UpStar's sloppy quality control. Also, they've reversed AC line Hot and Neutral and caused other problems in their California service facility, shipping fire and electrocution hazard TV's.
Aug 28, 2012 | Acer Televison & Video
Televison & Video Logo
169 people viewed this question
Top Upstar Televison & Video Experts
Jayesh Panchal
Jayesh Panchal
ray gallant
Are you an Upstar Televison and Video Expert? Answer questions, earn points and help others
