Question about Samsung Televison & Video
Samsung Plasma TV PN64E7000FFXZA. Cycles on=off.
Sometimes powers on and picture is as expected. Other times the power relay on the main power board cycles on off.I pulled the power supply board to look for obvious cap issues like swelled or damaged and did not find any.What next steps do you recommend?
  • 42 Answers
SOURCE: Westinghouse LTV-32w6 power light on, no video, no sound
One thing is to make sure the inverter board is unplugged when testing the voltages. A shorted inverter will shut down the power supply if the fuse dosen't blow first. There are fuses that don't look like fuses so they can be missed. The next thing would be to look for a connector from the main to power supply and see if there is a pin labeled power on or p.on or similar. The main board should turn this line high(5V) when you push the power button. If not you probably have a bad main board. Unless you can find good used boards they are both expensive. Around $200 for PS and $300 for main.
Posted on Jul 06, 2008
  • 304 Answers
SOURCE: Samsung TV Power Supply Board
I doubt that moisture damaged the SMPS bd.
There are many circuit boards in your set and it will take a trained samsung tech to find the problem.
Posted on Jul 17, 2009
SOURCE: intermitten problem with hitachi plasma on power up
well aparently all you do is fish for customers to buy into your sevice!
Posted on Nov 13, 2009
  • 927 Answers
SOURCE: Samsung model LNT5271f excessive relay cycling before full power
Yes, it is very easy to repair. Solder iron wattage should be at least 300 w.
The PSB is the center Board (towards left) after you remove the back off the TV. Remove the shield that covers the Boards and remove Board from TV with the 6-7 screws. Replace capacitors CM852 & CM853; 2200ufd 25volts.
Good Luck, big IRISH.
Posted on Dec 28, 2009
Testimonial: "Great fix"
  • 33 Answers
SOURCE: I have a Hitachi P50H401 plasma TV ,when you hit
unplug the unit for a while like one hour or so.
Posted on Sep 03, 2010
Samsung PN58C8000 Plasma. Picture changes from full color to a blue tinted picture. Logic board replaced 2yrs ago when TV would not turn on. Inspected all boards, no swollen capacitors.
Hi T Quinn.
Does the TV behaves the same way in all the inputs?
Does the color chances when the TV has been on for a while?
This failure could be in the main board, all the video info gets into the logic board from the main board itself.
I would suggest to check for proper voltages from the power supply to the main board, if all the voltages measure as expected. I would suggest to use a small cooling fan and place it near the main board.
Let me know if you require further assistance..
Feb 22, 2017 | Samsung Televison & Video
46 inch samsung TV cycles on and off, the standby light blinks consistently and shows no picture.
Main digital board fault. Check and replace it. If you wish to get more details visit the site linked here.
Jan 31, 2017 | Samsung Televison & Video
Samsung plasma tv pn58b650s1fxza, how to test the main board
Contact any service technician.
If you wish to get some details; check the site linked here. Pull up older posts.
Jul 11, 2016 | Samsung Televison & Video
I have a Samsung Plasma TV with no sound and no picture
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Apr 21, 2016 | Samsung PN43D490A1DXZA 43 In Plasma 3d...
Ln52a550p3fxza wont start cycles on and off
The problem could be temperature related. I replaced both my processor board as well as the power supply board and the problem is still there BUT I found a VERY simple solution that just requires me to keep the TV on all the time. When the TV is at room temperature, it literally takes 10-15 minutes for the system to stabilize and provide a good picture and audio. When my basement was at 55° for a few days, it took over 1 hr for the TV to stabilize. I now switch the input to my Roku player input and leave the TV on all the time. The Roku screensaver kicks in and all is fine with the world. No more issues with the TV not working. It adds to my electric bill but it is cheaper than replacing another board. When the TV dies, I'll get a replacement TV.
Dec 08, 2015 | Samsung LN52A550 LCD TV
Samsung ln46a630 power cycles with no picture or a grainy picture about 3-4 times then it will come on normal with a great picture.
Tuner fault. Contact any service technician to replace it. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Jan 26, 2015 | Samsung LN46A630 LCD TV
Samsung PS42B430 42" Plasma tv. LED flashes and
The tv power supply board have more dead components parts,u just don't have the skills an the know how to trouble shoot find out more dead components parts that all.Try website like to buy a whole refurbish power supply board for the replacement.
Jun 11, 2011 | Samsung PS42B430 42 in. Plasma TV
Samsung HP-R5052 Plasma TV
It related with Power Board(50%) or Y-Main(50%).
But, if you use the power bar with surge protacton, need to check
the power bar's lamp when the TV is turning on & off.
Jan 31, 2009 | Samsung HP-R5052 50 in. Plasma HDTV
Televison & Video Logo
Jerry Greenberg
Jerry Greenberg
