Question about Philips Televison & Video
Tengo el control taika TK-404 y se me perdi? la hoja de c?digos nececito sincronizar con philips
    Top Expert:
  • Philips Master
  • 74,136 Answers
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window" to get gathered related posts.
Posted on Dec 15, 2016
Hola tengo problemas con una troka ford di?sel 250 .2010 no starea no enciende con la llave nomas directa de la bater?a al stare le puse la computadora y estos son los c?digos. .p242a
Saludos, el c?digo que te marca tu veh?culo no tiene nada que ver con el problema de prender el veh?culo.
Si tu veh?culo prende utilizando un destornillador pegado al arranque (starter) entonces tu problema proviene desde la ignici?n del veh?culo. Te recomiendo que verifiques desde el arranque hasta la ignici?n.
En cuanto al c?digo p242a, tiene que ver con el escape, probablemente con el sensor que se encuentra en el manifold o header. Aqu? te dejo un enlace para verifiques.
http://p242a.enginetroublecode.com/dodge-ram-1500-van
Sep 24, 2015 | Ford Cars & Trucks
Tengo un control remoto universal Polar 9045699 y perdi la hoja de codigos y tengo un televisor LG. Alguien que me ayude con los codigos para Tv LG Flatron. Gracias de Antemano.
hola perdi el catalogo de mi control universal polar 9074996 y no tengo ni idea cuales seran los codigos, serian tan amables en ayudarme por favor
Jul 30, 2013 | Televison & Video
Hola tengo un control dish network y una television philips y no tengo el codigo
Hola mi nombre es Kimberly Escobar con DISH Network. Seria un placer ayudarle proveyendole la informacion que necesita para programar su control con su televisor Philips. Hay ciertos codigos que se pueden integrar a su control permitiendole funcionar con la T.V. Para la marca Sharp tenemos los codigos 566,770,741,628, y 521. El procedimiento es el siguiente: oprima el boton de T.V localisado en la parte de arriba en el control hasta que los demas botones se prendan en rojo una vez esten iluminados ingrese uno de los codigos seguido por el signo de numero, (por ejemplo 566#) el boton de T.V debe iluminarce 3 veces. Despues de esto puede intentar usar su control tambien puede entrar a nuestro link aqui puede encontrar mas codigos e instrucciones a como programar el control http://www.dishnetwork.com/SupportSection/remote-setup si necesita mas ayuda o tiene preguntas adicionales por favor contacteme directamente al kimberly.escobar@dish.com. Gracias y espero esto le sirva de ayuda.
Feb 17, 2012 | DISH Network IR Remote Control
Que significa el codigo de error hd en el modelo wtw6600sw2
Todos los códigos de error que aparecen en una hoja de datos en la lavadora. Para acceder, levante el panel superior de la máquina y buscar entre la bañera y el panel frontal. El panel superior es levantado por la inserción de un cuchillo de la masilla a lo largo de la costura en la parte frontal superior se reúne la parte delantera de la máquina, cerca de dos pulgadas a cada lado. Empuje el cuchillo de la masilla en la costura para liberar los clips de sujeción y levante la parte superior.
NOTA: Asegúrese de que usted se aferra a la parte superior, por lo que no se abre y se rompa. Se recomienda que utilice un poco de cinta para mantener la tapa cerrada.
La hoja incluye todas las definiciones de los códigos de error, solución de problemas, diagramas de cableado y los procedimientos de diagnóstico.
Si usted todavía tiene preguntas, por favor, después de vuelta y me dejó saber. Espero que esto ayude.
May 19, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Hola nesecito los codigos para programar mi aux marca sony .. tengo control dish
Hola mi nombre es Mayra Diaz con DISH Network. Sera un placer ayudarle y proveerle la informaci?n que necesita para programar un control de DISH Network a su televisor Sharp. Hay ciertos c?digos que se pueden integrar al control que le permiten funcionar con la televisor, unos de los c?digos serian los siguientes: 500, 758, 590, 640, 690 y el 090. El procesamiento a integrarlos es el siguiente: Presione el bot?n de T.V localizado en la parte de arriba del control hasta que se prendan los dem?s en rojo una vez esto suceda ingrese uno de los c?digos seguido por el signo de numero por ejemplo (#700). El bot?n de T.V deber? iluminarse 3 veces en rojo si el c?digo es compatible. Despu?s de esto puede intentar usar el control con su T.V. Espero esto le sirva de ayuda si tiene preguntas adicionales o necesita ayuda puede contactarme directa mente a mi correo electr?nico
Apr 03, 2011 | DISH Network IR Remote Control
Como desbloqueo el htc hd2
No puede haber muchas formas de desbloquear su teléfono.
Por lo que sé de los códigos de desbloqueo es la simple y más segura way.unlock utilizando el software de eliminar alguna información en la memoria puedo desbloquear mi teléfono con los códigos, tengo los códigos de http://www.superunlockcodes.com/htc-hd2/rs12wp9/ se puede desbloquear el teléfono aquí
He utilizado los códigos para desbloquear mi teléfono celular. yo tenía mi código de desbloqueo y mi teléfono estaba cerrada con llave.
tiene que especificar el país y proveedor de la red
Dec 06, 2010 | HTC HD2 Smartphone
El problema que tengo es con una dell 3100cn y elo que me aparece en la pantalla es el siguiente mensaje "bandeja 1 debe de ser de 250 hojas" no me permite meterme al menu ni tampoco se queda...
Nused que cuando movi? la impresora que usted instal? atr?s encima de la bandeja de 250 hojas (es requerido para el modelo 3100cn), es posible que puedan haber da?ado la entierra-conexi?n el?ctrica entre la base de impresora y la unidad de 250 hojas de bandeja.
Devuelva la base de impresora de la unidad de bandeja y conjunto aparte. Examine con cuidado el conector en la unidad de bandeja y aseg?rese del corchete que contiene el conector no ha sido doblado ni ha sido deformado. Consiga alguna ayuda e incline la impresora atr?s suficiente distante que usted puede examinar el conector que aparea debajo de la impresora. Si no ayuda a estar disponible, desliza la orilla de la impresora lejos la orilla de una superficie fija s?lo lejos suficiente en ver la conexi?n.
Nov 30, 2010 | Dell 3100cn Laser Printer
No se ve el video en mi TV
yo tambien quisiera los codigos me harian un mega favor, les dejo mi correo manuelgutierreznevarez@hotmail.com de ante mano gracias
Nov 24, 2006 | Yahoo YHT-650 System
Televison & Video Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
