Question about Air Tools & Compressors
Need pressure valve gasket for model nbr K40355/EPC448
Cooks Essential pressure cooker K40355 instruction Manuel
Good morning to you
When ever I find myself witout a manual I need, I go to manualsonline. You will find the missing manual, it may take some time, but follow the instructions and you will get there. Free User Manuals and Owners Guides ManualsOnline com
Jan 17, 2017 | Coffee Makers & Espresso Machines
Manual for Mirro pressure cooker Model M- 0536-1
go google and type in -- user manual for mirro pressure cooker model m-0536-1-- and if there is one it will be a pdf version down load
make sure that the lid seal went in without any twists
put something under the seal and go around the lid several time to allow the seal to untwist
Oct 26, 2015 | Crock Pots & Slow Cookers
I cooked Chicken Adobo with vinegar and soy sauce. And it was the 1st thing i cooked. The smell won't come out of the silicon gasket or the center silicon. HELP!
Silicone gaskets tend to hang on to smells, follow this procedure to clean it and then leave it out in the air until the next use. Generally, you should store your electric pressure cooker with the lid upside-down which would naturally air out the gasket. I know it doesn't look pretty, though!
Good luck, and don't worry the smell shouldn't affect the food you cook in it.
Sep 07, 2015 | Cook's Essentials CooksEssentials 4qt...
Why wont my steelcraft 13 gallon 5hp model ta25 build up no more then 20 pound of pressure and all i did was change the oil?
Check all connections for air leak including the water drain valve with soapy water. If no air leaking from connections, spray soapy water on head area where head attaches to the cylinder checking for gasket leaks. If no leaks are found, most likely problem is in the head /valves /internal gasket leak. If head gasket or valves are leaking, you will notice that air seems to blow out of the intake filter (normally there is good suction at the intake). Good luck
May 16, 2014 | Air Tools & Compressors
2004 jeep code 1763 what to do
P1763 - Governor Pressure Sensor Voltage Too High
This code is refer for the governor pressure sensor which is located in the valve body of the transmission. If getting power to the sensor and the wires are not open or shorted then the sensor will need to be replaced.
Hoist and support vehicle on safety stands.
Remove transmission fluid pan and filter.
Disengage wire connectors from pressure sensor and solenoid (see picture)
Remove screws holding pressure solenoid retainer to governor body.
Separate solenoid retainer from governor (see picture)
Pull solenoid from governor body
Pull pressure sensor from governor body.
Remove bolts holding governor body to valve body.
Separate governor body from valve body
Remove governor body gasket.
Before installing the pressure sensor and solenoid in the governor body, replace O-ring seals, clean the gasket surfaces and replace gasket.
Place gasket in position on back of governor body
Place governor body in position on valve body.
Install bolts to hold governor body to valve body.
Lubricate O-ring on pressure sensor with transmission fluid.
Align pressure sensor to bore in governor body.
Push pressure sensor into governor body.
Lubricate O-ring, on pressure solenoid, with transmission fluid.
Align pressure solenoid to bore in governor body
Push solenoid into governor body.
Place solenoid retainer in position on governor
Install screws to hold pressure solenoid retainer to governor body.
Engage wire connectors into pressure sensor and solenoid Install transmission fluid pan and (new) filter.
Lower vehicle and road test to verify repair.
Hope helps.
Sep 29, 2011 | 2004 Jeep Grand Cherokee
Was working normal suddenly will not build pressure
Maurader1 an apprentice has this problem solved and is spot on. All these gurus and wiz need to stick to the basic and common sense. The first place your pump will give out after use or abuse is the gasket. All this garbage about defective reeds and defective pressure switch is a lot of nonesense if you first don't rule out the most common problem the head gasket. I'm cheap and this thing has paid for itself 10 time over. You can get a gasket kit for $7, but I fabricated a gasket out of the back of my notebook and sprayed some gasket spray and been working like a charm ever since.
Sep 27, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
I have a Porter Cable air compressor model CPLKC7080V2. Air leaks from the pressure switch and aftercooler safety valve and the pressure switch before the compressor reaches 80 lbs pressure. I replaced...
I believe you have a head valve or piston ring problem. The parts you replace are suppose to leak. It is a safety feature that doesn't allow the motor to burn up before the pump warms up. Kind of like a soft start feature. If you look on the breakdown part number 107 Kit Valve Plate is what you need to inspect. Sounds like your valve plate is either worn or damaged. If you go into the pump you will have to get part 103 also which is a gasket kit. Or you can try to salvage the old gaskets.
If the valve plate is ok you will need to inspect the rings that go around the pistons. Some times you will get one that gets brittle and breaks off scarring the cylinder. Look for these two things, I am pretty sure one of them is the problem with your compressor.
Sep 06, 2009 | Air Tools & Compressors
Air Tools & Compressors Logo
82 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
