Question about Hardware & Accessories
How do I set ringgrip RCT24 N13577 timer please. It has grey and white push in pins
3 Suggested Answers
SOURCE: I have a old Ringgrip
1) I specialize in timers, and search timer information each day.
The only tripper pins available on internet are for Intermatic box-type and some outdoor timers.
http://www.electricsupplyonline.com/prod/intermatic-trippers.php
And not all Intermatic timers have trippers, because Intermatic manufactures timers for a lot of other companies, and sells timers under many brands.
2) Open following link to find same/similar timer
http://waterheatertimer.org/Woods-timers-and-manuals.html
3) You can add a comment and describe your timer, and I might know of same/similar product
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Feb 13, 2011
SOURCE: I have just found a
There are no instructions that I can find on internet or in my timer files.
Add a photo to this post so I can see timer, and maybe give a solution -or- starting point, and then between us we can find the steps needed.
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail while you work on timer or any do-it-yourself project.
Posted on Feb 19, 2011
How to get this RINGGRIP timer to work?
Do you have a manual?
First set the current time and after the on and off time
Mar 16, 2013 | Hardware & Accessories
I need to know how to set the time on my model RETP RINGGRIP TIMER
To set the time;
Press and hold the TIME button during the time setting procedure. While holding the time button press DAY to set the correct day and HR to set the correct hour (make sure the am/pm is correct) and then MIN to set the correct minutes. (If you hold down the Day/Hr/Min button for more than 2 seconds it will give a fast run-through)
Dec 13, 2012 | Hardware & Accessories
Ringgrip timer retp timer manual
1) Send a photo so I can see it.
2) Raindrip makes water timers.
http://raindrip.com/products/timers?vmcchk=1
3) Otherwise the only reference on worldwide web for ringgrip is Fixya, which shows links to answers that cannot show a product either.
4) And if all the links to your product show Fixya as first page google search, then there is likely no information available.
Nov 27, 2012 | Hardware & Accessories
I have just found a Ringgrip N13577 Timer in a box of electrcal items from a garage sale but have no idea how to work it . Can you help
Feb 19, 2011 | Hardware & Accessories
I have a old Ringgrip timer with little pins which allow the timer to switch on and off. I need to buy more pins
Feb 12, 2011 | Electrical Supplies
I have the GE Plug in Mechanical Timer Model 15119. I have the pins pulled up on the white side at 5 and on the black side at 5 and the side setting on the timer position. Yet when I plug it in the wall...
We had the same problem when we first tried to set our timer. Although we have a newer model, this might work for your timer as well. The pin for each 1/2 hour interval that you want the device to be "on" must be pushed toward the perimeter of the dial, not the center of the dial. For each 1/2 hour interval that you want the device off, the pins should be pushed toward the center of the timer. Don't forget to move the arrow on the dial to the current time just before plugging in the timer. Be sure the switch on the side of the timer is moved to "timer on", the override is "outlet on" for when you want your device to come on during the time that the timer is set to have your device turned off.
Dec 27, 2009 | General Electric GE 24-Hour Timer, 2-Pin...
Hello, I have a Worcester 24i boiler, it has a round clock with a grey outer ring,that can be pushed in(the grey bits around the clock), I would like to know how to set the timer on this boiler, it's...
When the grey bits are pushed in the boiler is set to come on for that 15 min incriment. Push they grey pins "in" for the required length of time you want the heating on and then set your manual on off switch to the middle position which will activate the clock to run through the set time sequence you have put in.
Sep 30, 2009 | Heating & Cooling
First alert timer 220
First Alert 6262 Patterson Pass Road, Suite C Livermore, CA. 94550 1.800.458.1385 orders@vwimc.com
  1. Set current time with arrow at top of dial
  2. Time on, push and slide white pin
  3. Time off, push and slide grey pin
  4. Automatic override, use red switch on side
Comments on some sites that refer to this unit is dont waste your time .. heap of junk, wasted hours and it still didnt work.
So good luck
Please rate our help to keep the FREE service online
Aug 30, 2009 | First Alert 24 Hour Timers - 2 For The...
Hardware & Accessories Logo
152 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
