Question about Pioneer Vsx 826 K Av Receiver Black
Is it worth repairing a pioneer vsx-826-k. There is power and I can change the different audio input but no out put to tv or dvd
2 Suggested Answers
AJIN G
  • 6694 Answers
SOURCE: pioneer audio video receiver VSX-D710S but there is sound to the speaker, but no audio coming from the player
Try to check the audio setting of the player. If you user using optical or coaxial then the audio out put format setting should be Raw other wise it should be PCM. You will see the setting if you go through the menu of the player
If you wish to get some details; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Posted on Jan 07, 2017
How do i put my pioneer receiver to my cable tv,dvd. vsx-917-v-k
For this purpose I am using headphone output of the TV set. I connect the headphone output to the AUXiliary input of the receiver. All you need is an interconnection cable, one end with 3,5 mm stereo male earphone jack, the other end with a pair of RCA jacks. This output of TV provides an additional output signal to your receiver but volume control behaviour (independent volume control for earphone output etc.) changes for different brands of TV sets.
Jan 04, 2015 | Pioneer Audio Players & Recorders
MY Pioneer VSX-826-K has just switched itself off and I can not get it to come back on?
try holding "advanced surround" and power buttons - it might be in protect mode.
Aug 07, 2014 | Pioneer Vsx 826 K Av Receiver Black
I am trying to hook up my Pioneer vsx-455 to a LG LED LCD TV. I am not sure on how to do this and I can not find a manual anywhere. Can you help me?
your reciever does not have hdmi, so the audio is not going to be true DD+ or DTS for broadcast tv.
if your dvd/blue ray player has digital optical spdif, this can be used to transfer the encoded DD+/DTS digital audio.
the besat way to run your tv audio through the reciever is to hook up the dvd/blue ray player up with (perferrably) digital optical spdif, composite spdif or (least favorably) through the stereo stereo analog inputs on the reciever for "dvd" audio in and hook the video from the dvd/blue ray up to the corresponding "dvd" video component input on the reciever.
this way is only going to get your dvd/blue ray sound, next you need to hook up your cable box to the reciever so that you can get broadcast tv sound. hook up the cable box audio to the "tv" stereo analog audio ins, and hook the video to the corresponding "tv" video component inputs.
the component video inputs have separate jacks for red, green and blue ( labeled "Y" "Pb" and "Pr") and are capable of carrying a 1080p full hd signal. use the component video outputs on the reciever to output the video signal to a component video input on the tv, using the receiver's input selector to change the video source.
Nov 25, 2010 | Pioneer VSX-455 Receiver
No TV sound, only DVD and CD players
Check your tv settings may need to change from speaker out to line out.
Check the tv input on the receiver, put the cd or dvd cables into the tv input. If you get audio the receiver is fine. No audio check the receiver settings.
Nov 16, 2009 | Pioneer VSX-54TX Receiver
Pioneer VSX-D608 Optical connection
The manual states that the default association of each digital input in as follows:
  • Optical 1: CD
  • Optical 2: MD
  • Optical 3: TV
  • Coax: DVD
Use the "Signal select" button to set the receiver to use a digital input, and the Dolby/DTS button (above "Signal select") to enable decoding.
As samz11 stated above, a remote is required to alter the digital input mapping.
Sep 19, 2008 | Pioneer VSX-D608 Receiver
VSX D511 No input select
I am getting no sound via my optical cable input. The back of the AMP says that the optical is TV/SAT but i can't change the input to digital it will only go to analog. DVD player is set to Bitstream all dvd options set to DTS, but still no sound going through. Any help would be apprecaited
Jan 29, 2008 | Pioneer VSX-D511 Receiver
DVD video stops; audio continues
This definitely sounds like a circuit board-level issue. Have you tried moving to a different input set (i.e. if you're now on the TV inputs, try the DVD or AUX inputs for both video and sound)? Just to rule out the obvious, have you made sure that it's the receiver and not the DVD player? I know that you said you powered down the receiver, but if you had turned it off by pulling the plug on the surge suppressor and your DVD player is in the same suppressor, you might want to make sure it's the receiver and not the DVD player.
If you're sure that it's the receiver, then you might want to look into taking it to a Pioneer service center to have it repaired. If it's not worth the cost to you, it might be time to be looking into a new receiver.
Dec 10, 2007 | Pioneer VSX-D914 Receiver
HDMI Compatibility
It sounds to me like you have a HDMI Control issue. It sounds like the DVD player wants to control the receiver. Try turning off hdmi control on the TV, reciever, and the dvd player in their setup menus.
Let me know if this helped,
Joe
Oct 03, 2007 | Pioneer VSX-81TXV Receiver
Video issues w/ Pioneer VSX-816 AV Receiver
Receivers generally cannot or will not convert from one input type to a different output. That's not to say there may not be some high end models around that do that.
I have this receiver and have it setup as follows. Monitor out Component, S-Video, and the Composite video channel (since I have surround sound I have no interest in getting audio to the TV since I keep its speakers off anyways) to their different inputs on the TV. Warning on some TV's if you plug in S-Video you cannot then use composite on that same input channel as it will override and disable the composite. Then you only need to choose the appropriate input on the TV when you switch sources. In my case Tivo is S-Video, DVD is component, and most of my older video games and VCR are composite.
Having a TV that allows you to change the labels for the input channels is helpful with teaching others that may be less adept, or a snazzy remote that you can program to do everything at once.
Aug 30, 2007 | Pioneer VSX-816-K/S Receiver
Pioneer Vsx 826 K Av Receiver Black Logo
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
