Question about Car Audio & Video
My car stereo cd player motor is not spinning after loaded. I have used 12v 2amp adapter. What was the problem
  • 3130 Answers
Its a good possibility that the turntable that the cd sits on is pushed down or up from where its suppose to be as if the laser cant focus on the disc the motor wont spin.There could also be a bad spindle motor as these do go bad or the motor driver ic is defective. see if you can somehow see the lens when the disc is inserted if you can see the lens moving up and down it is one of thoses problems I described are the cause, or worse case is a defective laser Pick-up assy. Good luck. good luck
Posted on Apr 15, 2006
  • 752 Answers
SOURCE: CD player on boombox
The laser is dead or damaged. Try swabbing the laser with rubbing alcohol on a Q-Tip, then IMMEDIATELY blowing dry with canned air. If this fails, the laser is dead. If it is a Sony KSS-2xx series laser (try to peek in the laser slot to see the decal on it) you can get replacements online. If not, it's junk.
Posted on Aug 04, 2008
  • 4669 Answers
SOURCE: New stereo, new CD Player
It's not too old, you can do it. You said three adapters. Is that three different ones you bought or three plugs on the car. You should be able to go to Wal-Mart and By a plug that will work.
Posted on Feb 27, 2009
  • 303 Answers
SOURCE: dc adapter fuse keeps blowing
you need a 4amp fuse
You can buy a new one ac adapter by clicking on the hyperlink:
buy replacement ac adapter power charger cord for POLAROID DUAL 7"
Posted on Mar 05, 2009
SOURCE: Sony XR-C350 Car Stereo - can't use cassette adapter for ipod!
I have a Sony car cd playerXR-c350 with a ten Cds unit,I want to know if there exist a Cd mp3 music player to use instead of the cd player, thanks.
Posted on Mar 20, 2009
I have An 02 hyundai xg350 and I'm trying to install an aftermarket CD player but somebody has cut the wiring adapter off so I don't know what wire goes whereso what are the wire colors
This site may help you The Install Doctor The Do It Yourself Car Stereo Installation Resource...
Not sure if you mean the plug is cut on the car or the radio. The colour code is pretty uniform , so its easy with a meter to identify permanent 12V, switched 12V and ground. Whats left will generally be speakers and aerial power lead if you have a power aerial.
Jul 22, 2014 | Cars & Trucks
I want to connect an mp3 player but i only have a cd player, is there a line-in jack somewhere in the car or behind the stereo
No jack on factory stereo. You'll have to use either a cassette adapter or an FM adapter; both plug into your regular mp3 line out. Cassette adapters are not as reliable but cheap and don't use power, while FM adapter requires power (from 12V or battery) and is more expensive.
Jun 06, 2011 | 2006 Ford Taurus
Changed Radio and now car won't start
What stereo did you use as a replacement? If you used a aftermarket (kenwood, sony, etc) cd player, you need to use the proper adapter harness. These cars have a build in theft deterrent system that involves the stereo. So, when you replace the stereo, a component of your anti theft system is missing. The use of the harness gets around this feature somehow, and allows you to use aftermarket CD players. Also, ensure that no wires are getting pinched behind the stereo, and that all your connections are soldered and shrink wrapped to avoid any future problems. I have provided a link for the correct adapter harness to your vehicle.
May 03, 2011 | 1999 Oldsmobile Alero
I need a wiring diagram for a Sony car stereo so I can figure out which wire color works for what.
yellow 12v battery
red 12v accessory
black earth
blue/white amp rem
blue power antenna
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
green rear left +
green/black rear left -
purple rear right +
purple/black rear right -
that should help u pls rate
Mar 30, 2010 | Sony CDX-F7710 Car Audio Stereo CD MP3...
Ive got a standard stereo in my 06 mercedes vito van and the cd has jammed inside how can i get my cd out than. matt
Follow this 3 steps :
Step 1 : You mast find the dc motor inside the car radio.
Step 2 : Desolder the 2 wires of the dc motor.
Step 3 : Connect the 2 wires to a 12V DC source, if the CD do not come out then reverse the wires.
Nov 09, 2009 | JVC KD-LH7R CD Player
I have a JVC CA-MXB5 stereo. As soon as you push the cd button error shows up on screen. Everything else works.
If you have a CD loaded, and you get that error, it means the laser can't detect focus on the CD.
If the laser detects focus on the disc but the turntable motor doesn't spin up you still get that error. Sounds like the laser is the problem in yours.
Oct 04, 2009 | Audio Players & Recorders
JVC car stereo won't play cd
If it does it with any cd and it played before you have to clean the lense or laser. Get a cd player laser cleaner disk or cd. If you still have problems take the radio fuse off in the fuse block to restart it. Remove the fuse wait five minutes then reinstall. Also some times when you burn CDs in the wrong format the cd player will not recognize them.
For Sony radios you need an aux Bus adapter called the Sony XA 300. It works with the Bus IN RCA, and there whould also be another plug spot for the Bus power and signal interrupter. That is how the Sony knows to access that port.
Oct 31, 2008 | Car Audio & Video
Car Audio & Video Logo
32 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
