Question about Yamaha RX-N600 Receiver
Yamaha rx-n600 what universal remote will work this reciever
  • Yamaha Master
  • 1,195 Answers
Hi U can buy Yamaha Remote's on E/BAY TO SUIT you're RX-N,600. US $46.99 ,good luck
Posted on Dec 17, 2016
  • 236 Answers
SOURCE: yamaha rx-v800 remote control's damaged
it can be accessed via the main unit controls but you need to go through your manuals. Maybe you can get your remote repaired still... maybe not badly damaged caused by corrosion.
redrivera0314@yahoo.com
Posted on Mar 19, 2008
SOURCE: Need Scientific Atlanta code for Yamaha Rx-V663 remote
043, 011, 003, 041,042,045, and 046
Posted on Jan 24, 2009
  • 50 Answers
SOURCE: Need a code for my Comcast Universal Remote
30176 is the code you need . Press Aux and then hold setup until Aux lights up. Enter code. If you want the remote to control the receiver all the time, press Aux and then hold setup until Aux lights up. Enter 993 then press Aux. Aux will flash, now press Cbl and Aux should light up when you use the volume.
Posted on Jul 06, 2009
SOURCE: Code for Time Warner Synergy V Model RT-U64CP remote
CODE 301 will turn off Yamaha but I don't have code to turn it back on.
Posted on Sep 13, 2009
perpetually
  • 360 Answers
SOURCE: I want my Comcast remote & Yamaha RX-661 to communicate??
30176 or 31176
I am guessing at what remote you are using, so the code may not work. If that is the case, go to the following link and pick your remote from the picture list.
http://www.comcast.com/corporate/customers/customer_support/remotes.html
Posted on Jul 13, 2010
I need codes for a Yamaha rx-v2500 receiver. The codes listed turn it on but not off. Can you help??
Joseph, codes 0081,0082,0176, 0186, 1176, the attached manual may have more codes.
Yamaha rx-v2500 receiver, try the auto programming feature on your remote to set up universal remote. It is possible the remote may not support your equipment and you will have to replace with compatible remote. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
RC Yamaha RX V2500 Receiver and DVR PVR 5 HELP
Codes for Universal Remotes Codes for Universal Remotes How to Program Universal Remote
Yamaha RX V2500 Owner Manual Setting Remote Control Codes
Aug 08, 2016 | Yamaha Audio Players & Recorders
My Yamaha RX-N600D will not switch on. Can I do anything to fix i?
Did you press the master switch? Just above the on / off switch. On the drawing the number 1
Jul 09, 2014 | Yamaha RX-N600 Receiver
I have a Yamaha AX-V690 receiver but I do not have a remote control. Can I buy remote for this unit oris there a universal remote I can use? Thank you. Plz reply to: molly@prtc.net. Thks.
You can purchase a remote for it if you would like. The part number for that remote is: VS713700 You could also use a universal remote if you would like. But keep in mind that most of the inexpensive universal remotes only support the major functions such as Volume, Tune Channel, etc.
http://www.remoteyard.com/yamaha-vs71370-vs713700-rx-v90-rxv90-rxv900-rx-v900-en.html
This is a replacement, but this particular remote is pretty expensive, and you could probably get a nice universal for that price (the lowest I found it was $69.95). Good luck, hope I have helped!
Mar 03, 2011 | Yamaha RX-V690 Receiver
I have a universal remote RF20 and need the right 3 digit IR code for a yamaha RX-V361 reciever . Does any one have any suggestions , all I need to do is control volume up and down with the universal...
Try using code search to find something that works. If a search through all codes stored in the remote control fails, you may have to try a different one. All universal remote controls do not contain all possible codes.
Jan 12, 2018 | Yamaha RX-V361 Home Theater Receiver
Can I adjust the level of each channel from the receiver, not from the remote control (the level button on mine is not working)?
Depends on the reciever, some due and don't, my advice is to get a universal remote that will work with your reciever and then you can adjust your settings no problem. I own a Yamaha RX-V3800n and you can hardly do anything without the remote.
Hope this helps
Sep 24, 2009 | Panasonic SA-HE7 Receiver
What is the yamaha htr 6050 remote code?
You have to "learn" the IR. Yamaha has discrete on and off commands. which universal remote are you using?
Jul 25, 2009 | Yamaha RX-V563 Receiver
Yamaha remote to command Sony CD changer.
isn't that nice of them to just list the yamaha code for CD players? I sent yamaha an email about it. we'll see what they say...
have you checked out the new universal remotes that are out now?
http://universalremote.com/consumer/products.php
http://www.compuplus.com/i-Universal-Remote-Control-URC-R50-Digital-R50-Universal-Remote-Control-1028369~.html?sid=jn84494w6bxh2e2
Feb 26, 2009 | Yamaha RX-797 Receiver
Need yamaha codes to program into uverse tv ir remote
(I have the RX-V659). Because the Yamaha remote has TWO SEPARATE buttons - power ON and power OFF (standby). This problem can't be fixed. There's a code to choose power ON and another code for power OFF. But one button can't be two buttons. Bad engineering\ design by Yamaha in my opinion
Jan 09, 2009 | Yamaha RX-V800 Receiver
Yamaha RX-V390
Try reseting the Yamaha-Shut the power off, and while holding down presets 1,2 and 3 press power on.
Nov 24, 2008 | Motorola Mobility DRC800 Universal Remote...
Yamaha RX-N600 Receiver Logo
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
