Installing a Lockstate ls-60 programmable thermostat. We have both a B and O wire. Instructions say we can tape off B, but what do we do with O?
SOURCE: Where does the T Wire go on the RTH7400
the t wire is for an outdoor anticipator reset. If you dont have a terminal on your thermostat it does not have to be used. Just tape it off.
Posted on Jan 19, 2009
daddyo742001
  • 70 Answers
SOURCE: Hunter 44110 programmable thermostat not turning off ac
You may and an anolog stat and the old one was digital if so it won't work. Digital sends info to system anolog is just a set of points open or closed. Digital can carry tons of info to system like a computer. Like comparing a computer to a rock. Sorry but you need to go back to proper type stat.
Posted on Jun 30, 2009
liteswink
  • 99 Answers
SOURCE: 1F78 thermostat change from F to C
yes to cut the wire named W904 at the middle.
Posted on Sep 23, 2009
billyvangogh
  • 108 Answers
SOURCE: Installing thermostat - extra wire?
you have to go down to your furnace and follow the thermostat wire ...it connects to a terminal strip or fan centre...the color doesn;t really matter...installers mix and match all the time....look at the furnace wiring and mark it down...Red on "R"...Green on "Y" whatever it is...and connect it accordingly upstairs...if you only have 4 thermostat wires downstairs you will need a jumper wire between RH and RC...if you have 5 wires you will see 2 wires on "R" at the furnace.,...and connect either to RH and RC at the thermostat
Posted on Nov 01, 2009
  • 252 Answers
SOURCE: installing a honeywell programmable thermostat for
one wire to R the other to W - dosen't matter which is which
Posted on Nov 08, 2009
I have a honeywell T87K round thermostat (2-wires R and W). I just purchased a honeywell WIF 7-day programmable thermostat RTH6580WF. How do I install the new thermostat? Is it even possible?
Programmable is in unit nothing to do wire fto urnace two wires cut furnace on and off you should have instructions to use two wires with your instructions
Aug 18, 2015 | Honeywell T87K1007 Mechanical Thermostat...
Honeywell programmable thermostat - was installed per instructions in manual and now the furnace runs non-stop unless I move switch to "off." The old (round mercury switch) thermostat was wired red t
If you are unsure about which wire goes where, that may be the source of your problem. The color coding can be confusing when changing from old to new. I pulled the instructions for my Honeywell CT3400A thermostat and found you can call Honeywell Consumer Services at 1-800-468-1502 M-F 7:30 am to 5 pm CT
Mar 11, 2013 | Heating & Cooling
I have a touchpad Zurich deadbolt lock on a front door. No manual. I replaced all 4 batteries at once. How do I re-program or re-set the passcode? Gordon
I have been searched unsuccessfully for "Zurich deadbolt keyless remote" in order to help you. However, if the picture shown in your request is accurate for your lock, I have found some information which may be useful to you!
The brand that I found is Lockstate, which looks like the lockset pictured. Go to this webpage (copy & paste into your browser search window):
http://www.lockstate.com/manuals-and-downloads.html?start=10
Go to the bottom of that page, to "LOCK LS-DBS" and click on Download. This will download a PDF file of the installation and programming instructions.
If you cannot open and view the download, you will need to download and install Adobe Reader. You can get it here:
http://get.adobe.com/reader/
If this is not the correct information for your lock, please re-submit the problem and I'll try again. Any further model info, etc., will be helpful.
Good luck--and please provide feedback if this helps!
Aug 25, 2011 | Deadbolt Zurich Digital Keyless Remote...
Where does the W2 wire go?
w2 wire is second stage heat does your furnace have two stages.look at gas valve it would have 2 valves/ sol w2 will go to w2 on stat. if a single stage furnace w2 is not used
Jan 25, 2010 | Honeywell Programmable Thermostat Heater
Nov 01, 2009 | Honeywell Electronic Programmable...
Nov 18, 2008 | Honeywell Programmable Thermostat Heater
Need help !!
have you tried there web site for the wireing instructions or manual to installing it.
Programmable thermostats at discount prices at
hunter-thermostats.com.
riz.
Feb 17, 2008 | Hunter Fan Company 5/1/1 Programmable...
Installing a honeywell CM900 wireless programmable thermostat
the analog unit uses just two wires for heat. red - white. there is a heat anticipator setting that must match the burner current. check your programmable specs and follow instructions.
Dec 04, 2007 | Honeywell Programmable Thermostat Heater
Heat pump thermostat replacement
It sounds like your reversing valve energizes the opposite from how you wired it at the thermostat. Check the instructions.
Oct 28, 2007 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
29 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
