Question about Vector Camping, Backpacking & Hiking
Vector VEC158 3,000,000 spotlight, when I plug in using the built in A/C adapter all the led battery indicator light come on (3 red and the green) and there is nothing in the manual about this!
brainyass
  • 242 Answers
SOURCE: Vector Sport Spot 1,000,000 candle power spotlight
6 Volts, here is info from site.
VEC127Y
VECTOR SPORT SPOT 1 MILLION CANDLE POWER CORDLESS-RECHARGEABLE SPOTLIGHT
  • HIGH CANDLE POWER QUARTZ HALOGEN BULB DELIVERS A BRIGHT AND TIGHT BEAM
  • AREA WORKLIGHT IN HANDLE PROVIDES UP TO 15 HOURS OF LIGHT WHEN FULLY CHARGED
  • PROVIDES CONTINUOUS SPOTLIGHT USE FOR UP TO 25 MINUTES WHEN FULLY CHARGED
  • HIGH IMPACT, BREAK RESISTANT ABS AND POLYCARBONATE HOUSING
  • TOUGH, WEATHER RESISTANT AND BUILT FOR RUGGED OUTDOOR USE
  • REPLACEABLE 6 VOLT, 6 AMP HOUR, NON-SPILLABLE, SEALED BATTERY
  • LOCKING TRIGGER FOR ON/OFF LIGHT CONTROL
  • INCLUDES AC AND DC CHARGING ADAPTERS
  • INCLUDES BUILT IN HANDS FREE WORKSTAND
Posted on Sep 17, 2008
SOURCE: Need adapter for Vector 1 Million sport spotlight Model VEC156
if its the one im thinking of, i had the same problem.
if you look at the back and theres the male prongs to plug into the wall
well what i did was i took off the back
then i took off the cradle that held the battery in place, and stood it up on the lens and simply plugged it into the wall to charge it.
its kind of complicated but simple way to save some dough in todays market.
Posted on Dec 03, 2008
  • 973 Answers
SOURCE: My Vector Vec157 Flashlight won't Charge...
It is the battery, I have a similiar Vector light for a few years and tried re-charging the battery but only the little LED light would come on. I have another Vector light, same model and switched batteries from the worjking one to the non-working one and now it works fine.
I then proceeded to purchase a new battery for the non'working one and when I arrived home I installed it and turned on the main light, still won't turn on, I tried the LED's, they work. I figured maybe the new battery needs a good charge so I plugged the charger in and charged the light for 12 hours, still no main light.
I guess the new battery is defective, so now I will return it and exchange it for another one.
Posted on May 27, 2010
  • 973 Answers
SOURCE: Power On Board 3 Million Rechargeable Spotlight
Vector is now owned by Black and Decker since 2006, you can order one at their website, you will need to enter the model #, here is the link http://www.dewaltservicenet.com/servicenet_home.aspx?AspxAutoDetectCookieSupport=1
Posted on Jun 17, 2010
Testimonial: "Thank you so much!! I do appreciate it!"
  • 973 Answers
SOURCE: Need replacement battery for spotlight
You can purchase a battery from Black and Decker, they purchased Vectorlite in 2006, here is the link, you will need to enter the model #
How can I fix my rechargeable portable spotlight/flashlight after no charge for 1(one) year?
I replaced the battery in mine(coleman powermate) for 10 bucks but you have to be careful in how you disassemble it and put it back together. Batteries sulfate after awhile like a car battery.
Dec 12, 2014 | Vector Camping, Backpacking & Hiking
The spotlight/flashlight battery may have failed as a result of being unused and not charged periodically.
I simply need to know what the 3 colored LEDs on the handle represent. There is a red one, an orange(yellow) one, and a green one. I lost the manual and need to know when the battery is fully charged. ...
Red, Yellow, Green are the battery level indicators, Red being the lowest like a fuel gauge. If the green comes on right away after plugging in the charger then it must not indicate the charge cycle. If its a 3Ah battery whats the charger output amperage? Then you could just do the math to figure out how long it would take to charge that battery to full with the output. Otherwise it shouldn't hurt it to leave it plugged in overnight or at least a few hours to charge it.
May 04, 2017 | Vector 2M Pwr Rch Spotlight
What tip polarity do I use to connect an after market charger?
The short answer is "The tip should be set to positive (+).
I found an old Vector VEC127Y Spotlight. It appeared to be in perfect condition but the battery was dead and there was no charger. I was able to buy a replacement battery at BatteriesPlus for $21 USD. Here is the link for the battery
REPLACEMENT VECTOR VEC127Y BATTERY
I also purchased a Universal A/C adapter to use as a charger at BatteriesPlus for $17 USD. Their site does not list it yet but here is the manufacturers link. Please note the original battery was rated 6Ah. The replacement is only rated for 5Ah. Which means one less Amp hour (Ah). Which means a shorter run time, after charging, than the original battery had. Otherwise they are equal.
UNIVERSAL AC ADAPTER
I installed the new battery. I set the AC Adapter to 6V and installed the largest of the seven adapter tips that came with the charger, with TIP set to be positive (+). I opened the battery compartment of the spotlight and disconnected both the red (positive +) and black (negative -) battery leads from the battery. I then plugged the adapter tip of the Universal AC Adapter into the spotlight and plugged the AC Adapter plug to a power outlet. With a multimeter I tested the polarity of the spotlight battery leads while charging. I was able to confirm that the Adapter TIP should be set to positive (+). After reconnecting the spotlight battery leads and setting the AC Adapter to charge, I have a perfectly great spotlight in full working order.
Dec 02, 2010 | Vector Spotlight - 1 Million Candles...
I have vectorlite 1.5 Million Candlepower light I want to know the ac charging adapter specification. We kind of lost track of particular adapter in recent moving :(. we appreciate your help....
Most of the Vector spotlights use a class 2 charger with an output of 12VDC 400ma with a positive (+) center connector, which are very common. I have several of these chargers from different manufacturers, and I use them interchangably on whichever spotlight I happen to plug them into.
One complication with my Vectors is they use a coaxial connector plug on the spotlight end that is a size N, which is being phased out and Radio Shack doesn'd even carry any more. If you hae a box of misc chargers, find a 12VDC one with a connector that fits your 1.5MCP light, and that is probably the one that came with your light.
Note that you can also charge your light with the cigarette lighter adapter cord that came with it. So if you can't find an AC transformer that fits but you have your cigarette lighter adapter cord, you can buy one of those cigarette lighter size gadgets that plugs into an AC outlet, and then plug your cigarette lighter cord into that.
Jun 28, 2010 | Vector 1 Million Rechargeable Spotlight
Recharging - indicator lights when complete
When the green light stays on that means the battery is fully charged. The correct charger for that light is a Class 2 Transformer
Model: KA12D120030042U It has a output of 12VDC at 300 mA
May 29, 2010 | Vector 2M Pwr Rch Spotlight
I have been charging my 2 million candle power spot light for last 2 days but full battery charge indicator (red light) does not flash yet. the led white light is working but the main lamp doesn't work....
It should take 10-12 hours, any longer the battery is no good, you can test the battery using a Volt Meter, the battery should be reading 12 volts, any less and the battery will need to be replaced. You can order a new one from Black and Decker, they purchased Vector in 2006, here is the link;
Feb 13, 2010 | Vector 20 Million Power Series Spotlight
VEC127Y
Sep 07, 2008 | Vector 2M Pwr Rch Spotlight
Aug 22, 2008 | Vector 20 Million Power Series Spotlight
Camping, Backpacking & Hiking Logo
155 people viewed this question
Top Vector Camping, Backpacking & Hiking Experts
Barry_IA
Level 1 Expert
Jim London
Jim London
Are you a Vector Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
