Question about GE Kitchen Ranges
GE profile oven doesn't heat up to proper temperature. Heats up fine in 400 plus range but is about 50 degrees to low when trying to heat up in 300 degree range?
SOURCE: Oven does not heat to proper temperature
get a new oven
Posted on Nov 23, 2007
  • 638 Answers
SOURCE: Hotpoint RGB747GER oven does not heat properly
Posted on Aug 18, 2008
  • 833 Answers
SOURCE: whirlpool oven 50 degrees too low
How do you know? Use an oven thermometer to check and leave it in for half an hour after the oven reports hitting temperature. Your manual should have a recalibration method.
Posted on Feb 25, 2009
  • 85 Answers
SOURCE: We have a Maytag Gas Range, Precision Touch
Likely your oven igniter is bad. Part number 74007498
Posted on May 18, 2009
  • 85 Answers
SOURCE: maytog gas oven model 5765QDB--oven will not heat up
Sounds like your oven igniter is bad.
Part number is 74007498
Why t takes long time for oven to heat up?
Does the oven actually heat up with the temperature more than 100 or does it just stay at 100? Alternatively, when you open the oven can you see the orange glow of the flame through the vents in the bottom of the oven and hear the gas hissing?
Aug 18, 2014 | GE Profile Spectra JGBP90 Gas Kitchen...
Our GE profile oven model JGsp31wet1ww oven will not heat up. When i set the oven to say 400 degrees, it just stays at 100 and never heats up. The broiler seems to work fine and the stove top gas burners...
pull out the racks and remove the bottom floor of the oven,turn it on bake,if the ignitor doesn't glow most likely it's bad,if it does glow and it doesn't ignite within 40 to 60 seconds the ignitor is bad.even though it glows doesn't mean it's good,it works by takes 3.2 amps.for a flat ignitor to open the gas valve and 2.5 amps for a round ignitor to open the gas valve.
May 15, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
GE free-standing electric range Pre-heat oven temp is about 50 degrees less than what is set (i.e. set digital display to 400 and over only reaches about 350). Is there an adjustment that can be made to...
We have a new GE Range and the signal beeps at about 100 degrees below the temp which we have set . The dealer replaced the sensor and the control circuit, but there was no change.
A service tech from GE came to our house and explained that the new ovens have a bottom heating element which is covered and therefore heats the lower part of the oven more slowly; but the exposed upper element heats more rapidly and the sensor is located near the upper element. We were advised to wait for about 15-20 minutes after the beep before placing the food in the oven. Judging from the number of comments found online, this seems to be a feature of newer ranges.
Nov 08, 2010 | GE JKS05 Electric Single Oven
The oven temperature isn't correct. Ovenw Won't heat up.
has the oven got a fan on it. if so then maybe fan is faulty.
if convection oven then maybe one of elements is faulty
or the thermostat is a problem
richard saupe
Appliance repairman colchester
appliance repairman
Mar 14, 2010 | GE Profile JT915 Electric Single Oven
My Magic Chef gas oven thermostat is not working properly. At 400 degrees it only heats to 200 degrees and at 500 degrees it only heats to 300 degrees. Do I need to replace it or can I calibrate it?
ther is a temp sensor that goes from the control valve to the oven,this may be the problem, make sure sensor probe is tight where it screws into the gas valve and other end is not just hanging in the oven, it attaches to the top of oven,if it's where it's supose to be, I'd change that first
Jan 31, 2010 | Magic Chef CGR3725 Gas Kitchen Range
My gas oven will not heat up above 300 degrees and
You may have 2 problems.
One. The temperature sensor could be bad. You can remove the temperature sensor and check it with a ohm meter. It should read 1050 to 1150 ohms. If not. It is bad.
Two. The glowbar ignitor could be bad and not igniting the gas safety valve.Open the bottom drawer of the oven and set the oven to bake. The burner should light in 60 seconds or less. Re-light should be about 30 seconds or less.
If it takes longer the ignitor is bad.
Dec 26, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Incorrect temperature in oven
the computer needed replacement. i just purchased another range instead.
Mar 27, 2008 | Amana ACS3350AS Gas Kitchen Range
Ge spectra xl44
check your Measure oven temperature sensor circuit at oven temperature sensor (should be approx 1100 ohms at room temp); check for cut or pinched wire or loss of contact and /or Replace Electronic Range Control (ERC)
Dec 18, 2006 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
44 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
