Why is my d8b stuck at boot up on checking nvram?
3 Suggested Answers
Benimur
  • 6966 Answers
SOURCE: nvram
Hi, This message "Checking NVRam" is part of the BIOS/CMOS POST even before Windows loads up. Offhand two things you can try: 1. Do a CMOS reset by temporarily moving the jumper near the battery to the opposite pair or by removing the Lithium battery for a couple of minutes or as prescribed by your motherboard's user manual; 2. If #1 is a no go, perhaps you should consider flashing your BIOS. If neither works out, it is possible that you have a hardware/motherboard problem and would require replacement. Hope this be of some help/idea. Post back with your motherboard brand/model, how things turn up or should you need further information. Good luck and kind regards.
Posted on Sep 15, 2007
engg_cool_bo
  • 236 Answers
SOURCE: when i replace and upgrade my ecs p4vmm2 ram up to
i think u are trying to upgrade ur ram with ur existing ram, if this then plz check ur old ram frequency and then select another ram with same frequency, means u have to install rams with same frequency. i hope u can understand what m i saying.
Posted on Nov 07, 2009
How can I turn my clock on on my mackie d8b
There is a clock card inside you can not turn that unless you have an apogee clock card
Oct 25, 2014 | Mackie D8B Digital 8-Bus Mixer
Tip
Why lose a router settings after a power outage?
Question:<br> After a power outage <a href="http://www.3anetwork.com/cisco-1900-series-routers-price_c12"><b>Cisco 1900</b></a> lost my router configuration, was saved, reload the configuration, save, reboot and no problem.<br> How to know if my router is properly, all my services run smoothly? Why it happens that configuration is lost?<br> Are there any benefits the settings saved in flash?<br> Answer:<br> Did you check if the NVRAM was empty or running config was empty?<br> If router booted with empty running config, it could be that startup got erased (NVRAM issue) or that it did not load it from startup to running (likely config-reg) issue.<br> Since in your case config-register ix 0x2102 and was not changed, the problem should be with NVRAM.<br> From me exprience, I have seen that in the following cases:<br> - config was not saved to NVRAM;<br> - at the time of powerdown the NVRAM startup file was accessed for editing (e.g. saving running config) and got corrupted or erased;<br> - NVRAM HW issues cause file system problems.<br> Is it reproducible in your case? E.g. if you powercycle the switch, do you see the same problem with config loss? If yes, check the NVRAM content. <a href="http://www.3anetwork.com/cisco-1900-series-routers-price_c12"> <b>Cisco 1900 router</b></a> That could give some hints.
on Aug 22, 2013 | Cisco Computers & Internet
The cpu of my Mackie D8b no longer recognizes the keyboard or mouse and won't boot up.This problem just started after many years of trouble free use.
had the same problem once after a new install it still did not work
turned out to be the keyboard itself had a cable that wat broken solderd it and it worked again you can test this with a multimeter to see if the cables are still connected to the connector goodluck
Jan 14, 2014 | Mackie D8B Digital 8-Bus Mixer
BIOS NVRAM checking - not passed
I have had even new sticks of ram not work in one machine, but are fine in another. Put the old ram back in and make sure everything works like you want, then try the ram again. If they are still giving problems, unfortunately it looks like even more ram is your solution.
Dec 23, 2017 | Toshiba Satellite Computers & Internet
When i replace and upgrade my ecs p4vmm2 ram up to 1gb..first it enter os but when i restarting im stuck with checking nvram"..im done with re installing the usb wire,reseting cmos..unplugging...
Sounds as though your new RAM may not be compatible with the ECS.This is most certainly the case if the system boots correctly with the old RAM back in place.You may need to check the specs for this mobo on the EliteGroup website to find out what RAM is compatible.
Nov 07, 2009 | EliteGroup P4VMM2 Motherboard
Mackie D8B Mixer freezes
Don't know your setup but have you checked out any possible Hum loops? Have you updated any firmware updates? Is your mains input clean (no spikes or very short drop outs of voltage)? Are you near any possible RFI, e.g. Taxi's or CBr's? The list goes on so check out the Mackie forum on the web for more. Good Luck...
Regards,
Frank.
Apr 07, 2009 | Mackie 1604 Vlz3 16 Channel Mixer
Nvram mismatch error after replacing the dislay panel on lexmark t644
You have to install a brand new front display, the display board has a backup of the nvram, on boot the system board check the nvram and if it don't match it will return an NVram mismatch error
Mar 30, 2009 | Lexmark T640 Laser Printer
Mackie D8B
Yep, same problem 30 seconds and loss of sound and led freeze, I did find this, (not that i have tried it yet, scares me opening things like this up, but let me know if it works
http://forums.mackie.com/scripts/forum/ultimatebb.cgi?ubb=get_topic;f=1;t=007783;p=3#000075
Jun 14, 2008 | Computers & Internet
P4VMM2 "Checking NVRAM"
Do you know where the lithium battery is located on that motherboard?
Replace it and reset your BIOS.
Jun 11, 2008 | EliteGroup P4VMM2 Motherboard
23 people viewed this question
k24674
jasbo
jasbo
