Question about Refrigerators
Why the freezer door won't close when the refrigerator door closes.
IFIXALL
  • 868 Answers
SOURCE: Freezer Door Won't Stay Shut
OK LOOSEN THE HINGE THAT SUPPORTS THE FREEZER DOOR.IT'S ON TOP AND HAS 3 SCREWS .JUST LOOSEN AND NOT REMOVE THEM.NOW LIFT UP THE DOOR UNTIL IT LINES UP EVEN WITH THE OTHER DOOR.AT THE SAME TIME TIGHTEN ALL 3 SCREWS. YOUR DONE!!!
PLEASE RATE THIS. THANX!!
Posted on Jun 06, 2008
  • 74 Answers
SOURCE: GE GSS22JEPA WW
This could be a sensor issue , that is what i would be changing in the first instance. The sensor connects into the same connector the vent door connects into.
Posted on Sep 02, 2008
  • 56 Answers
SOURCE: Subzero 550 Gurgling whenever door closes
Personally it does not bother me that much on mine. But since you asked, there is drain line that runs into the drip tray underneath. The line should not have any bends in it to form a P-trap which will hold enough water in to form a seal, so when the door closes and the pressures equal you have a gurgling sound. If it really bothers youtry these steps, remove the kick plate by removing the two phillips head screws on either side. The drip pan is suspended in the middle of the support and will probably have water in the drip pan so put a towel down before you start. Once off shine a light to see if the tube has a bend in it. Depending on when it was made there may be a clamp that hold the drain tube in place. Carefully pull the hose past that clamp to remove sag and eliminate the bend which forms the P-trap. You have to be careful as the hose maybe brittle and come apart. So if you pull to hard you may wind up replacing that line which requires pulling the unit at considerable cost. There is a check valve that can be ordered but was only used for a short time. The inline check valve was a part number 4202130. If it bothers you too much and don't want to try the fix here is the Sub Zero locator page for parts and service. http://www.subzero.com/locator/locator.aspx?type=0&zip=02030
Posted on Dec 05, 2008
  • 105 Answers
SOURCE: refrigerator door pops open, frigidaire top
The refrigerator needs to be perfectly leveled side to side dn should pitch back slightly. Also look at the plane of the doors, that is to say that they should be squared to the cabinet. If they are sagging, you may need to adjust the hinges.
Posted on Apr 17, 2009
  • 4793 Answers
SOURCE: KitchenAid Superba refrigerator door not closing
have you adjusted the levelers underneath to make sure f/f is square.use a level on top.
Posted on Mar 06, 2010
Testimonial: "Got it done finally. It was an easy fix and I was planning to hire someone to do it. Thanks."
Amana Br22tw refridge door won't stay closed
Check all the screws for the hinge and be sure the door is lining up properly.
Oct 23, 2012 | Amana ABB1927DE Bottom Freezer...
When I close my side x side frig the freezer door pops open
This happens because the refrigerators of today are air tight, the fresh food door pushes the air into the cabinet as it closes and the air has no place to go but up the air vent into the freezer and "pops" open the freezer door. First thing is make sure the freezer door is capable of closing properly and is not rubbing or catching anywhere. I sometimes add a washer or 2 to the center hinge under the freezer door so it doesn't rub anything. Put a little Vaseline ( or food grade silicone lubricant ) on the hinge side of the seal. I then raise the front of the refrigerator so that the front of the refrigerator is a little higher than the back of the refrigerator. Never level a fridge with a level. Once you have the door closing properly and front slightly higher than the back...let the fresh food door close from 90 degrees on it's own and the freezer door may "pop" open a little but will close again on it's own...and stay closed once all is set up properly. We see this more often now and have no trouble with the door staying open again after setting up the refrigerator properly.
Oct 17, 2012 | Kenmore Side by Side Refrigerator
Freezer drawer slides
you have to keep the white wheels on the rod even or the draw won't close correctly,pull the racks out fully open and even on both sides,you might have to adjust the wheels so both sides are even,i use a marker and mark the wheels,now when you hook the door assy on.you have to make sure the wheels stay in place or when you close the whole unit one side of the door won't close all the wa,it's a little tricky if you never tried to line them up before but if you mark the wheels part numbers 12002497 so both sides stay lined up it will close correctly. http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Refrigerator-Parts/Model-MFD2560HES/3048/0161000/M0412077/00009?blt=06&prst=0&shdMod=MFD2560HES this is the sears site and will show you a picture of all the parts.hope this helps
Dec 01, 2011 | Maytag MFD2560HES Bottom Freezer French...
I have top freezer LG refrigerator (I have it for a week, so it's a brand new). When I close refrigerator door the freezers door bounces opens and closes). Hoe to fix this problem?
When you close the door, the air pushed in by the door has to do somewhere, so it may momentarily pop the other door. As long as it closes right away by itself, no problem.
Apr 19, 2011 | LG LRTBC1825T Top Freezer Refrigerator
Our side by side freezer door opens slightly
That is a common occurrance for side by side refrigerators. Closing the fresh food door is like having your car windows closed and closing the door. You can feel the air pressure on your ears. In the refrigerator, the air passes through the duct and into the freezer pushing the door open. The magnet on the door gasket should keep it closed. But it may be the freezer door needs the hinges adjusted to the door seats better when closed. Take the plastic cover off the top hinge and you can loosen the screws (don't take them out) and adjust the door slightly (so it looks even between both doors) and tighten the screws up. The top of the door should be level with the top of the unit, and the gap between the doors even the whole way down.
Jan 03, 2010 | GE Refrigerators
GE Profile freezer door problem
I wil let you know of things you can do to solve this.
Hope this helps, Thanks Sea Breeze
Sep 22, 2009 | Refrigerators
Freezer door pops open when fridge door is closed.
well u need to check the rubber of ur freezer ;s door .some damaging in the rubber is causing the problem.
May 26, 2009 | Amana ARSE66MB Side by Side Refrigerator
Doors creak loudly when closed and pushed from the outside. Don't when open.
This short solution may help solve your creaking problem. First thing is make sure the freezer door is capable of closing properly and is not rubbing or catching anywhere. I sometimes add a washer or 2 to the center hinge under the freezer door so it doesn't rub anything. Put a little Vaseline ( or food grade silicone lubricant ) on the hinge side of the seal. I then raise the front of the refrigerator so that the front of the refrigerator is a little higher than the back of the refrigerator. Never level a fridge with a level. Once you have the door closing properly and front slightly higher than the back...let the fresh food door close from 90 degrees on it's own and the freezer door may "pop" open a little but will close again on it's own...and stay closed once all is set up properly. We see this more often now and have no trouble with the door staying open again after setting up the refrigerator properly. Putting vaseline insid the hinge pins too is a good idea.
Let me know if I can assist you better, Thanks, Sea Breeze
Apr 27, 2009 | LG LFC21760 Bottom Freezer French Door...
Sub-zero 500 series refrigerator door wont stay closed
If Your Refrigerator's Freezer Door Pops Open When You Close the Fresh Food Door... If a 'top-freezer' refrigerator's freezer door pops open when the larger fresh food door's closed, it's actually a good thing. That tells us the seals are in great shape, sealing well.
Some freezer door 'pop' is unavoidable bc the bottom door's so much larger than the top one and the hydraulic effect of compressing all that air kicks in. The two compartments share the same air via a duct between them, and that compressed air rushes up into the freezer compartment and can 'pop' the door.
To improve the situation, apply a few drops of oil (sewing machine oil or 'three in one' - NOT WD-40) to each freezer door hinge pin. (Even better: if you can, pull the doors and coat the hinge pins with petroleum jelly). This will help the freezer door swing back closed by itself. The freezer door usually stays ajar because it's binding a bit, and that's usually caused by it's swinging 'dry', with no lubrication.
It’s also a good idea to ‘kick’ the habit of letting the refrig door close hard.
Sep 04, 2008 | Refrigerators
Refrigerators Logo
29 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
