What means code FH in the console A/C Model DSC-F1253L-V Thanks
  • 1,381 Answers
No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
If there is no water in the unit:
1. Make sure that both valves at the water source(s) are turned on all the way.
2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
3. Verify inlet valve operation
If there is water in the unit:
1. Verify Drain pump operation
2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
Verify there is not a siphon problem
Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
Check all hoses for possible leaks
Verify pressure switch operation
Verify flow meter operation
Verify CCU operation
If this is intermittent, it would be very hard to determine the cause.
It can be caused by low water pressure into the water from the customers water supply, or clogged inlet water valve screens.
Make sure you don't have any duct tape or something around your drain pipe, it needs that air gap to prevent siphoning. Hope this helps
Posted on Dec 15, 2016
The indoor EEPROM unit
1 ChecK whether there are false weld or bad connection etc, between the EEPROM chip block and electronic control board,
2 check whether the EEprom chip is broken foot and the direction of the installation is in line with EEPROM block.
3 When the procedure of EEPROM chip and itself have fault the code FH will appear. That is a need to replace EEPROM chip.
Dec 15, 2016 | Daewoo Heating & Cooling
How do i get refrigeration to circulate in Daewoo model DSC-F1253L-V split AC system. All installed and no cold air, no error codes?
If you don't evacuate the system/vacuum you will be contaminating the refrigerant. Reduced efficiency and premature compressor failure are destined to be in your future. You must at least purge lines. Hope you're confident in your flares/solder joints. Does the condenser come precharged? There has got to be a service valve or you cut them off to not have to flare. Good luck
Oct 03, 2016 | Daewoo Heating & Cooling
Fh error code wirpool duet washer
Display shows F20 or FH - Front-load washer ' Whirlpool ...
Whirlpool Home AppliancesQuestion: Display shows F20 or FH - Front-load washer. Answer. Image. or. Image. or. Image. This error code indicates a water supply problem. Are both the hot ...
whirlpool duet error code FH - Appliance Repair Forum > Appliance Repair Help > Washer Repair
Jan 5, 2009 - 10 posts - ‎1 author
... Repair Help > Washer Repair » whirlpool duet error code FH .... FH No water detected entering machine or Pressure switch trip not detected. Whirlpool Duet diagnostic code C:03 error code FH
1 post
Dec 5, 2014
Whirlpool Duet Washer HF Error Code
Jun 10, 2013
FH Error Code on Whirlpool Duet Washer
Mar 11, 2013
FH error code
Sep 13, 2008
More results from
Stumped on error code FH for Whirlpool Duet front load washer .
Jan 08, 2016 | Washing Machines
Whirlpool duet washer fills with water washes for about 12 min then code hf
The FH error code means that the washer has not detected any water entering it. This tip i wrote relating to the FH code covers what to checkto fix it.
Oct 04, 2011 | Whirlpool Duet GHW9150P Front Load Washer
The error code FH means no water is detected entering the machine which can be due to a faulty flow meter not registering the correct amount of water that has passed through it or the pressure is not tripping from the empty position to the full position when the correct water level has been reached. Your machine is definitely made by Whirlpool like other Kenmore and Maytag washing machine so they are basically the same and troubleshooting is then the same. The link below contains the detailed troubleshooting of this error code for a Whirlpool Duet and should be applicable to your machine.
Error Code FH on Whirlpool-made Front-Load Washers
Aug 13, 2011 | Maytag EPIC MFW9700S Front Load Washer
Whirlpool duet FH code
its possible you have the correct number, but yes the FH is a "no waterdetected" fault, are you sure you rehooked all wires in the rightt location and in the right position(it possible to put a harnes sin the wrong slot or even upside down, the only 2 CCU's out there for this model and of you had the wrong one you would get wrong cycle selections, not anything to do with the intake waster, i would really recheck your connections
Jan 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore elite he3 flashing FH
The following link explains the "FH" error:
This can be a rather tough one to figure out, even with the error code explanation. I would recommend unplugging the washer for AT LEAST 30 minutes first. This will reset the Central Control Unit (CCU). In many cases this is all that is required to correct momentary glitches with the unit. If the error code reappears, check your washer installation to rule out the easiest possiblities, first. This means checking to ensure you don't have a siphoning condition, checking your drain lines and checking to ensure your fill hoses aren't kinked or clogged. Read through the link thoroughly and let me know if you have questions. I hope this helps you.
Jan 09, 2009 | Kenmore 46462 Front Load Washer
Fault code
I have look over the codes for your model and dont see an FH code if you post your email here i will send you the service manual
Jan 26, 2008 | LG WM1814CW Front Load Washer
Washer trouble
fh means no water coming into washer. remove cold water line from back of washer and see if the screen in the valve is clogged. if so, remove screen and clean it, if not replaced water valve
Nov 22, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
