Question about Kenmore Dryers
Removing the back from a kenmore 90 series dryer
If your model looks like it has two hinge brackets at the top of the back panel, you don't remove the back, you lift the top instead. Try running a thin blade screwdiver or puttyknife along the top crack above the door on the front of the dryer. You should encounter a release pin about three inches in from each edge. Push the pins in to release the top panel and it should swing up on the hinges. Now you can access the internals.
Posted on Jul 21, 2009
5 Suggested Answers
SOURCE: motor removal and replacement on a kenmore electric dryer 90 series model# 110.86984110
remove screw at each end of console. pull & flip back out of way. remove top, remove bottom panel, slide putty knife to release both retainer clips. remove screws to remove door panel assy. remove belt, remove drum. remove motor clamps & remove wires from motor conector.good luck.
Posted on Aug 07, 2008
larryyb
  • 291 Answers
SOURCE: coins stuck inside dryer fins
raise the top and there are 2 1/4 screws running into each fin ,,,,, take screws out and dump fin and that wit do it for you / larryyb
Posted on Nov 30, 2008
danromarris
  • 101 Answers
SOURCE: My Kenmore 90 series dryer won't heat
The thermal fuse is going to be located on the heating element housing. When you take off the front panel you will see your lint screen housing. You will need to remove that to get to the element housing. Once that's out of the way the thermal fuse should be right on top of the housing. It is small and has two small wires coming off of it. The wires should be different colors. Just don't get it mixed up with the thermostat. Just match it up with the new one that you have. It is held in place with two small screws. Let me know if you have any other questions or still can't find it, also let me know if this was helpful. Good luck and glad to help out.
Posted on Jan 22, 2009
TheMobilian
  • 8220 Answers
SOURCE: kenmore dryer- remove fan to change motor on
The wheel has left handed threads. Use an impact wrench and an adjustable wrench to get it off or get a vice grips or pipe wrncha nd lock down the shaft then get a stick of wood or a hammer handle and shove it in between two fins at the 3 oclock position. Slam downwards on the wheel and it should pop loose.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Mar 22, 2009
Kenmore Series 90 drive belt
Access to the belt may be from the front.
Feb 25, 2018 | Dryers
My Kenmore 90 series electric dryer not running
http://www.washerwizzards.com ,,,,check the thermofuse in the back,,it is a white fuse coverd in plastic with 2 wires attached ,,,,hook the 2 wires together and test it
Dec 23, 2009 | Kenmore 63942 Dryer
9 yr old Kenmore 90 series dryer wont heat
is it gas ? next time open dryer door and send full model number if it heats for a while you have bad gas coils,when you change them out watch out for the coil with three prongs on it,there is a metal piece that sometime gets stuck in old coil when you remove it,if it happens just poke it out of old coil and slide it back on post where new coil will be installed
Nov 07, 2009 | Kenmore 63942 Dryer
My Kenmore Series 90 dryer won't run as it appears the door does not hit the actuator. It would appear either the door has moved to a lower position or the actuator has moved up into the dryer. May I ask...
The door switch or actuator is broken. A common problem. On most Kenmore dryers this is replace by lifting the top. Since you haven't given the whole model number I will discuss raising the top on the most common model.
If your model has a lint filter at the top the slide show below should show you how to raise the top.
Kenmore Dryer
Disconnect power to unit. Lift the cover from the lint filter or if yours is the one with a filter and cover together, remove the whole filter. You will see 2 screws under the cover/filter, remove them. Now, you will need a putty knife or a thin shafted straight screw driver to remove the top panel. Push the putty knife or screw driver to "pop" the front top clips. The top panel will hinge back towards the wall and can be left there. Just inside the top of the front panel, you will see 2 screws, remove them. You will see the wires for the door switch on the right side. *** the top of the front panel toward you to gain access to the switch for replacement.
Reverse process for reassembly. Good Luck
Sep 19, 2009 | Kenmore Dryers
Dryer doesnt go on
I opened up the lower panel of my kenmore 90 and then removed the blower cover. I found two hair pins lodged in the blower and removed them. I tested the dryer with it open and the blower and drum began to turn again. I buttoned everything back up, and it is running fine now.
Jul 21, 2009 | Kenmore 73952 Gas Dryer
Kenmore 90 series electric dryer blowing cold air only
1st check the breakers
2nd check wiring in back to see connections are secure.
3rd check element. It would be burned in two.
4th check thermal overload switch which is located underneath top of dryer. Easy to remove top. Probably 4-6 screws.
Jan 15, 2009 | Zanussi TC7102W Electric Dryer
Kenmore 90 Series Dryer will not DRY
first check the vent outside to see if it is blowing air out strong, then check for heat.
Dec 24, 2008 | Kenmore 62602 Electric Dryer
Motor removal and replacement on a kenmore electric dryer 90 series model# 110.86984110
Aug 07, 2008 | Dryers
Kenmore dryer 90 series model 66901692
heating element is located at the back of the dryer. if you can see a big coil of wires like a long spring laid back and fort to a duct , that is the heating element.
Feb 19, 2008 | Kenmore 62602 Electric Dryer
Dryers Logo
298 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
