Question about Cameras
Can we see previously recorded shows, after I remove the cable card ? If so how do I hook it up ?
Diamond VC500 Capture Card Wont Record!?
Windows bugs... I would first remove the card and software and then reinstall. Update drivers under system devices. Try again. There may also be a menu to enable recording, allocate hard disc usage for recording etc.
Sep 05, 2012 | Diamond Multimedia ( VC500) Video Capture
I have hooked up all cables correctly however when i attampt to record of my xbox i get black and white record screen ive tried 3 diffrent record program im using the HD componet cable (blue green and...
Greets - You are mixing cables up. You need to connect the Dazzle yellow, red, white cables to the yellow, red white cables on the TV. You can't plug standard video/audio cables into the component (red, blue, green) connectors on the TV.
take a look at this diagram, just pretend the devices on the left are all connectors on your TV.
Good Luck, Mikeywaf
Mar 03, 2011 | Pinnacle Dazzle DVD Recorder
I got a magnavox dvd recorder and 4 head hi-fi stereo vcr and im having trouble with hooking it up to my cable box how do i record shows on my recorder without switching inputs on my tv because i switch...
Don't hook the DVD/VCR recorder through ur cable box.Hook the DVD/VCR recorder through ur tv only it should work find.This way each units have it own direct functions to the tv.U recording the shows from the tv not the cable box ok.
Nov 15, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
I cannot save video to my pc. Is the preview sceen supose to go blank when recording?
The small screen should play what is being recorded. Make sure you push 'play' on the VCR2PC before you click the 'record' button.
Feb 20, 2010 | ION Audio VCR 2 PC USB VHS Video to...
Zenith xbv713 won't record on vhs tape
is the tab on the cassette in place? if it has been removed the cassette will eject automatically when pressing the record button.
Jan 05, 2009 | Zenith XBV713
No Tuner hardware !
The PC must have a cable tuner card installed and connected to be able to record and show TV.
The extender uses the PC for showing the (recorded) TV.
Dec 21, 2008 | Linksys DMA 2100 Media Center Extender...
I can't figure out how to bring up and watch a program i previously recorded on my motorola cable box
Look for a green button marked LIST almost in the center of the remote. If the List button doesn't work, be sure the remote is in the CBL mode (press the CBL button right under Master Power once)
When you get the list of recorded shows up, use the up and down arrow keys to highlight the show you want, then hit the OK/SELECT button. That should bring up another dialog box, look for Play and press the OK/SELECT button again to start.
Dec 12, 2008 | Arris DCT6200 DTV Receiver
you'll need an interface connector to get this to work..check at Radio shack.
Apr 21, 2008 | RCA DRC8300N DVD Recorder/VCR
Memorex MVD4544 VCR will not record
Take the unit back to the store and exchange it for an other unit of the same. The likelyhood of two units not working is very slim, and good luck with your new unit.
Jan 26, 2008 | Televison & Video
Cameras Logo
27 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
