Question about Garden
How do I set idle and high speed jets on Tillitson ME 5 B carbeurator
4 Suggested Answers
  • 7 Answers
SOURCE: 1988 Toyota Corolla high idle with lights on
Because it's carbeurated they have an electric 'idle up' solinoid (or vacuume) to compensate for rev loss when load is put on the engine caused by the alternator working harder because your using power. It should have a small adjustment screw on the carbeurator to lower the revs. If you have it set too low it will shudder when in drive & foot on brake with headlights on. It should only pick up about 200rpm when lights are on. To find the screw, take the air filter off, run the engine & look for something moving when the lights are turned on & off. Somewhere near the moving bit you will find the adjustment screw. I hope. I'm not sure exactly where it is on that model.
Posted on Apr 10, 2009
zipandbuddy
  • 694 Answers
SOURCE: rough idle
Poss mass air flow sensor
Posted on Mar 02, 2014
gregg201
  • 47764 Answers
SOURCE: what are the factory settings for low speed and high speed jets ?
Hi, David for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your David, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www2.vulcanrider.se/DL/KawasakiVN800_96-04ServiceManual.pdf
OEM Parts for Kawasaki
http://www.kawasaki-techinfo.net/searchOM.php?name=VULCAN+800&code=VN800&from_year=1986&to_year=2004&view_lang=EN&spec=OC&category=MC&page_no=1
Posted on May 19, 2016
Hi I have bought. super splendor bike 2011.my bike mailege. was suddenly getting down to 30 kms.per litre. I have changed new air filter. And head walls setting also. but no result.
Hi Anonymous and the usual suspects are:
1. Excessive enrichner use.
2. High-speed riding style.
3. Idle speed improperly adjusted.
4. Dirty air cleaner element (may also affect idle speed).
5. Vacuum piston assembly malfunction.
6. Excessive accelerator pump output.
7. Plugged or restricted bowl vent.
8. Fuel level too high.
9. Loose jets.
10. Worn or damaged needle or needle jet.
11. Enrichner valves not seated or leaking.
12. Plugged air jets or passages.
Aug 15, 2015 | Super Motorcycles
Poulan 222 38cc choke problem; choke has to be kept out for it to continue running. Carbeurator has been cleaned.
Sounds like this saw has had gasoline with alcohol in it and the idle jet is plugged up. Have to take it apart and use a small wire to open the jet. Just cleaning the carb will not solve this problem. With the idle jet plugged adjusting the idle screw will accomplish nothing. Then us gasoline with no alcohol in it from then on. Search with google to find a station that sells non alcohol gasoline in your area.
Feb 10, 2015 | Poulan Garden
Repair manual
Hi Robert:
Before you remove or try to adjust your low and high speed jets you should always count the number of turns it takes to lightly seat the idle mixture screw and high speed needle adjusting screws.
Be sure to write the number of turns down on a piece of paper so you will know how many turns from the seated position to open the jets when you go to reinstall them, or if you remove them for cleaning or replacement.
If you have aready tried to adjust them then the adjustments below should get it running for you for final adjustment when warm.
Normally you will adjust your idle jet to 1/2-3/4 turn open from the bottom seated position.
Then you will re-adjust the low speed of the engine when the engine is warm by turning the idle screw in or out till the engine runs smoothly at idle speed, around 1200 RPM.
The high speed jet is adjusted to 1 1/2- 1 3/4 open from the bottom seated position, after the engine is warm.
Then re-adjusted by turning the High Speed jet adjustment screw in or out till the motor runs smoothly at high speed.
Alway use the "lightly seated" method if you have not changed the screw settings.
Bud
Oct 03, 2013 | whipper snipper stihl fs 38
Need to tune sthil fs74 line trimmer
Hi chris tanti
Please take time to rate me
Bud
Oct 13, 2012 | Stihl Garden
Stihl FS 80 carburetor settings for high and low screws
Hi F Del
Bud
Oct 10, 2012 | Stihl Zama Fs-80 Carburetor C1q-s157...
Car settings stihl 026 with wt 194 carb?
Hi Alan Cowart
Sep 09, 2012 | Stihl 026 Ms260 024 Ms240 Original Walbro...
Wt 194 settings
Hi
Sthil carb setting
Hi
Aug 24, 2012 | Stihl 019t, Ms 190t, 191t Chainsaw Rewind...
I have a Briggs & Stratton 2 cylinder motor Model # 42A707-125201. Runs fine at high speed with the choke off, but it will not idle smoothly unless the choke is partially on (about 2/3). I rebuilt...
The fact the choke must be 2/3 applied to obtain a smooth idle indicates not enough fuel is being supplied by the carb at idle speed. Applying the choke richens the air/fuel ratio.
I suggest you revisit the carb idle air/fuel jets, air passages and any adjustments as well as checking for intake air leaks.
Sep 15, 2017 | Yard Machines MTD Gold 185 HP Lawn Tractor...
1964 5 1/2 hp evinrude kills at high speed
You should have a High Speed carb adjust and a Low Speed carb adjust. If it's running fine while idling, adjust the high speed setting. If you have two nobs, its the lower one. May be set wrong. If you don't have two nobs, remove the carburator and check the jets to make sure they are completely clean or better yet, order yourself a carb rebuild kit to take care of all of this. I just rebuilt my 1971 evinrude 4hp and the carb kit made the world of difference.
Apr 17, 2010 | Light Outboard Motor Boat Bass Fishing...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
