Question about Polaris 2013 Indy 600
What size jets should I use in my97 Indy xlt 600 triple for psi triple pipes
Torque specs foe heads on 94 indy xlt sks 600 triple
not 100%sure for polaris but skidoo is 14lbs
Feb 05, 2017 | Cars & Trucks
93 xlt 580. Only runs on 2 cylinders sometimes at cold. Change plugs and works sometimes.. Not always same cylinder.. Any way to check stator,coil?
Ask The SnowMan Your Sledding Questions Answered: Off ...
www.off-road.com/.../ask-the-snowman-your-sledding-questions-answer...
Mar 1, 2009 - Its a 96 polaris indy xlt 600 triple not the special edition though. ... THEM SITTING ON THE HEADS BUT ONLY 2 CYLINDERS ARE RUNNING WHEN ... Q: I have a arctic cat ext580 the compression in both cylinders is about 70psi .... i have a93 polaris 600 xlt and I just got home and the antifreeze is ...
93 XLT Carb settings? - Snowmobile Forum: Your #1 Snowmobile Forum
www.snowmobileforum.com/polaris.../41045-93-xlt-carb-settings.html
Nov 27, 2009 - I bought a new to me 95 polaris sport last year. it had not run in twoyears. ... It's all in the tuning, clutching, jetting and gears.. i have a 93 xlt 580 and i ... he is loading up with fuel and just cutting the spark out of a cylinder.. i had ... XLT w/ Triple Pipes Question?
May 8, 2013
93 XLT Ran Great, Shut Down, Now Backfires
Feb 13, 2012
Dead cylinder
Dec 11, 2011
1998 ski doo f3 700 wont run right
Feb 22, 2011
More results from www.snowmobileforum.com
Polaris Indy 600 XLT HELP! - Snowmobile Fanatics
Jan 04, 2016 | Cars & Trucks
Have a 96 Polaris XLT 600 triple it holds an idol
Sounds like you're running lean on the idle circuit. Add a little choke and see if that changes your situation. (might not even if this is your problem) if you've just cleaned the carb recently and you didn't mess with the jetting at all, I think the mixture screws are likely off. (that is assuming they are accessible and were accidentally adjusted)
Oct 19, 2014 | Motorcycles
1997 Polaris XLT Triple. Do I really need to pull
I have 1995 and a 1997 XLT. i have rebuilt the recoil on the 95 and all it takes is the few bolts to take off the cover and take the pipe off. if the 97 is any thing like my dads 94, you may have to pull the engine up a bit, the bottom left bolt cant fully be backed out with out hitting the side of the belly pan retainer, all it takes to pull the motor up is one nut in the back of the motor mount, and one bolt off the front, and it will tip up enough
Jan 10, 2010 | Polaris New Genuine Polaris Snowmobile...
Horsepower output from a 95 polaris xlt 600 snowmachine
A 1995 Polaris XLT 600 snowmobile has a class-leading 120 hp.
Dec 23, 2009 | Polaris New Genuine Polaris Snowmobile...
Acceleration with gsxr 600
did you adjust the mixture when you changed the jet if not do it now fiddle with it till it runs smooth 11ff035.jpg
Sep 25, 2009 | 1998 Suzuki GSX-R 600
Carburetion; running too rich at low speed
check your jetting, Clip postion on needle jet. floats could be sticking. Carbs dirty.
Jan 16, 2009 | Polaris New Genuine Polaris Snowmobile...
Polaris 2013 Indy 600 Logo
105 people viewed this question
Top Polaris Winter Sports Experts
Larry Fostano
Larry Fostano
toddgilbert
toddgilbert
Are you a Polaris Winter Sport Expert? Answer questions, earn points and help others
