How do I fix the can when the lid doesn't open when I step on it?
    Top Expert:
  • Washing Mach... Master
  • 8,302 Answers
Dryer doesn't stop when door is opened and light does not work (new bulb)
see the next steps and proceed with common sense: God bless you
If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. To determine if the lid switch has failed, watch the part testing video at the bottom of this page. Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse
Aug 01, 2012 | LG Tromm Electric Dryer
Tip
How to fix a Washing Machine if it doesn't Spin
If the washer seems to complete all of its cycles but doesn’t spin:
1) Be sure the load of clothes is not lopsided. If the tub becomes unbalanced, it may spin erratically or not at all. Open the lid and reposition the clothes. This automatically resets an off-balance shut-off switch. Then, just close the lid and retry.
2) Check the lid switch and the tab on the lid that strikes it. If the plastic tab is broken, the washer may halt during the spin cycle. If the switch doesn’t click when you press and release it, it’s probably broken. If you’re experienced at home repair, you can remove the switch, test it, and replace it if needed; otherwise, call an appliance repairperson.
3) The belt may be loose, worn, or broken. If you’re fairly handy, tighten or replace the belt; otherwise call a repairperson.
4) There may be a problem with the controls; if this is the case, call an appliance repairperson.
on Sep 03, 2010 | Washing Machines
711 Lid lock issues
see this causes:
t doesn't pump or spin
frozen puller, or broken belt, lid switch defective or open replace
It pumps, but doesn't spin
lid switch defective, motor coupler defective,belt broken, clutch worn,drive motor defective,transmission is not shifting properly, basket worn,
It spins only with the lid closed
for security reason, only spin with the lid closed
Jun 19, 2012 | Fisher and Paykel Fisher Paykel Intuitive...
Washer will not spin dry
see the causes:
frozen pulley or broken belt replace+lid switch open or defective replace
lid switch defective, motor coupler defective,belt broken, clutch worn,drive motor defective,transmission is not shifting properly, the basket is worn.
for safety, only sping with the lid closed.
Jun 19, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing/dryer machine will not spin and when drying selected attempts to wash
check this possiblities:
It doesn't pump or spin
prevent to open the lid, test the switch see the diagram
May 11, 2012 | Washing Machines
LSR6132E agitator doesn't work, won't spin?
open the lid,on the right side you'll see a hole in the top panel,stick a screw driver into the hole,you should hear a click or close the lid,lift it up an inch or two and close it down,if it doesn't make a clicking sound the lid switch is bad part number 3949247 and it's around 45 dollars.
Sep 03, 2011 | Whirlpool Washing Machines
Washer won't spin, what do I do
Check the lid or door switch this is the usuall issue with a washer that won't spin. The other is a blocked pump or clogged pump filter.
Apr 30, 2011 | Maytag Washing Machines
Navigation lid fails to open fully
Mine doesn't even try to open. Have you resolved your issue? could you share?
Jan 19, 2010 | 2004 Nissan 350Z
"OP" ERROR CODE
Take a look at this post, it’s for troubleshooting an OD alarm but you can follow the same troubleshooting path to see if you have a lid magnet out of position or a broken lead on the magnetic reed relay located in the left lid lock. The lid magnet operates the magnetic reed relay to signal the lid is closed/the lid is open. Try an external magnet on the left bumper and see if that clears the OP error code with the lid open. If it doesn’t I would try reseating the left lid lock plug (possible corrosion issues). If that doesn’t clear the OP alarm it would be time to pull the life lid lock out of the machine and inspect for a broken lead on the magnetic reed relay or other corrosion issues with the left lid lock. The left lid lock is in a location near the bleach dispenser. Links to the SM are in that post and a link for parts look up. Post back if you have questions
Jun 23, 2009 | Maytag Neptune FAV6800AW Top Load Washer
MY WASHER STOPS ITS CYCLE WHRN IT GETS TO SPIN,BUT IF I PRESS REAL ******* THE TOP THE TIMER KICKS BACK IN
Sounds like you have a lid switch problem. The machine thinks the lid is open and it is designed not to run with an open lid. Depending on the styl of whirpool washer you have there is two ways to fix it. First raise the lid of your washer. Do you see a pin on the underside of the lid and a hole in the top of the machine it would fit into? If you don't, try tightening the 4 phillips screws on the hinges on either side of the lid. If they get loose the hinge wont strike the lid switch. If you do see the pin and the hole I mentioned, you likely will actually have to replace your lid switch. If you have this style, send me back your model number and I will type you up a step by step replacement of it.
Jun 26, 2008 | Whirlpool Washing Machines
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
