Question about Garden
I have a Jacobson sno- burst snow blower, need the magneto assembly part #126668 for engine J-501ST
2 Suggested Answers
  • 12826 Answers
SOURCE: I have a Jacobson sno-burst snow blower? I need a megneto assembly part#126668 for a j-501st engine
can do an online search for part--notify a small motor --lawn and garden repair shop --
Posted on Dec 15, 2016
Dec 15, 2016 | Garden
I have a Jacobson son burst blower n need the magneto assembly 126668
look up a small engine repair shop or online search for part
Fluid levels in gear box
Amber. With machine on level surface,fill gear box with specified gear oil until it starts running out the fill hole on front of gear box.
press the helpful button and follow me on fixya for more tips
Service
Craftsman snowblower auger gearbox lubricant
Sno Thro Engine Oil Gear Case Lube
Auger Gear Oil Sorry to ask again Snowblower Forum Snow Blower Forums
Feb 09, 2016 | Garden
Why sno thro continues to run after ice block is removed
Because that is how it's designed. It's designed to run again, after you remove ice block.
Apr 29, 2014 | Ariens Snow Blower. Sno-Thro Deluxe Drift...
Looking to see what shear pin the sno trac snowblower model 310-680502
Go to www.doityouself.com Look under who makes sno trac snow blowers. The article tell you what to do.
Mar 19, 2014 | Craftsman 16" High Garden Tractor Snow and...
Auto drive malfunction
the drive wheel is worn out or tension on the wheel needs adjustment
Feb 05, 2014 | Sno-Tek Snow Blowers. 24 in. Two-Stage...
Engine chugging
carb dirty
clean and put fresh gas in it
Dec 18, 2013 | Sno-Tek Snow Blowers. 24 in. Two-Stage...
Auger does not engage on Ariens Model 924121 sno- Thro
first check shear pins in the auger ( try to turn big auger by hand, engine off)
then if they are good then try to turn impeller by hand, engine off
youll need to turn it a few times before the larger ones turn, but thats what you want
if they dont turn then you have sheared the gear box gears
be sure belts are good tooo
Dec 15, 2013 | Ariens Snow Blower. Sno-Thro Deluxe Drift...
My snowblower just started back firing,why?
Snow is melting on the engine and causing the spark wiring and/or magneto to short out...
Stop blowing snow and run the engine at a fast idle for awhile to dry off the motor...then it will work again..
heatman101
Feb 25, 2011 | Toro Snow Blower Ccr 1000 Belt 715381...
I have a ariens 24 "sno tech it will not throw
The most common cause of this is the drive belt is worn. If you remove the cover (usually plastic) in the middle of the snow thrower and look at the belt closest to the blower assembly. This is the blower drive belt. (Your operators manual will show you the location and how to remove the cover if you are unfamiliar with your snow blower)
With the engine not running, have someone depress the drive lever and check the belt. You should only be able to depress the long side 1/2 inch or less. More than that the belt has stretched and needs to be replaced. On some older blowers you can adjust the tension pulley, but most made in the last 15 years, you can't.
The belt may be frayed on the edges or glazed causing it to slip (it is shiny on the sides of the belt)
You can get parts (the new belt) through your local Ariens dealer or jackssmallengines.com
Feel free to ask any other questions. I know Snow Blowers. Please remember to rate this answer!
Jan 13, 2011 | Ariens 34 In. Zoom Series Riding Mower
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
