Question about Refrigerators
Why the freezer door opens when the refrigerator is closed?
There are 2 separate doors for the freezer and the refrigerator.
I have a refrigerator with a top freezer that was constantly popping open, just enough to let the heat in and melt anything inside. This can also cause heavy frost build up from condensing humidity in the air. The frost can build up on the front face of the fridge where it meets the magnetic gasket on the door making it even harder to keep the freezer closed.
The cause in my case was that slamming the refrigerator door sent a puff of air through the ductwork to the freezer above. The sudden pressure increase popped the freezer door open and the door wasn't heavy enough to close on its own. Since this is a beer fridge in my garage I fixed it by putting a stick on childproof latch from H-D on the freezer door. :-)
If this was our main fridge indoors, I would first check to see how much force it takes to open the freezer vs. the refrigerator section. It should be about the same. If not, check the freezer door gasket to be sure no food or ice is built up on it and that the mating surface is clean. Check that the door is closing parallel to the mating surface. A misalignment would make it hard for the gasket to seal or stay sealed. Adjust hinges if necessary. If all seems ok, check to see if the fridge is level or possibly needs to be adjusted so it tilts back just a bit to make the doors self closing and not fighting gravity to stay closed. If all else fails, inspect the door gasket to be sure it isn't broken or stiffened with age. Inspect the bottom of the door gasket with a mirror. I once had a side by side with what looked like a good gasket until I felt around the bottom of the door. Replace if necessary.
Posted on Dec 15, 2016
When I close my side x side frig the freezer door pops open
This happens because the refrigerators of today are air tight, the fresh food door pushes the air into the cabinet as it closes and the air has no place to go but up the air vent into the freezer and "pops" open the freezer door. First thing is make sure the freezer door is capable of closing properly and is not rubbing or catching anywhere. I sometimes add a washer or 2 to the center hinge under the freezer door so it doesn't rub anything. Put a little Vaseline ( or food grade silicone lubricant ) on the hinge side of the seal. I then raise the front of the refrigerator so that the front of the refrigerator is a little higher than the back of the refrigerator. Never level a fridge with a level. Once you have the door closing properly and front slightly higher than the back...let the fresh food door close from 90 degrees on it's own and the freezer door may "pop" open a little but will close again on it's own...and stay closed once all is set up properly. We see this more often now and have no trouble with the door staying open again after setting up the refrigerator properly.
Oct 17, 2012 | Kenmore Side by Side Refrigerator
GE profile freezer door pops open
If you close any refrig door " fast " , the other will pop open . These magnetic door gaskets , are designed for lighter holding power now , than they used to be , due to children getting caught inside . I would suggest lowering the front legs slightly , so that when you let go of the door , it will close slowly on its own .
Sep 29, 2009 | GE Profile PFS22 33" Artica French Door...
GE Profile freezer door problem
I wil let you know of things you can do to solve this.
Hope this helps, Thanks Sea Breeze
Sep 22, 2009 | Refrigerators
Frigidaire FRT17G4BW9 doors not staying closed
Adjust the front legs of your refrigerator slightly to raise the refrigerator. and and store items on the freezer door shelves to add weight. This is a problem of pneumatics and a testament to how tight newer refrigerators are. When you close the large refrigerator door it compresses the air in the refrigerator compartment. Both compartments are connected by air passages and thus the pressure change is transferred to the freezer causing the freezer door to pop open.
Raising the front of the refrigerator a tiny bit will help both doors close from the 90 degree point, which is desirable. Adding weight to the shelf will just help the process.
An additional aid in self-closure will be to use vegetable oil on a paper towel to wipe down the hinge side face of both door seals. All these maneuvers should aid in causing the door to stay closed and re-close if it should open slightly. Good Luck
Aug 23, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
Freezer door pops open when fridge door is closed.
well u need to check the rubber of ur freezer ;s door .some damaging in the rubber is causing the problem.
May 26, 2009 | Amana ARSE66MB Side by Side Refrigerator
Doors creak loudly when closed and pushed from the outside. Don't when open.
This short solution may help solve your creaking problem. First thing is make sure the freezer door is capable of closing properly and is not rubbing or catching anywhere. I sometimes add a washer or 2 to the center hinge under the freezer door so it doesn't rub anything. Put a little Vaseline ( or food grade silicone lubricant ) on the hinge side of the seal. I then raise the front of the refrigerator so that the front of the refrigerator is a little higher than the back of the refrigerator. Never level a fridge with a level. Once you have the door closing properly and front slightly higher than the back...let the fresh food door close from 90 degrees on it's own and the freezer door may "pop" open a little but will close again on it's own...and stay closed once all is set up properly. We see this more often now and have no trouble with the door staying open again after setting up the refrigerator properly. Putting vaseline insid the hinge pins too is a good idea.
Let me know if I can assist you better, Thanks, Sea Breeze
Apr 27, 2009 | LG LFC21760 Bottom Freezer French Door...
How do you level the kitechenaid side by side
Hope this helps solve your problem, Let me know. Thanks, Sea Breeze
Feb 27, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Freezer door is canted forward. This separates the gasket from the frame and allows air in. Large amount of frost build up.
HI thanks for the question. the fridge door should close by itself if opened and then just let go of door. if not that way. raise the front of the fridge to make it work that way. thanks the appliance doc. please rate my answer. thanks.
Aug 11, 2008 | GE Monogram ZICS360NRRH C... Bottom...
LG LRFC25750 Refrigerator French Door
Freezer section evaporator fan motor bearing are going out. This would be indicted by a high pitched squealing noise. Have the fan motor replaced and it should solve your problem.
Jul 31, 2008 | LG LRFC25750 Refrigerator French Door
Refrigerators Logo
29 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
