Question about Miscellaneous
I have a very swollen lymhnoid on the left side of the back and about 10 cm from my underarm and it is growing bigger any thoughts to this
How to build a hydroponics garden
To start with... check the below links and videos
Hydroponics at Home and for Beginners
Jan 17, 2014 | Garden
Does underarm hair grow at the same speed as hair on your legs? I am asking because I feel like I have to keep shaving my underarms and my legs need shaving so much less often and I wondered if this was...
You are right - underarm hair grows up to 50% faster than the hair on your legs. So it's very normal that you have to shave your underarms much more frequently. Maybe consider waxing so that you don't have to do so often.
Feb 18, 2013 | Health & Beauty
What is the easiest way to remove unwanted hair? Ie from my legs and underarms.
Shaving is definitely the easiest and cheapest method to remove unwanted hair. You can buy razors quite cheaply and use shower gel, although some people prefer to buy a shaving cream which reduces redness afterwards. Shaving your legs and underarms doesn't hurt at all but you have to keep doing it regularly as the hair stubble grows back quickly.
Jan 10, 2013 | Health & Beauty
My Sansui 32 Inch LCD screen shuts off, after a minute. The power remains on - the screen just switches off.
This may not work but i had a similar problem. My 32inch sansui LCD TV would switch off after about 10-20 minutes. I had to unplug it to get it going again. So i decided to open it as the warranty was long gone anyway. Very easy to open the back. I checked to see if anything was "swollen" as some sights suggested, but found nothing burnt , blown or swollen. Then i thought about heat? So i left in on without putting the metal backing plate back. It worked! when i put the plate back.....20 minutes and it shut down. So i just left the metal backing plate off! And no its not dangerous as the sansui has a protective plastic backing, that covers the metal one, that is better ventilated and protects the bits and pieces. Its been a week now and its fine.
Feb 15, 2012 | Sansui 32" TV
A rectan Dear Madam Please look at the math questions below. Please help me solve the questions Question 1 : A rectangular tablecloth is 2.5 m long. Trim is to be sewn around the perimeter of the cloth...
1. Well this one is pretty simple. Since you are not supposed to trim the length trim the width instead.
to make the perimeter 0.4 m shorter cut the cloth by 0.2 m width the picture will make it clear.
2. let the length of rectangle be x cm
and breadth = 20 cm
now original perimeter = 2(x+20) cm
new length = x-30 cm
breadth remains same = 20 cm
new perimeter = 2(x-30+20) cm = 2(x-10) cm
According to question
new perimeter = old perimeter /2
2(x-10) = 2(x+20) /2
2x -20 = x + 20
x = 40 cm
hence length of longer side 40 cm.
If you want to directly comm
Feb 13, 2011 | Vivendi Excel@ Mathematics Study Skills...
Scans very very slowly. Thought it wouldn't scan at all. Left it. Just see half a page scanned. One cm at a time or so..
I presume that you mean "photocopies slowly".
Check the "resolution" of the scan, i.e., 300-by-300 or 2400-by-2400 or something else. Bigger numbers mean slower (but better) scanning.
Oct 07, 2009 | HP PSC 1210 All-In-One InkJet Printer
panel is going bad
Aug 18, 2009 | Televison & Video
My epson rx420 only prints the left hand side of any document ??? Can any one help please . many thanks
have you set the page setup in document is same with page setup at print setup. Some new epson printer use paper sensor to measure the paper width. If page setup wider than actually paper inserted, the printer will print only half page. example : Your document 10 cm wide, page setup 20 cm, and you insert 10 cm paper wide. It will print only half of 10 cm, 5 cm.
Jun 09, 2009 | Epson STYLUS R230 InkJet Photo Printer
Flickering at bottom left hand corner of screen
Remove every Electromagnetic interference source in a 50 CM radius: speakers (low cost speakers are unshielded), fan, transformer, UPS.
Make a symple test using an AM radio: if you ear noise when approaching the area (screen Off) remove the source of interference.
Some time a different orientation of devices will fix the problem.
It worked for me
Jan 10, 2009 | LG Studioworks 700S 17" CRT Monitor
Miscellaneous Logo
22 people viewed this question
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
steve cannon
Level 1 Expert
Dan Grod
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
