NS-32D311NA17- Is any set up for voice - Televison & Video
On the Insignia TV remote, how do I get back to being able to choose channels with Direct TV remote?
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name of your device, in the "Search box at the top right of the Home page display" to see the set-up codes to your device, with different brand remote controls.
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code
Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
Nov 28, 2015 | Insignia Solutions Original INSIGNIA TV...
Voice recognition using Sony ICD-P320 and Naturally Speaking
I would run compatibility check. It sounds like not compatible with Vista.
May 16, 2010 | Sony ICDP620 Digital Voice Recorder
What is the screen resolution for this set - Insignia NS-27RTV
Standard definition is 480. This TV has 500 lines of resolution. Detailed specifications can be found in the owner's manual, under the Support tab.
Jan 28, 2010 | Insignia NS-27RTV 27" TV
I have Insignia Blu-ray DVD player and a membership with Netflix. My DVD player references Netflix download coming soon in order to stream movies straight to the DVD player. Is that download available?
This model, NS-BRDVD, is not Netflix capable. Models NS-BRDVD3, NS-WBRDVD, and NS-BRHTIB are, however. A firmware update may be required when first setting up your player for best functionality.
Jan 14, 2010 | Insignia NS-BRDVD Blu-Ray Player
RE; NS-LCD42HD-09 THE COLORS ARE TERRIBLE. THE
Here are some preferred settings for the same model in 32" It should get you close enough to fine tune from.
  • Picture Modes
    • Picture Mode : N/A
    • Color Temperature : Warm
    • Aspect Ratio : Wide
  • Precision Settings
    • Contrast : 60
    • Brightness : 50
    • Color : 52
    • Tint : G1
    • Backlight : 3
  • Advanced Video Menu
    • Noise Reduction : Off
    • 3DYC : Off
    • Dynamic Contrast : Off
Dec 25, 2009 | Insignia NS-LCD42HD-09 42 in. HD-Ready LCD...
Record your voice?
The recorder for this unit was designed to be connected to a PC or other music player that fed a powered signal. Connecting a microphone without a power supply and amplifier to it will not record since the port requires a powered send.
The "B" port will record a "Line Level" signal but not a "Mic Level" signal. you will need a pattery powered microphone for you to record your voice with this unit.
It works...but not the way you'd like it to.
Apr 15, 2008 | Insignia NS-DV2G MP3 Player
12 inch insignia subwoofers model # ns-sub12
how to wire 12 inch insignia sub woofers
Apr 01, 2008 | Car Audio & Video
Speaker act more like tweeter only, not mid range + tweeter
They are mid Hi speakers.1st Open them and check if the mid speakers are ok maybe they are defected or the protection is open. Good Luck Toufic Malek
Sep 22, 2007 | Yamaha NS-A327 Speaker
Televison & Video Logo
56 people viewed this question
Top Televison & Video Experts
