Question about Daewoo Heating & Cooling
DAEWOO AIR CONDITION MODEL DSC-F1253L-V MINI SPLIT INVERTER THE UNIT WORKING FOR 3 MINUTES AND TURN OFF AUTOMATIC AND SHOW CODE FH. THE UNIT IS NEW. WHAT'S MEANS CODE FH. THANKS
  • 1,381 Answers
The indoor EEPROM unit
1 ChecK whether there are false weld or bad connection etc, between the EEPROM chip block and electronic control board,
2 check whether the EEprom chip is broken foot and the direction of the installation is in line with EEPROM block.
3 When the procedure of EEPROM chip and itself have fault the code FH will appear. That is a need to replace EEPROM chip.
Posted on Dec 15, 2016
What means code FH in the console A/C Model DSC-F1253L-V Thanks
No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Check/Repair:
Press PAUSE/CANCEL twice to clear the display.
If there is no water in the unit:
1. Make sure that both valves at the water source(s) are turned on all the way.
2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
3. Verify inlet valve operation
If there is water in the unit:
1. Verify Drain pump operation
2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
Verify there is not a siphon problem
Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
Check all hoses for possible leaks
Verify pressure switch operation
Verify flow meter operation
Verify CCU operation
If this is intermittent, it would be very hard to determine the cause.
It can be caused by low water pressure into the water from the customers water supply, or clogged inlet water valve screens.
Make sure you don't have any duct tape or something around your drain pipe, it needs that air gap to prevent siphoning. Hope this helps
Dec 15, 2016 | Washing Machines
How do i get refrigeration to circulate in Daewoo model DSC-F1253L-V split AC system. All installed and no cold air, no error codes?
If you don't evacuate the system/vacuum you will be contaminating the refrigerant. Reduced efficiency and premature compressor failure are destined to be in your future. You must at least purge lines. Hope you're confident in your flares/solder joints. Does the condenser come precharged? There has got to be a service valve or you cut them off to not have to flare. Good luck
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Oct 03, 2016 | Daewoo Heating & Cooling
Hi, when i turned on my Senville mini split the fan will go on for 2 - 3 minutes and then the air conditioner will display P4. On the error code description, it say inverter compressor drive error.
contact the manufacturer to see if they can help you with this type of failure. the compressor and its controller are the two most expensive parts of the unit to repair.
Jul 29, 2016 | Inverter Heating & Cooling
Accent model ADC 27E1. Why is it displaying E C fault?
FAQs and Troubleshooting - Actron Air
www.actronair.com.au/service-and-warranty/faqs-and-troubleshooting
The air conditioner is not running at all and no control lights are on. (If there are no ...Air conditioner regularly cuts out on a circuit breaker trip or error code ...
Air conditioning (Accent Air control panel) is - Fixya
www.fixya.com/support/t3343544-air_conditioning_accent_air_control
Nov 3, 2009 - Air conditioning (Accent Air control panel) is displaying EC - what ... Panasonic mini split air conditioner css9nkua error code h99 what does it mean ...ERROR CODE ON AIRCONDITIONER LG ART COOL INVERTER MODEL .
Dec 05, 2015 | Heating & Cooling
New LG mini split installation getting error CH05
I believe the wiring may be incorrect. Here arethe fault codes.
05
Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
5
Hope this helps
Bob
Aug 08, 2014 | LG LA120HYV Art Cool Premier 120HYV Ultra...
System 3 in-door with system 4 out door inverter. all in door unit show error code CH24 pls help
CH 24-Splits and Multi Splits = High or low pressure trip. Low at 1 bar High at 35 bar check pressures. Multi V = High pressure trip.
Nov 17, 2010 | LG LS-L1210CL Mini Split Air Conditioner
My mini split shows f8 and turns on/off alone
The unit is going off on a hi temp .Can you leave it off for a while and then it will start up if you turn it on?I would be checking the fan motor to see it will run alone when the unit stops.Also check and see how hot it is at that time.
Apr 05, 2009 | Daewoo DWC-073C Air Conditioner
LG Inverter A/C Unit LSJ092V-3
I would first check the condensate drain pipe. This can be done by blowing back into the drainpipe from outside. Not to worry it is not dirty or dangerous. Also make sure that your air filters are clean.
Feb 19, 2009 | LG LS-L1210CL Mini Split Air Conditioner
Heating & Cooling Logo
Top Daewoo Heating & Cooling Experts
Tim Whalen
armandog07
armandog07
Steve
Are you a Daewoo Heating and Cooling Expert? Answer questions, earn points and help others
