Question about Poulan Garden
Poulan chainsaw got turned upside down running full open,quit and now won't fire off,even with shot of starting fluid.
  • 270 Answers
This being a two stroke the oiling is via fuel - oil mix, there are few reasons this may be happening.
fist remove the spark plug and check it. It may need replacement IF the center electrode is rounded or if it has heavy deposits on it. While it is out attach the plug wire and give the starter rope a pull to see if you have spark. No spark means more trouble shooting which I will not get into now.
If the plug is black or dark it has been getting too much fuel. The spark plug should look tan after some use in a properly working engine.
The air filter is also worth checking... No air or restricted air will cause a blackened or dirty spark plug.
Lastly it is possible the carburetor has particles in the fuel bowl. These can get into the very small fuel delivery passages (jets) and cause the problem you describe.
This means removing the carb, taking it apart to clean it. There are many you tube videos available that can help you with this last possibility. Since you tried starter fluid this seems unlikely.
Keep in mind these are very simple engines to troubleshoot but you may be better off taking it to a local small engine repair if you are not conversant with the tools and processes I put above.
Posted on Dec 15, 2016
It is getting fuel but has a weak spark and will not start.
DO NOT , I repeat do not use starting fluid on a 2 stroke chainsaw or trimmer. you will score the cylinder or the piston. When trying to diagnose a hard to start motor just give it a small squirt of mix in the carburetor. If it won't fire you have a compression problem or an ignition problem. when you test for spark make sure you have a good plug, that is well grounded and not in bright sunlight which can make it hard to see the spark. if you have spark, do a compression test.
Mar 19, 2015 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
My new poulan will start and run great for about 5-10 minutes then will just quit running. let it set and cool down and it will do the same thing why?
important to use correct oil and mix. no guessing. too much oil mix fouls up the engine. make sure blade is adjusted properly and not gummed up with oily debri
Feb 14, 2015 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Why chain saw will not start
1) Check if it fire! If not! change spark plug!
2) Fill fuel tank, Pull spark plug ou, turn upside down chainsaw, if fuel drip from the cynlinder than you need to change carb gasket.
3) check if the bubble primer is not puncture. If so need to remplace it!
4) Clean the gunk!
Jun 23, 2014 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Chainsaw will not start
1. make sure you have full tank of proper fuel mixture.
2. prime carb. if applicable
3. set choke to full
4. pull starting cord till it fires
5. place choke to one half full
6. pull starting cord till it runs, then as the engine heats reduce choke to full open.
Jan 23, 2014 | Poulan Garden
I have a poulan pro 4218 it was running great when i put it away last year . went to start it this year put in fresh fuel i have a spark used starting fluid doesnt even try to start what gives?
If there is good fuel in the tank and there is a good spark, there is only two reasons why it will not fire up, the ignition timing is out ( sheared flywheel key ) or there is too little compression ( engine has seized at some time trapping the rings )
Oct 14, 2012 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan Pro - won't start after quitting
Hi, unfortunatley you have partially siezed the chainsaw. You will still feel some compression with your thumb but the rings will be siezed in the piston. Hence no fuel transfer to the sparkplug. Sorry Phil.
May 30, 2012 | Poulan Garden
Just bought a poulan 14 inch chainsaw...filled it with bar oil and the gas oil mix. Trying to start and won't even turn over. Any suggestions?
If it wont turn over, it may be because the cylinder is full of fuel, remove the spark plug under the top cover, with the plug out does it no crank over, if so give it a good few pulls to clear it out, replace the pluf and try again, using no choke and full throttle, just one point you didnt fill the fuel tank with oil by mistake??
Jul 18, 2011 | Poulan 14" Chainsaw
Poulan 18' model 2000 chain saw, quit running , will not start.
If you have a compression gauge, check the compression. Anything under 90psi is too low.
Check your flywheel key. If it is broken the flywheel will move and not fire at the correct time.
Note: if it does not sputter with carb cleaner then it's not your carb.
Remove your exhaust manifold. Look into the cylinder with a flash light. You are looking for scratches. Anything larger then a light fingernail is definite proof you need a new cylinder/piston assy.
If it passes that test do the following:
Pour mixed fuel straight into your cylinder until 1/4 full. Slowly pull your saw over while looking into the cylinder. If you see bubbles after the ring/rings go by then you need a new cylinder/piston assy. On rare occasions if no scratches are present on the cylinder wall or piston, you may be able to change just the rings.
Mar 31, 2009 | Poulan Pro Chain Saw 46cc 20"
Garden Logo
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
