Question about Insignia IS-LCDTV32 32 in. Television
Remote Broken my remote control went off. i purchased a universal remote and cannot get it to work either,, help
  • 934 Answers
Re: Remote Broken
If you're looking to make the universal work with the Insignia Tv you need to research the remote (model/brand) to the Tv. You can do this at:
It would be my strong suggestion however that you purchase the original because no universal remote will allow you access to the service menus and all the features.. You can buy the original for about $32.00 plus shipping at :
Hope this helps!
Posted on Dec 01, 2007
0 characters
3 Points
My remote for my viano TV is broken and I need a replacement , can you help?
If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site Check this site too. Universal remote controls are available at most of the electronic spare part selling shops.
Oct 09, 2014 | Sharp 60-inch LCD TV - LC-60E69U Aquos...
GVA 42 inch LCD TV #OLN5773 original remote broken and cant get universal one to work plz HELP!
If you are able to mend and stick back the broken covers you can repair the remote control . check this link for tips, if not click the link below for universal remotes that can work with your TV.
Oct 19, 2011 | Flat Panel Televisions
Remote is broken and tv wont turn on with button on side, just keeps turning itself off
The best solution for you would be to purchase a new remote control.
You can contact the manufacturer of your TV directly to arrange purchase of a remote or you can go in to an electronics store and purchase a universal remote for less than $10. With a universal remote, you need to do a code search and program it in, but it can do most basic functions of your tv.
Mar 07, 2011 | Flat Panel Televisions
Remote control
Be sure to check all your menu settings for the remote control function. Shake the remote a little bit if you hear some rattling inside then its broken. It could bee the IR eye that's has developed a problem with-in the remote or the tv itself. Try a universal remote to see if its the tv or the remote that's not responding.
Nov 03, 2009 | Soyo DYLT032D 32 in. LCD Television
I have the child lock on and the remote control is broken. How can I turn the tv on without the remote control
The power button on the TV doesn't work because of the child lock?
I went over the copy of your manual for your TV. It must be the child lock timer problem.
I would try leaving the TV unplugged for 30 mins and see if that reset the TV and releases the lock.
If it doesn't work, the remote needs to be replaced. A universal remotes aren't really universal when you need to use special buttons. The remote made for the TV is the best.
If your TV is the model 47PFL7403D, here's the cheapest place to buy a replacement.
May 12, 2009 | Philips 47PFL7403D 47 in. LCD TV
Trutech 16190 no remote
Try the Universal remote control URC-R6 it works fine with my Truetech.
The bad thing about my Truetech PLV16190 19" Flatscreen, 30days after I purchase the remote the tv went out. Screen Black, but sound works fine.
Feb 05, 2009 | TruTech PLV16190 Television
Universal remote
i have a television but my regular remote is broken don't work. some universal remote control don't have the codes for the tv. i just bought a remote sony i figure it had the code but it didin' do i get a code for the universal remote that i bought.
Feb 16, 2008 | TruTech PLV1615T 15 in. LCD Television
Ilo hd tv
Hey try unplugging your television and taking the batteries out of the remote control.. Wait about 5 minutes and try it then! Did that help? If not, your remote control code be broken or it could be your television, but most likely the remote, so I would recommend purchasing a new replacement remote control from a site like instead of buying a universal remote control that you'll have to spend hours trying to program to work with your tv, instead the replacement remote will be an exact replacement for that broken remote control. Hope that helps!
Sep 06, 2007 | iLO V27DMBX Television
Some more suggestions to see if your remote control has just lost it's programming is try unplugging your television and taking the batteries out of the remote control for atleast 5 minutes. If this doesn't work, or you've tried tvtek's advice up top and you still can't get your remote control to work, I would try ordering a original replacement remote control for your specific television. I would not recommend purchasing a universal remote, because half the time the problem with it not working could just be caused by it using the incorrect code. If you go to a site like and look through their site for the exact model number of your television and purchase that remote control than you'll have a good idea if it's the remote or the television. Most likely you'll find it was the remote control!
Feb 21, 2007 | iLO V27DMBX Television
Insignia IS-LCDTV32 32 in. Television Logo
Top Insignia Flat Panel Televisions Experts
Sp Gupta
Gareth Cockram
Gareth Cockram
The Wyzzyrd
Are you an Insignia Flat Panel Television Expert? Answer questions, earn points and help others
