Question about Radio Communications
How do I remove the frequency restrictions on icom f7000 HF radio so it can transmit from 1.6 Mhz to 29.999 Mhz
    Problem Solver:
  • 17 Answers
This is the only Mod I am aware of https://www.youtube.com/watch?v=AGhPLpifAoU It was no easy find. Being its a SDR radio. I am unsure of any mod sites hosting any mod aside from receive. Except in this case of the video here.
Posted on Dec 25, 2016
  • 20 Answers
SOURCE: what's the channel frequencies for a common 22 channel motorola 2 way vhf radio?
Not sure what you want.....VHF band ius approximatly 130mhz to 175 mhz..... in that VHF band there is a commercial VHF band aprox. 155 mhz to 175...... the amateur radio vhf band is aprox. 135 to 150mhz.
With amateur radio, any freq in that range can be used...... with commercial radio the FCC cangive a company any freq. in that range also.
If you are looking for FRS/GMRS frequencies they are UHF freqs not VHF.
So I'm not sure exactly what you want......sounds like you might want to program in FRS freqs into an Icom amateur radio. If thats  the case you will need an Icom that will do UHF freqs.
Posted on Oct 12, 2007
Benimur
  • 6966 Answers
SOURCE: Yeasu FT 897D
I suspect that the extended transmit will really allow you TX on 2 Meter from 136-174 or thereabouts even with modifications.
At any rate, Air Bands are amplitude modulated, have you tried switching mode to "AM" when operating 116-136MHz??
Would you post back please on how the modification (extended transmit) was done; software programming of the EEPROM or jumpers (JP1001-1009).
Good luck and kind regards.
Posted on Nov 23, 2007
  • 36 Answers
SOURCE: Commercial radio model
Simply Put, modifying an AMATEUR radio for use outside of the 144-148mhz band is completely illegal. These radios are not spec'd for operating in the commercial VHF Band, and modifying it to do so may cause not only failure of the radio, but when transmitting you may interfere with other commercial frequencies, ie..fire, police, and if you are caught with the modified radio, may even face a huge fine or Jail time. Put bluntly, your better off to go out and purchase a proper VHF Radio for use in the frequencies which it is intended.
Posted on Jan 02, 2008
BillB-SA
  • 2761 Answers
SOURCE: how to add frequencies/channels to ICOM IC-F21
Sorry, but your radio is limited to 16 channels in the 400-430 and 440-470 MHz ranges. The number of channels cannot be expanded, nor can the frequency coverage.
Bill B
Posted on Mar 29, 2010
SOURCE: ICOM IC-A23 CL-ERR Problem
My neighbor just had this problem so I delved into it and fixed it.
You will need another working radio and the cloning cable.
DO NOT GO BUY ONE FOR 23 BUCKS PLUS SHIPPING!!!!!!!
This cable is nothing more than the same one you use to pipe your MP3 player into a car's AUX input.
You either have one or know someone who does that you can borrow.
If not go buy one from Sears ,Best Buy or any decent truck stop should have them for about ten bucks.
Turn both radios off.
Now with the 3.5 mm cable plugged in to both radios hold down the up and down arrow buttons and turn them on.
They should say "clone".
Now press the" ENT" on the good radio,
This will send the data over to the "bad" radio.
Now turn them both off, remove the cloning cable and turn them back on.
Both should be working now.
\WARNING if your battery is in bad shape it can cause the problem to come back. Either deep six the battery or hit the battery for a few seconds with your car battery charger to shock the cells.
Some times this can extend the battery's life.
Good luck!!
Rich
Posted on Sep 12, 2011
How can I remove the transmit frequency restrictions on icom IC-F700 radio
You can't, they are made to work on certain frequencies by law and it would be a Federal Offence to alter, even if it was possible.
icom IC F700 Google Search
Dec 15, 2016 | Radio Communications
How come my icom 756 pro did not transmitting on 8000 frequency
You have to modify this radio to operate outside of the HAM bands. You will likely find the modification at www.mods.dk. This is a pretty common and easy modification for HAM radios. Your performance may not be as good as in the HAM bands.
You do this MOD at your own risk. If you are not licensed for operation on ANY frequency or band, you are not legally allowed to transmit. Heavy fines may be levied against you.
Jul 14, 2016 | Icom IC-756PRO Transceiver 002896
How to change frequency of ssb fs-1503
For direct frequency input: i.e 2061.4khz transmit - (TX), (2), (0), (6), (1), (4), (ENT) - use (RX) for receive frequency.
For ITU channels - (CH), (4), (1), (2), (ENT)
Direct frequency inputs are restricted to authorized marine band frequencies.
Jun 09, 2014 | Furuno FS1503 HF SSB Radiotelphone EMail...
My icom 706 mk2g transmits on VHF uhf but not on HF whats the possible problem
My icom 706mk2g does no give me hf power on the hf bands but on uhf is working wel.
On the s meter the last blok is turn on.
Reseiver is working wel.
Wat can it be?? Transistor Finals broken???
The two srfj?
May 19, 2013 | Icom IC-706MKIIG
Need a service manual need to modify a MR f55 radio to transmit on 161.600 mhz can you help?
You want to be able to transmit to the Coast Station on this frequency I assume. The Coast Guard monitors channel 16 at all times. This would be the primary channel in the United States. Your radio is VHF Marine Radio and has a built in frequency range of 156.050 MHz to 163.275 MHz. There is no need for a modification. This is a duplex frequency. What that means is you will transmit on one frequency and receive on another, while on channel 20. You will not need to transmit on 161.600. Turn your radio to channel 20. When you transmit, you will transmit on 157.000. And when the Port responds to you your radio will automatically receive their signal on 161.600. So if you are trying to figure out how to communicate with the port authorities then for that frequency turn your radio to channel 20 and you will be able to communicate with them.
Regards, Tony
Mar 31, 2011 | Cobra MR- F55 Base CB Radio
How to add frequencies/channels to ICOM IC-F21 two-way radios?
Bill B
Mar 28, 2010 | ICOM Informatique Icom IC-F21 16ch UHF...
Icom ic720a ham radio not transmitting, pliz help
upon what frequency are you trying to transmit?
Perhaps the radio is blocked from trying to TX on said frequency.
Mar 17, 2009 | ICOM Informatique Radio Communications
A Kenwood TM-271A is an amateur radio and therefore restricted to transmit only from 144 - 148 MHz but can receive from 136 to 174.
The TX restriction is done with a resistor (R119) which inhibits transmission outside of the 144-148 band. It is located very near a large IC (IC252).
Depending on your country's radio communications policies and/or your radio license privileges, simply removing R119 would allow transmission outside of the 144-148 MHz.
Hope this be of some help/idea. Post back should yuo need additional information.
Oct 18, 2007 | Radio Communications
What's the channel frequencies for a common 22 channel motorola 2 way vhf radio?
Oct 12, 2007 | Unwired UFR650 (14 Channels) 2-Way Radio
Radio Communications Logo
90 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
