Question about Garden
Solenoid clicks but plow won;t move
Lights on plow come on , but when I try to raise jack, or turn plow left or right or up , the solenoid clicks but plow won't move nor will the jack. Test light shows I have power . Would a bad solenoid turn on the lights and show power to plow? Bad battery connection?
jigsawbill
  • 398 Answers
SOURCE: Dead battery or starter?
Take the battery out and have it charged up. reinstall it and you should be allright. Your car has discharged it completely, and it will need a recharge to start. The gauge is only measuring voltage, and not the status of charge.
Posted on Aug 06, 2008
SOURCE: The charge lights blink and the chair won,t go.
Just had this problem with my Guardian Aspire. They had to replace the electronic box with the joy stick. BIG BUCKS!
Posted on Mar 13, 2009
ghost45
  • 1280 Answers
SOURCE: 95 hundai accent wont start
The wiring diagrams for the 95 Accent do not show any OEM (original equipment manufacture) 'anti-theft' systems.... this does not preclude the possibility that an After Market system was installed.
Posted on Sep 06, 2009
  • 14036 Answers
SOURCE: 97 ford escort left turn signal ticks fast, but no lighty outside
A BAD BULB MORE LIKELY.
Posted on Oct 04, 2009
saailer
  • 1871 Answers
SOURCE: Turn the key, heard starter solenoid pop, clicking
Hello! It sounds like the cables (both + and -) are corroded or loose...If you have a volt meter and a wee bit of experience using it, here is a voltage drop test...If you do not have a meter send a comment...Turn the key to on...turn on headlights, and blower motor...Set the meter to its lowest voltage scale...Place the positive probe on the center of the + battery post...Place the negative meter probe on the other end of the cable where it connects to the starter...Meter must read less than .03 volts...Next place the + probe on the center of the - battery post...The - probe on bare metal of the engine block...Meter must read less than .05 volts...If one or both readings are incorrect the problem is poor cable connections...If the cable ends that hook to the battery are corroded where the cable is attached to the connector...Replace both - and + cables...Making clean and tight connections on both ends...Send a comment....Guru...............Saailer
Posted on Feb 09, 2011
I have a fisher minute mount 2 plow for some reason it only goes to the right now , not up or left , no matter what button I press on the control it goes right .
Start by plugging everything in and pop the cover off the control part on the plow and check for magnetism on all 3 solenoids when you hit the various buttons on your plow controller. The pull should be very strong and noticable...a weak magnetic pull is likely just residual magnetism on your screwdriver. In my case, the S3 solenoid wasn't firing and that causes exactly what you're describing.
If your S3 isn't firing you can test the wiring by moving the S3 hot wire to the S2 solenoid. If your wiring is good the plow will misbehave in an entirely different way. Also get out your ohm meter and test the S3, if its good you should get 7 ohms on it.
You need to use the guide from Fisher and be methodical about it. Start at the plow and work your way backwrds towards the truck.
Jan 27, 2016 | Cars & Trucks
I have a minute mount plow, when I try to use it only goes to left and right side but doesn't go up, when I try to lift the plow goes to the right. What can I do
2002 Fisher Minute Mount Inst-Act Wont Angle [Archive] - PlowSite ...
www.plowsite.com > ... > Truck & Equipment Repair
Nov 17, 2011 - 90 posts - ‎9 authors
My plow went up it was jerking and did it in steps , but , it got there . Now , it onlyjerks when i try to angle it right or left or up . I filled the fluid ... Drop it and if it doesn'traise you can just use a jack and shorten the transport chain to hold it. .... I do havecontinuity on the plow side for all 3 wires going to the plug . Hooking Up A Fisher Minute Mount 2 In Under 1 ...
Feb 1, 2011
Plow Wont Angle
Oct 19, 2010
What's wrong with my plow?
Jan 9, 2003
Looking For Minute Mount Tips
Feb 13, 2002
More results from www.plowsite.com
Ultramount Intermittent Angle Problem - Snow Plow Forum - L
Dec 27, 2015 | Cars & Trucks
I have a fisher minuteman plow it will go up, left and right but will not go down what is wrong with my plow
If you have a Minit Mount two it's probably the valve sticking. It's electronically controlled so if it clicks, then the solenoid is working and the shuttle in the valve is stuck. Can be disassembled and cleaned. New ones are best but pricey.
Jan 24, 2015 | Cars & Trucks
Plow will only turn to the right
It is electric over hydraulic most are, make sure the solenoid is clicking when you try to turn the plow. One side is working see what one is clicking the other one would be the culprit. If the solenoid are working then the problem is internal to the valve body. Make sure you haven't bent the rams that will cause this as well. If you have you will hear the hydraulics trying to over come this. Make sure the power is getting to the solenoid as well to make them click. Sometimes the switch inside the cab will break inside and not send the electric signal to the solenoid. inside when they do this they are moving a spool valve to redirect hydraulic flow of fluid to one ram or the other. Hope this helps :-)
When i try to lift or angle my plow all i get is a clicking sound when i push the lift button and when i let up on the button the moter on the hydrolic unit will click but will not move the plow. minute...
Not familiar with model, but valves click at the same time motor is suppose to run. Check power and ground to motor (or try running it with jumper cables, but don't be where plow can angle and squish you. If good power but won't spin, clean brushes/commutator/check bearings in motor.
Aug 15, 2014 | Cars & Trucks
NO power wont lift
boss plow will not go up or down, do not have light on main control. Truck lights will go on but when toggle switch is activated, truck lights stay on and plow lights will not go on.
Jan 28, 2011 | 82" TruckSUV Snow Plow
Fisher plow that wont go up and sometime won't turn either way
did you try cleaning the solenoids for the plow? i think this would solve your problem
Mar 09, 2009 | 1996 Dodge Ram 1500 Club Cab
Garden Logo
174 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
