Question about Dryers
Have a delonghi BC0330T that does not heat coffee, changed the thermal fuses, thermostat, and coil still does not heat coffee.???
  • Dryers Master
  • 2,355 Answers
Where do you have power?
Posted on Dec 15, 2016
Delonghi DCU72 not working
The light coming on is significant, it tells us that power is getting inside. If all else appears normal and it is only the heating function that is not present, it may therefore be:
  • thermal fuse;
  • heating element;
  • doubtful if the thermostat is defective but may be worth checking.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 20, 2008 | DeLonghi DCU72 Coffee Maker
Maytag Bravos XL Dryer not heating- blowing thermal fuse
The thermostat is controlling the temperature, however the Heating Coil may be defective. Check the COIL.
Feb 27, 2014 | Maytag MEDB950YW Electric Dryers
My Coffee from my DeLonghi Magnifica does not seem to be hot enough.
Possible weakness in the thermostat which make the heaters cut off at a earlier state. So try to check the machine for any loose connection to the lines, the heaters or else the switch and thermostat must be looked into .
Jan 24, 2011 | DeLonghi EAM3500 Espresso Machine/Coffee...
We havn't had our Delonghi BCO-120T but for 3 months & the coffee side stopped working all together. My husband is a great handyman & after taking that side apart. the tubing & tank looks...
In uk delonghi spares by agents of kenwood.co.uk. there is a directory of local agents. before ordering element check thermal fuse attached to the element it may be open circuit.
Jul 29, 2010 | DeLonghi BCO120T Programmable Espresso /...
Heating up please wait nothing happens then general warning comes on what can i do
Standard problem with some Delonghi coffe makers.
The problem is with heating device inside.
There is thermal fuse - that have production leak i think
Need to remove cover and repair this fuse
Apr 01, 2010 | DeLonghi Esclusivo Magnifica ESAM3300...
The coffee pot won't turn on anymore
burnt thermal fuse or heater does heater work under coffee pot? :)
Jul 03, 2009 | DeLonghi DCM485 Coffee Maker
Wont heat or brew!!
Make sure the coffee maker is unplugged there's 120 lethal volts inside when plugged in!
This unit has a replacable thermal fuse. It's a "Microtemp" Thermal Cutoff Fuse G4A00. You can buy five on eBay for $2.70. There are two on this unit and they are in the base concealed inside a 3" white mesh that runs alongside the heater. You will need a security fladebladed screwdriver that you can make by filing a notch in the center of a regular screwdriver.
Jun 28, 2009 | DeLonghi DC312T 14-Cup Coffee Maker
Dryers Logo
47 people viewed this question
Top Dryers Experts
