Question about Uniden Lands Phones
I need a user manual for Uniden DECT Digital Answering System
  • kakima Dec 15, 2016
    Hi Marie Butler, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    What model Uniden DECT 6.0 phone?
SOURCE: user manual of GE 29878GE1 Digital Answering Machine
From the Manual: RECORDING THE GREETING Before using your new answerer, you should record a greeting (the announcement callers hear when your answering system answers a call). If you don't record a greeting, callers hear a default greeting which says, "Record message after tone." When recording the greeting you should be about 6 inches from the unit. Eliminate as much background noise as possible. 1. Prepare your greeting. Sample Greeting: Hi, this is (use your name here). I can?t answer the phone right now, so please leave your name, number, and a brief message after the tone, and I?ll get back to you. Thanks. 2.Hold down the GREETING button. After the tone, you have 30 seconds to record your greeting. 3.Release the GREETING button when you finish. The greeting will playback automatically. NOTE: Your recording time should not be less than 2 seconds. Otherwise the unit will return to the default greeting.
Posted on Aug 22, 2007
SOURCE: ENZER DAS 100 DIGITAL ANSWERING SYSTEM
I need to set a new message and connect it to my new Telkom Business OPticon machine before tomorrow.. can anyone help and assist me!
Posted on Dec 18, 2007
SOURCE: conair digital answering system
TAD2012 Quick Reference Guide
To Install
1. Open the battery door with a ballpoint pen. Install one 9-volt alkaline battery (not included)
and replace cover.
2. Plug the telephone line cord (connected to the back of the TAD2012) into the modular wall
jack.
3. Plug AC adapter into standard 120-volt outlet. Plug your phone directly into an outlet, not into
an extension cord.
Answering System Operation
Recording Your Personal Greeting
1. Press and hold down the GREETING control.
2. After the beep, speak towards the front of the base; you have 30 seconds.
3. When finished, release button. Your unit will play back your greeting and
reset to answer incoming calls.
4. Adjust volume control on the side of the unit to set the speaker to the desired level.
Select the Number of Rings
Choose 2,4 or TS (Toll Saver), which programs the number of rings that you want before your unit answers.
To Play Back Your Messages
1. When the message indicator flashes, you have received messages.
2. To hear your messages, press and release the PLAY control. Your unit will automatically
reset after messages are played.
To Save Your Messages
After the last message and 2 beep tones, press the STOP/SAVE control.
IN CASE OF POWER FAILURE OR IF ANSWERING SYSTEM IS NOT OPERATING PROPERLY
If a power failure occurs or the plug comes out of the wall, your unit will shut down until the power is restored. One 9-volt battery must be installed to retain your personal greeting message and incoming messages during the power failure. Occasionally outside factors, such as power surges, may adversely affect the unit. If the unit is not operating properly or if the light continues to flash once power is restored, try these steps:
1. Unplug the AC adapter from the power outlet.
2. Remove the 9-volt battery. Replace with a fresh 9-volt battery.
3. Plug AC adapter back into power outlet.
4. When your unit is initially plugged in, it will check its memory for approximately 3 seconds.
Three deep tones will be heard if you attempt to record a greeting message before this
period.
5. Record a new greeting message.
Indicator Status: Message indicator is consistently flashing slowly.
Reason: No greeting message has been recorded.
Action: Record your greeting.
Indicator Status: Message indicator flashes rapidly.
Reason: A 9-volt alkaline battery (not included) has not been installed or needs to be replaced.
Action: Install a fresh 9-volt alkaline battery. (Battery provides power failure backup. Unit is functional without it).
Indicator Status: Message indicator flashes to indicate number of messages received,
and then repeats.
Reason: Messages have been received.
Action: Press PLAY control to hear your messages.
Indicator Status: Message indicator is lit solid.
Reason: System is in Answer Mode.
Action: No action required. Unit is ready to receive calls.
Conairphone™ Consumer Hotline
Questions? Call the Conairphone™ Consumer Hotline, toll-free, 1-800-366-0937.
Hotline Hours: Monday-Friday 8:30 a.m. - 9:00 p.m. (EST)
Saturday 8:30 a.m. - 12:30 p.m. (EST)
7475 North Glen Harbor Blvd.
Glendale, AZ 85307
Posted on Jan 29, 2008
SOURCE: User manual for a Bellsouth answering machine model 1188
Found my manual!
To set the time, press and hold the time/code button for 2 seconds. You will hear "TO SET CODE PRESS TIME AND CODE BUTTON."
Release the time/code button.
Press the 2 way/m button once. You will hear "SET DAY AND TIME, SUNDAY"
Press the << or >> button until you hear the correct day.
Press the time/code button once. You will hear "TWELVE"
Press the << or >> button until you hear the correct hour.
Press the time/code button once. You will hear "OH".
Press the << or >> button until you hear the correct minutes.
Press the time/code button once. You will hear "PM".
Press the << or >> button if you need to change to AM.
Press the time/code button once and you will hear the complete time and day setting.
To record an outgoing message, press and hold the ogm button. Release the ogm button and start to record after you hear "PLEASE RECORD AFTER THE TONE" followed by a beep tone. When finished, press the ogm button.
Make sure you put a battery in the answering machine so you don't lose these settings if the power goes out!
Posted on Feb 14, 2009
  • 569 Answers
SOURCE: I need an Uniden phone DECT2080 owner's manual.
You can find the manual here:
http://www.uniden.com/pdf/DECT2080om.pdf
Posted on Dec 16, 2009
How do I get message lite off?
If you are talking about the 'Message Wait Indicator' The answer is on page 26 of the user manual. Downloadable here (click owners manual) If you mean the 'answering system' it is on page 42
http://www.uniden.com/telephones/dect-60-cordless-digital-answering-system-with-caller-id-and-extra-handset-and-charging-cradle/invt/dect20802g/
Sep 17, 2014 | Uniden Lands Phones
I don't know how to delete message on a uniden dect 6.0 digital answering system
Since you declined to specify the model of your Uniden DECT 6.0 answering machine, I can only suggest you select it from the list beginning here to download a copy of the manual.
Feb 15, 2012 | Uniden DECT 6.0 Cordless Phone ID
I want to change my greeting. I have a Uniden dect digital answering system. No greeting button on machine nor any greeting button on the menu from the phone hand set.
Since you didn't specify the model of your Uniden DECT 6.0 system, select it from the list beginning at
http://www.uniden.com/owners-manuals/dect-phones/scat/dectphones_mnl/
to download the manual.
Aug 05, 2011 | Uniden TRU8885 Digital Answering Machine
I have lost my manual and i dont know how to record a personal message on my answering machine and how to enter the code to retrieve my messages from another phone.
From your handset, you just have to press the mute button, your phone should start telling you the time, date, ect. press the #5 key and then the #8 key and start recording your message. When finished press the # 8 key again. Hope this helps
Mar 21, 2011 | Uniden DECT 6.0 Cordless Phone ID
User manual for the Uniden Dect 6.0 digital answering system. thank you
There are a number of Uniden DECT 6.0 phones with and without answering systems. Find your model in the following list: http://www.uniden.com/index/manuals_results.cfm?cat=59 . Then choose the translation in which you want to read the PDF.
I hope this helps.
Nov 19, 2010 | Uniden DECT 6.0 Cordless Telephone...
User Manual for UNIDEN Dect 6.0
Sep 15, 2010 | Uniden 5.8GHz Expandable Cordless Phone...
Uniden DECT 6.0 Cordless Digital Answering System
You didn't specify the model, but you should be able to download a manual from http://uniden.com/index/manuals_results.cfm?cat=1
Nov 17, 2009 | Uniden Cordless Phone
Lands Phones Logo
44 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
