Question about Health & Beauty
I have a klafsun pro 3000 I went change timer on bed and heard a pop sound now I can't get the new timer to work checked the breaker it on. Is there a fuse or something else I could of blown
SOURCE: Sound Won't play
We had the same problem with our last rca stereo. I don't remember what model it was. My husband took it apart and found that there was and area on the circuit board that was fried. I don't know of any other solution then the one we chose. Trash it. I'm not expert but I would imagine that you could by a new stereo for the price of replacing that circuit board. Just don't buy an rca. They are junk. Our new rca just quit playing cds.
Posted on Nov 06, 2007
  • 161 Answers
SOURCE: Oven blew a fuse
The POP sound normally indicates a short circuit fault (as opposed to overload) you need to have it looked at by a competent person.
Posted on Nov 17, 2008
  • 298 Answers
SOURCE: Loud pop Blank screen 42 inch Viore Plasma
Unfortunately, that board is the inverter board. And for this model the inverter board is only supplied with the the PDP panel. The panel is quite expensive, here's a link if needed:
LG 42PX5D Replacement Part PDP Plasma Display Panel
Posted on Dec 29, 2008
  • 225 Answers
SOURCE: blown fuse, i think
pull one fuse at a time check to see if its blown,continue until you find the blown one(hold fuses to a light to see if the wire in fuse is seperated.)
Posted on Jun 13, 2009
bozcro
  • 867 Answers
SOURCE: I was roasting a chicken in my Maytag Cooktop when
there is a short for sure, sometimes when the heating element burns out and melts, it touches the metal inside the housing causing a short. inspect the heating elements in the oven(top and bottom). the loud buzzing sound is what a shorting out heating element makes as it melts like a weldin rod, usually because of using tin foil(not recommended)
Posted on Jun 15, 2009
I have a Sunquest Pro 16s tanning bed. I just put all new bulbs in and tanned 2 times then it quit working. the timer is still going but the bulbs went off and the fan stopped.
Have you checked to make sure the bulbs are inserted properly? If everything checks out well I would contact Sunquest customer service.
Jan 09, 2018 | The Health & Beauty
I heard two popping sounds and now my television will not power on.
A popping sound as you describe sounds as if your tv blew a couple capicators on the main control board. More than likely , you are needing to aquire a new main circuit board.
Sep 01, 2014 | Samsung UN55B8000 55 in. LCD HDTV
Sunquest 24s wont do nothing
Have a trained technician to check for blown fuse on back of bed and then for burned out wiring in top and/or bottom of bed. Voltage going to bed may also be a cause. These beds are sensitive to wrong voltages.
Dec 21, 2012 | Wolff Sunvision Pro 24S Tanning Bed
I have a sunvision 24 tanning bed and it isn't coming on what do i do
Have a trained technician to: Check main breaker, check that bed is getting power to it, check for bad fuse on back of bed, check for burned out wiring inside of bed at main relay, check that the timer is good.
Aug 28, 2012 | Wolff Sunvision Pro 24S Tanning Bed
After a "pop" - the oven no longer works
You should have thrown the breaker before moving the oven. The element likely shorted and blew the breaker. make sure the breaker is off. replace the element and plug it back in and reset the breaker.
Eric
Sep 22, 2009 | Ovens
Put in new wall oven and set the clock and a few minutes later I heard a pop sound and the power to the oven went off without tripping the breaker. There is power on the 15 amp circuit but not on the 30...
if nothing on it works there is a possibilty the control borad went out if it has a control borad if it is new the warranty should cover it
Jun 07, 2009 | Ovens
Electric Dbl Wall Oven-loud popping noise at end of self clean
Bill ,i dont suspect the control unit is the problem im going back to the loud pop you heard I would say the pop you heard was one of the elemants blowing and that the reason the the breaker tripped if you say the clock,timer and light functon are ok it more so points to an elemant in most cases when an elemant blows it breaks the circuit .but the other componants also work when you reset the breaker i think in this case bill i would call a electrician it needs testing,sorry i could not help this time bill,but do not hesatate to contact me if i can help you again.adrian
Feb 02, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Toshiba tz50v51 popping sound
Possible problems: * The TV set may be unplugged. * A fuse or circuit breaker may be blown or switched off. * The remote control unit (RCU) may be disabled. Solutions: * Make sure the TV/VCR are plugged in and the wall switch is on. * Check the fuse or circuit breaker. Test the outlet with a lamp. * Replace the RCU's batteries: if this fails exchange the unit.
Jan 18, 2006 | Toshiba TZ50V51 50" Rear Projection...
Health & Beauty Logo
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
