Question about Beko Washing Machines
Beko washing machine door is stuck shut, small white lever type handle came off/broke off. need to get washing out
    Top Expert:
  • Beko Master
  • 8,303 Answers
My front loader washing machine won't open-the lock symbol disappears but despite putting the machine through a variety of cycles I can't unlock it
How to open a washing machine door that won't ... - YouTube
? 3:57
https://www.youtube.com/watch?v=-65_eoT6zuk
Aug 22, 2013 - Uploaded by how-2-repair.com
Your washing machine door won't open this video will show you a technique ... to our channels social media as this really helpsmy site and keeps us going. ..... Front Load Washer Door Latch Troubleshooting Replacement ...
How to Open a Washing Machine Door that's Stuck Closed ...
? 1:30
https://www.youtube.com/watch?v=s-_x2tSmd0A
Jun 4, 2010 - Uploaded by eSpares
For all your washing machine spare parts go to http://bit.ly/1828iPF If your washing ... of thumps on the frontpanel next to the lock to see if this shocks it to release. ....impossible for ariston av51 washer, my arm cant go thru it...small space for ... How to open a washing machine door that won't open normally.
How to open a washing machine door that is stuck shut.
www.how-to-repair.com > ... > Door Locks & Switches
Jan 04, 2016 | Beko Washing Machines
Is there a filter
Usually you can remove the kick strip by putting a small screwdriver in the gap and levering the panel off to find the pump filter behind
May 09, 2014 | Beko Wm & Wma Models Washing Machine Motor...
My Beko 81241 LW seems to be stuck in the Spin & Drain cycle (it's not actually on though) and the Start symbol is flashing. The time is also displayed (12mins). The door is also locked. Holding the Start...
Good Day,
Your washing machine is fully automatic?
the washing cycle is normal?
if yes do the same maybe it will help you.
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, how? remove the cup of your drain pump like a ordinary cup, screw it clock wise or counter clock wise.
Remove drain pump filter and clean it, some hair pins, cotton buds or coins or any small item that coz of clog up.
if your washing machine dont have drain pump ,but fully automatic check the drain motor if running or not? how? open the back cover for top loader washing machine only, select spin cycle and press start to see the drain motor running? the drain motor is like a small box with small wire to pull the lever of the drain to remove water inside, if the motor running or pull the lever of the water pipe but water still inside the washing machine, remove the drain cup or cover and clean it or check if have coin or cloth inside that coz of clog or water stuck,
if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
Oct 30, 2013 | Beko Washing Machines
Zanussi FL1012 tenants broke off external door catch. I have bought new catch, how do I release the door to open it without the handle? to replace it with with new handle, only the end bit of the handle is...
there is a lever if you can pry it open a bit and get some type of hook in there and pull it across you can get it open i can get it with just a flat blade screw driver but a have had heaps of practice
Jan 05, 2011 | Zanussi Washing Machines
Hoover washing machine door handle
if any one is stuck fitting a door handle to a hoover washing machine HNL 6146 nextra series then please email me johndgill49@hotmail.com
Aug 29, 2009 | Indesit W 123 Front Load Washer
Can't open the kick plate of my samsung j845 washing machine
Happened to me too today. As I was pulling the handle, a piece inside snapped. The handle felt loose, as though it wasn't pulling the catch. To get the door open, I used a screwdriver. I pulled the handle as far out as I could, so that I could get the screwdriver in. The dark black metal part has to be levered away from the washing machine - in the direction the door would open. That will release the catch and then the door will open.
After the door is open, the challenge is to remove the handle. You'll need to undo all 10 (or so - from memory) of the little screws, so that the inner part of the door comes off. Be careful as you get to the last one - things will fall away. The handle and the small broken tab just fell out for me. Once the handle is out, you can put the door back together again. I use a small hex key to help open (and close) the door. With no handle, the catch springs a bit too far over for the door to close, so you'll need something (e.g. 1/8" hex key) to hold it over a little. So now, I can use the washing machine while I try to find a new part.
Apr 11, 2009 | Washing Machines
Washing machine White-Westinghouse LB-42 door stuck?
The Inside Handle was Broken (from Iside) ! I had to remove the cover and replace the broken handle !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Dec 14, 2008 | Hotpoint WF430 Front Load Washer
Belling SGE12X broken door handlw
it's not an easy job to replace a door handle, but to release it for the door to open, turn off the machine at the outlet and unplug. Take the top of the machine off and slide your hand down to the door catch. Depending which type of catch it is, you should either be able to push down a small lever on top or push up a small lever on the bottom or the door catch.
I hope this helps
Oct 25, 2008 | Belling SGE12X Front Load Washer / Dryer
Zanussi FL884 Washing Machine
there is no emergency release.
two ways of opening door.#
break handle off and you can lever door peg with a small screwdriver
or
disconnect from mains
take top off. feel down to the door interlock and feel for the end of the door peg. push this sideways and you can sometimes release the door
Oct 03, 2008 | Zanussi Washing Machines
Washing Machines Logo
139 people viewed this question
Top Beko Washing Machines Experts
micky dee
janman
Domenico Grillo
Are you a Beko Washing Machine Expert? Answer questions, earn points and help others
